Old 06-19-2001, 09:04 AM   #1
Mikemar
Member#: 7259
2004 Sti
Stone Chip Blue
Question Underdrive Pulleys, What do they do??
Sorry for being stupid but, I see a lot of mention of underdrive pulley sets. What purpose do they serve? I think I know where they go but what good does changing a pulley do?
Mikemar is offline   Reply With Quote
Old 06-19-2001, 09:06 AM   #2
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
lighter, less rotational mass = easier to turn = more power
also
smaller = easier to turn (think gears on a bike) = more power
now, I should rephrase...because they don't give you more power, rather they rob less from the engine than the standard pulley.
JGard is online now   Reply With Quote
Old 06-19-2001, 09:11 AM   #3
MBX Motorsports
Member#: 3726
2001 2.5RS
Blue Ridge Pearl
It increases the efficiency of your pulleys, thus requiring less power from the motor to turn them. It doesn't add horsepower, it simply free's some up.
MBX Motorsports is offline   Reply With Quote
Old 06-19-2001, 09:29 AM   #4
Mikemar
Member#: 7259
2004 Sti
Stone Chip Blue
Talking Thanky Thanky
Why thanky thanky, Thats what I thoght but they seemed kinda pricey for just lighter pulleys.
Old 06-19-2001, 11:30 AM   #5
EchoWrx
Member#: 4101
2000 Impreza
Default Yep!
They are very expensive for what they are but almost worth $150-200 bucks. I know a guy who shattered his stock steel pully on his dual overhead 98 Impreza, now that's torque! He won't use a alloy one because he is scared of doing this again. I have one and I like it a lot. It feels like you have new spark plugs all of the time And it is darn easy to install, if you have big enough tools.
bye
Gill
EchoWrx is offline   Reply With Quote
Old 06-19-2001, 12:02 PM   #6
Poseidon
Member#: 4864
2004 WRX
Just FYI, I think you got that a little mixed up. The smaller diameter means that it rotates slower and sends less power to the alternator (or whatever accessory it is driving). This is why they warn that your lights may dim slightly at idle with an UD pulley. Actually, if you take two pulleys (or gears) of equal weight but different diameter, it takes more torque to get the smaller pulley turning. This is why you get a larger HP gain from reducing the pulley weight than you do from reducing the diameter.
Jordan
Poseidon is offline   Reply With Quote
Old 06-19-2001, 12:22 PM   #7
Santo Domingo 2.5 RS
Member#: 5354
Silverthorn Metallic
Question
Do you need to change the size of your belts when you mount an underdrive pulley?
Santo Domingo 2.5 RS is offline   Reply With Quote
Old 06-19-2001, 12:38 PM   #8
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Yes, you need to change the belt size... actually buy one size smaller than they reccomend. UOR likes loose belts or something.
Midwayman is offline   Reply With Quote
Old 06-19-2001, 12:43 PM   #9
RaceCarRiot
Member#: 6542
1997 Ver IV
Arrow
lightened pulleys use the stock belts. underdrive pulleys need different belts, and a decent retailer will usually supply them as part of the package.
i would just go with the lightened pulley, as there's really no disadvantage (lights dimming, etc) to using one...
stock=5 3/4 lb
lightened=1 3/4 lb
i forget what the underdrive pulley weighs, but it's not much less than the lightened one, just a few ounces.
(adam)
RaceCarRiot is offline   Reply With Quote
Old 06-19-2001, 03:12 PM   #10
Member#: 5354
Question
Wich company do you think, sells the best Underdrive pulley on the market? and do they come with with the recomended belt size for the new pulley?
ah!! also, how can you lighten the stock pulley by yourse˝f? can this be done?
Trespassers... What are they doing? What should I do? markman Off-Topic 102 04-08-2008 01:42 PM
Steering bushings....what do they do and how do you know if you need them replaced? kaisersouse Brakes, Steering & Suspension 4 01-11-2006 11:51 AM
What turbos / mods do they do in Japan? Sordid Philosopher Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-21-2002 06:56 AM
What do they do for the 10000 mile tune up? WR-REX Texas Impreza Club Forum -- TXIC 3 01-24-2002 12:39 AM
Front/Rear end-links, anti-lift castor's, what do they do? Ru fan New England Impreza Club Forum -- NESIC 7 12-14-2000 12:01 AM
