Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 09-27-2004, 06:48 PM   #1
Veck
Member#: 15661
Default Hydra Auto tune question
Anyone know if you can log data and auto tune at the same time?
Did a few pulls on the way home tonight with both enabled and compared the before and after maps and it did not make any changes to the map.
Veck is offline   Reply With Quote
Old 09-27-2004, 07:41 PM   #2
bboy
Member#: 56468
04 Improved STI
Dirty White
You have to save changes for them to be seen. Phil just posted the most complete description of this on his website today. I believe you have to "upload" changes made by Autotune from the ECU prior to shutting off the car. You can make additional changes, but they must be downloaded (transferred) back to the ECU.
Also, are you sure autotune is truly running--turn on "closed loop" and "autotune". You need to also turn off "long-term learning.
Logging and Autotune are separate functions, so I don't see a conflict.
Old 09-28-2004, 01:20 AM   #3
Veck
Member#: 15661
I've done all the necessary steps and have had it work fine before. I'd just never tried to do it with the log on.
Perhaps I missed a step. Wish there was some visual feed back on the main tuning screen to let you know auto tune was running.
Old 09-28-2004, 09:57 AM   #4
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Veck,
I have run both the AutoTune and the data logger at the same time and the system was active. I could see the AFR change from the previous log to the new one. With that said, try it again as you may have made a mistake somewhere. You also may need to turn the AutoTune rate up.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 09-28-2004, 09:01 PM   #5
Veck
Member#: 15661
I figured out what was going wrong. Apparently at some point I had saved a map to the ECU that did not have auto tune unlocked. Once I had re-entered my code and saved the map BINGO autotune is working again.
Thanks for the help Phil.
Old 09-29-2004, 09:25 AM   #6
Element Tuning
Member#: 54918
673 WHP Element
Veck,
No problem, I'm glad it was something simple.
Thanks,
Phil
Old 09-29-2004, 11:54 AM   #7
WhiteKnight
Member#: 56133
2004 Euro spec Sti
Black - Rotated gt3037s
Does it really work ? I mean how is the car with the auto-tune feature enabled ?
WhiteKnight is offline   Reply With Quote
Old 09-29-2004, 08:35 PM   #8
Veck
Member#: 15661
Auto tuning works great. A few pulls and the maps really close to the target AFR.
I'm still not tuning for real power yet, just getting the map close and focusing on driveability. I'm very pleased so far. I've been too busy learning all the software and tweaking stuff to post any results yet. This stuff is fun.
Hydra auto tune...how much can it compensate? theotherguy Other Engine Management 12 08-03-2010 06:40 PM
Few tuning questions cabikejumper Newbies & FAQs 54 06-05-2010 01:22 PM
Auto tune question majunche66 Other Engine Management 5 07-28-2007 01:34 AM
fs sfl 05 sti Hydra ems w/wideband o2 for auto tune pbevo12 Engine/Power/Exhaust 14 04-20-2007 10:20 PM
Hydra EMS v. 2.17 w/ Wideband & auto tune Scissors Private 'For Sale' Classifieds 12 04-27-2006 04:22 PM
