South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 09-28-2004, 11:06 AM   #1
TreyS
Member#: 42478
2004 WRX STi
White/Gold
Default What is the going rate for a 15k service checkup?
I'm due for a service visit at the dealer and was wondering what I should expect to pay. I just did an oil change this past weekend and brake pads so I'm good there.
Thanks!!
Trey
TreyS is offline   Reply With Quote
Old 09-28-2004, 11:33 AM   #2
Rebellion
Member#: 8069
2016 Fiesta ST
Kona Blue
I think it's a little over $100. If you've already done your oil, then 90% of the 15k is done. All it is is oil, oil filter, air filter, and inspect everything.
Rebellion is offline   Reply With Quote
Old 09-28-2004, 02:25 PM   #3
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 XV, '99 RS
$199.00 here...includes Parts & Labor for the following:
Oil & Filter Service
Battery Service
Rotate Tires
ECU Diagnoisis
Replace Brake Fluid
Replace Transmisson Fluid
Replace Differential Fluid
Set tire pressure
Lube body hinges
Inspection of steering, suspension, brake linings, fuel system, axles, parking brake, air filter, windsheild wipers, lights, horn, doors & locks, belts & hoses & tire condition.
Opie is offline   Reply With Quote
Old 09-28-2004, 03:14 PM   #4
mx_9
Member#: 36138
2015 2015 Focus ST
Magnetic Metallic
Battery Service
Rotate Tires
ECU Diagnoisis
Replace Brake Fluid
Set tire pressure
Lube body hinges
Glad you provided that info...my 15k service will be in about two months and if they do the brake fluid check I need to bring my Castrol SRF...
mx_9 is offline   Reply With Quote
Old 09-28-2004, 03:19 PM   #5
Rebellion
Member#: 8069
2016 Fiesta ST
Kona Blue
odd... the service guide says only to check BF,TF, DF at 15k.
15000 mile service
Inspect Steering and suspension
Inspect Clutch operation
Perform Inspect brake lines and check operation of parking and service brake system
Inspect Disc brake pads and discs, front and rear axle boots and axle shaft joint portions
Replace Engine oil filter
Replace Engine oil
Old 09-28-2004, 03:47 PM   #6
crazyhorse
Member#: 19502
2010 Impreza with no
scoop. =(
Opie is smoking crack.. he just described the 30k service.
crazyhorse is offline   Reply With Quote
Old 09-28-2004, 03:49 PM   #7
Longfury
Member#: 36047
2013 BRZ
Galaxy Blue
Thats what i was thinking too
Atleast i am smarter than i look
Longfury is offline   Reply With Quote
Old 09-28-2004, 03:52 PM   #8
TreyS
Member#: 42478
2004 WRX STi
White/Gold
All I need is this:
Set tire pressure
Lube body hinges
Everything else has already been done by me.
Wonder what that'll cost?
Old 09-28-2004, 03:56 PM   #9
crazyhorse
Member#: 19502
scoop. =(
Usually a lot more than $199 I think the 30k service runs around 400-700. I'm not 100% sure because I've always done my own fluid changes. (Wow doesn't that sound bad... ) If you're only at 30k you don't need to have the fluids changed unless you're going to an aftermarket fluid.
Old 09-28-2004, 04:15 PM   #10
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
Nope, that's our 15k (Subaru's recomendations for coastal residents). Our 30k adds coolant flush & fill, fuel filter, air filter, PCV.
Runs $329.00
Old 09-28-2004, 04:26 PM   #11
Blindeye_03
Member#: 4418
2016 Focus ST
Tim is always smoking crack.. he just described the 30k service.
fixed
Blindeye_03 is offline   Reply With Quote
Old 09-28-2004, 05:22 PM   #12
Fernely
Member#: 6824
2008 QSM Leg. spec B
Pastelito Racing/ SFSOC
Nope, that's our 15k (Subaru's recomendations for hurricane residents). Our 30k adds coolant flush & fill, fuel filter, air filter, PCV and 3 sheets of 5/8" plywood!
Runs $329.00
Fixed it for you Opie.
Fernely is offline   Reply With Quote
Old 09-28-2004, 06:28 PM   #13
Blindeye_03
Member#: 4418
2016 Focus ST
hahaaha
Old 09-28-2004, 06:41 PM   #14
Porter
Member#: 486
2004 Forester XT
bug spattered
Runs $329.00
WOW.
I mean, WOW. Awesome.
At SoG that was like $500.... $700 if you got all the "premium" BG flushes and whatnot.
Porter is offline   Reply With Quote
Old 09-28-2004, 06:41 PM   #15
TreyS
Member#: 42478
2004 WRX STi
White/Gold
I wouldn't take it in at all but when you need some warranty work and they pull up your name and see you don't do regular service or oil changes, at the dealer, things tend to turn for the worst really quick.
Old 09-28-2004, 09:14 PM   #16
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
Your going to the wrong dealer then...
Old 09-28-2004, 09:16 PM   #17
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
Originally Posted by Porter
WOW.
Geez, ours is still under $500 if you add all the BG flushes and stuff!
Old 09-28-2004, 10:43 PM   #18
MidnightRallySTi
Member#: 50242
2008 Infiniti
G37S
this reminds me i need to get this done asap...probably need some new brake pads after running teh dragon a couple weeks ago
MidnightRallySTi is offline   Reply With Quote
Old 09-28-2004, 11:14 PM   #19
Rebellion
Member#: 8069
2016 Fiesta ST
Kona Blue
Prestige was around $330 for the 30k. I took the OBS there for it's a couple years ago. I just did most of the 30k stuff myself on my car though. (still need to finish a couple things, ie: tranny/diff fluid and PCV).
Opie... what exactly does "battery service" consist of?
Old 09-29-2004, 12:17 AM   #20
TreyS
Member#: 42478
2004 WRX STi
White/Gold
WOW.
That says it all right there.
Old 09-29-2004, 01:11 AM   #21
firedust
Member#: 38795
2003 WRX
Sonic Yellow
dude...SoG wanted 215 bucks for a 15k...i got an oil change and called it a day. checked my fluids on my own, and my brakes...and thats it. i was thinking about the tranny fluid..then a little birdie told me teh portAr laughs at people getting tranny fluid changes early and wasting money. so now im at 17k..no services otherwise.
firedust is offline   Reply With Quote
Old 09-29-2004, 11:51 AM   #22
bailey454
Member#: 36474
what's a good price for just a coolant flush and fill? i know there's supposedly a magical mystery subaru coolant that is made of unicorns by gnomes or something like that and my car will rip a hole in the fabric of space-time if i don't have a dealer do it. plus, i don't feel like messing with all that leftover coolant.
edit: that'd be for my 30k in a little while.
bailey454 is offline   Reply With Quote
Old 09-29-2004, 11:53 AM   #23
Porter
Member#: 486
2004 Forester XT
bug spattered
It's all polypropylene glycol.
Use distilled water for best results, and a little water wetter.
Old 09-29-2004, 09:59 PM   #24
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
Cleaning the terminals, checking the water in the battery (topping off if needed) and load testing.
what is the going rate for 2.5 GT wheels/tires? Benjamin Tang Legacy Forum 14 01-19-2003 11:53 AM
What is the going rate for 2003 Foresters these days? twiztid Forester Forum 9 11-13-2002 08:53 PM
what is the going rate for a consultant? (IT) Fish Off-Topic 23 11-06-2002 05:59 PM
what is the going rate for wrx wheels/tires? Benjamin Tang Vancouver Impreza Club Forum -- VIC 23 06-10-2002 01:37 AM
What is the going rate for TEIN front and rear pillow ball mounts? Robmat Brakes, Steering & Suspension 0 07-19-2001 06:59 PM
