Old 08-01-2004, 03:14 AM   #1
Impreza2003
Member#: 67247
2003 2.5RS BRP
SQC 189
Default Crank Pully Install Q
how hard is it to install?
its probably going to be a mr josh or a perrin
Impreza2003 is offline   Reply With Quote
Old 08-01-2004, 07:18 AM   #2
eurojax
Review Crew
Member#: 34269
Only marginally
funny.
****in tough. If i had to do it again, I wouldn't. I put so much pressure and strength into getting that ****in bolt off that I thought I was going to break the engine in two. I used a 5 foot long breaker bar too, and I'm a HUGE guy.
eurojax is offline   Reply With Quote
Old 08-01-2004, 08:53 AM   #3
White2.5GT
Member#: 25142
1998 Legacy 2.5GT
Default no problems
I had no problem at all I also used a breaker bar and it took about 5 mins from start to finish, and that includes getting all the tools and the clean up
Very simple install.
White2.5GT is offline   Reply With Quote
Old 08-01-2004, 10:29 AM   #4
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
You're going to want at least 2 people around.
In the case of the crank pulley, it will be one person to break it free, while the other steps on the brakes (with the car in 5th/park and the e-brake on as well). This coupled with something stopping the rest of the pullies to not turn (shove something in the power steering pulley and brace it in the engine) and you should be able to get the bolt to break free with a breaker bar and something to extend it to like +5' or so.
It sounds daunting, but it really isn't all that bad. With my car this weekend, we just needed to get a chain wrench in order to keep the pulley from turning while I broke it free with the breaker bar and upper bar from a 2.5ton jack. With all that, I was able to break the bolt free.
However, the gains I feel by putting a lighter crank pulley on is incredible. It's not a "kick you in the pants" feeling, but the car is no longer boggy when I step on it. It just pulls all the way through the rev band, and it reaches the power band and everything so much quicker. Most definitely a worthy investment for anyone.
AJ
AJ711 is offline   Reply With Quote
Old 08-01-2004, 11:40 AM   #5
Impreza2003
Member#: 67247
2003 2.5RS BRP
SQC 189
hmmmm I think im going to go to AZP for this one
Old 08-01-2004, 12:04 PM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Its not that bad.
I once did 8 complete underdrive pulley kits in a day, among other mods.
Jay
munkis is offline   Reply With Quote
Old 08-01-2004, 01:27 PM   #7
Nicklbrso
Member#: 44887
00 GC6
Same here.
Nicklbrso is offline   Reply With Quote
Old 08-09-2004, 12:59 PM   #8
AZP Installs
Member#: 40160
Not a problem, we have our usual Saturday open house this coming saturday 8/14 so stop by and we'll throw it in for you.
-mike
AZP Installs is offline   Reply With Quote
Old 08-09-2004, 03:23 PM   #9
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
The ease of the install depends on the model year. My 95 has so much space between the radiator and crank pulley that I didnt have to remove anything other than the belts to get the pulley off. Meanwhile, a 2000 RS takes a bit more work to get the wrench in there... I dont know how much space there is for the 03 though.
Old 08-09-2004, 03:29 PM   #10
Honkey3k
Member#: 53992
SOLD CGM 2005 2.5RS
35 PSI -- in my tires
I had S-Squared do mine... I couldnt even get the alternator pulley to budge =\. They charged me a pretty penny though...
Honkey3k is offline   Reply With Quote
Old 08-09-2004, 03:34 PM   #11
elijah25rs
Member#: 59711
2005 WRX
Crystal Grey Metallic
How long would it take a shop to install a 3 peice pulley kit?
elijah25rs is offline   Reply With Quote
Old 08-10-2004, 08:38 AM   #12
AZP Installs
Member#: 40160
They shouldn't whack you more than about $60 for the 3 set install.
-mike
Old 08-10-2004, 12:33 PM   #13
jeffg
Member#: 2958
2001 WRX (GC8)
The install is really easy with an impact wrench. Thats about the only way to get the alternator pulley off. I wouldnt recommend jamming anything through the pulleys to hold them. Your best bet if they want to spin is one of those strap wrenches. Putting things through the pulley is a good way to damage either the pulley or the thing you jammed it against. Just my opinions.
J
jeffg is offline   Reply With Quote
Old 08-10-2004, 04:13 PM   #14
piker28
Member#: 22664
when i had mine done it wasnt to bad and my car is an auto, more of a hassle
just loosen the belts, get a big breaker bar on the nut to the crank pulley and we did the start crack nut method with starting the car for a second
in all prob took like 15 mins just do to the engine being hot
piker28 is offline   Reply With Quote
Old 08-12-2004, 07:37 AM   #15
AZP Installs
Member#: 40160
15 min after 2 months of whining haaaaaaaa
-mike
Old 08-12-2004, 04:00 PM   #16
piker28
Member#: 22664
hey id rather wait and get it done right then rush and mess something up
Old 08-13-2004, 01:27 PM   #17
staticfritz
Member#: 66934
2004 JBP FXT
2002 cammed OBS - RIP
AZP...how much you charge for a crank pulley install on an MT 02 OBS?
staticfritz is offline   Reply With Quote
Old 08-13-2004, 06:16 PM   #18
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Subaru Banner
I found that tightening the cam and crank pulley's to be the biggest PITA of the whole install when I changed my Timing belt and related components. I had someone hold the pulley(s) w/ a strapwrench while I torqued them down to specs.
Crank pulley bolt: 130 ft-lb
Cam pulley(s) bolt(s): 58 ft-lb
Ditto .
-Charles-
ImprezaVA is offline   Reply With Quote
Old 09-30-2004, 08:46 AM   #19
scoolbuzz
Member#: 44003
2004 Evo (sold)
5 minutes my butt! I just took the Perrin pulley off and that took about 30 minutes! I will put the stock one back on tomorrow morning!
scoolbuzz is offline   Reply With Quote
Old 09-30-2004, 09:52 AM   #20
staticfritz
Member#: 66934
2004 JBP FXT
buzz, you getting rid of the perrin? i might be interested
Old 09-30-2004, 10:13 AM   #21
RyansJDMgc8
Member#: 65462
01' 2.5RS
Silver/Carbon Fiber
How do you loosen and tighten the belts? Do you need a special tool or do you just loosen some brackets?
RyansJDMgc8 is offline   Reply With Quote
Old 09-30-2004, 01:50 PM   #22
scoolbuzz
Member#: 44003
2004 Evo (sold)
Staticfirtsz - I am shipping it today to the buyer!
Ryans... - All you need are 10 and 12 mm wrenches to loosen the brackets and bolts on the AC ? and the Alternator.
Old 09-30-2004, 02:56 PM   #23
chip4761
Member#: 55867
2005 Saabaru
AS
130ft lbs on the crank pulley? I'm fairly certain mine was way less than that (ej22). I had the engine on a stand when I did my timing belt. I just had my buddy hold a stopper on the flywheel while I used my 3/8s ratchet with a 1 ft extension to break it loose. It was tough, but took like 5 seconds. Are you guys sissies? LoL!! Just kidding.
chip4761 is offline   Reply With Quote
Old 09-30-2004, 06:43 PM   #24
RyansJDMgc8
Member#: 65462
01' 2.5RS
Silver/Carbon Fiber
Impreza GC8
Im sure its a lot easier with the engine pulled...
I want to do some pullies but dont know what to do about a new belt??? Will the stock belt work or would I need a shorter one???
How do you re-tighten the belts? Just use a pry-bar or something? I have done this on my 73' Chevy Big Block 454 but my Sube seems a little more complicated....Is it pretty much the same procedure?
Old 10-01-2004, 05:42 PM   #25
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
I've heard 94 lb-ft and 130 lb-ft on the crank pulley bolt. I tightened mine down to 120 lb-ft and felt lucky I got that since I was holding it with a strap wrench and tightening the bolt with a 1/2" torque wrench. It kept slipping and was a PITA. I'm not going to beat this in the ground because this is already a well discussed topic.
-Charles-
The crank pully is a torsional dampner too. ebeck Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 07-20-2003 09:46 PM
AccessECU and aftermarket crank pully conflict? targadave Engine Management & Tuning 3 07-01-2003 08:46 PM
Legacy's and crank pully/keyway issues? annointed Legacy Forum 4 03-25-2003 11:45 AM
Crank pully tool / timing belt replacement mikemo Normally Aspirated Powertrain 16 07-07-2001 12:43 PM
Underdrive Pully Install Help (Or, That %^!@%#^!@# Crank Bolt) BrianX Technical Forum Archive 15 07-24-2000 09:53 AM
