Old 06-19-2001, 05:47 AM   #1
Sin
Member#: 2403
1998 Impreza 2.5RS
Rally Blue
Exclamation EMergency: STi engine mounts wont go back to the crossmember
after i jack up the engine and put the engine mounts in, i lower the enigne but the screw of the mounts wont go back into the holes of the crossmember
helpppppppppppp
i need to use the car tommorow
Sin is offline   Reply With Quote
Old 06-19-2001, 06:00 AM   #2
Sin
Member#: 2403
1998 Impreza 2.5RS
Rally Blue
Angry EMergency: STi engine mounts wont go back to the crossmember
helpppppppppppp
Old 06-19-2001, 08:17 AM   #3
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Patience, my friend.
They will go in, albeit a little tight. You will have to shift the engine back and forth and side to side to center the studs. Sometimes, you may be able to get one side in first, but have the other side hang up on one of the crossmember alignment features. If that's the case, use a very big screwdriver or thin pry bar to nudge the studs into place.
-WaC
Wayne
wac is offline   Reply With Quote
Old 06-19-2001, 08:20 AM   #4
Travis R
Member#: 153
'07 Mazda CX-7, '91
BMW 535i & '06 Ninja 650R
I have never done the mounts but I've heard that they are hard to get in. I assume you mean the bolts don't line up with the holes in the crossmember, and not that the bolts are too large for the holes. Have you tried leveraging the engine around with a crow bar or some other long lever arm? Don't use the oil pan as that will surely dent. You might search the STi-mailing list archives, as I'm sure this has been covered there.
Good luck
Travis R is offline   Reply With Quote
Old 06-19-2001, 08:34 AM   #5
Pipercub
Member#: 2188
2004 Impreza STI
82 BRAT with 12 in. lift
As someone who has done this twice let me tell you that nothing is out of the ordinary. What you need to do is get two friends to push and rock the engine back as you raise and lower it with the jack.
Pipercub is offline   Reply With Quote
Old 06-19-2001, 10:06 AM   #6
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Yeah, what Pipercub said.
We were putting them on mine and working it back and forth and while were looking at it going what the heck it just dropped in. Clang!
It'll go. Just needs fiddling.
blaster88 is offline   Reply With Quote
Old 06-19-2001, 07:24 PM   #7
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I will go ahead and agree with blaster and pipercub: the engine gets out of alignment with the crossmember when you jack it up. It just takes some patience and a whole bunch of wiggling to work the engine back into the right spot.
-Jon
Old 06-19-2001, 07:57 PM   #8
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
there's a nice big bolt on the tranny you can grab, and pull the whole drivetrain straight back. this works best if someone else is doing the screwdriver-on-the-bolts trick.
ColinL is offline   Reply With Quote
Old 06-19-2001, 10:09 PM   #9
Sin
Member#: 2403
1998 Impreza 2.5RS
Rally Blue
yeah i got it done wooohoo
and the tranny mount also
i feel like the engine is more stable when i start the car
although the shifting feels better, i think it's still lose
Old 06-19-2001, 10:29 PM   #10
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Then get kartboy!
Up Pipe installll helpppp!!! engine mount wont line back up?! WTFJayJay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 02-24-2009 06:25 PM
Stage 2 WRX looking to go back to the stock map-Questions.. SubbieAndCoop Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-14-2007 10:22 PM
Reason to go back to the Dealer. BoostorLose New England Impreza Club Forum -- NESIC 6 05-16-2007 06:56 AM
did subaru go back to the antenna on the roof? VTSubieRS General Community 12 04-29-2007 02:08 AM
Time to lose the winter weight -going back to the cottage cheese diet perret318 Off-Topic 18 03-15-2006 03:53 PM
