Old 09-28-2004, 11:05 AM   #1
suby53
Member#: 59648
97' Legacy Outback
Question Head swap?
I have a 1995 impreza 1.8 with a T3 turbo I have recently installed. I have been running 9 psi for about two months and show no drop in compression and no knocking. I know the 1.8 isn't a power monster but I am wondering if some 90'-94' ej22 na heads or cams will fit in my motor to squeeze out a little more power from higher flow or if these heads/cams are the same as the stock 1.8 heads/cams.
suby53 is offline   Reply With Quote
Old 09-28-2004, 03:02 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
same...
Old 09-28-2004, 05:29 PM   #3
chip4761
Member#: 55867
2005 Saabaru
AS
Wouldn't you get lower compression? Good for boost, I guess. I really don't know one way or the other.
chip4761 is offline   Reply With Quote
2.5 DOHC heads to 2.2 SOHC heads swap questions. sick1.8t Subaru Conversions 10 05-02-2006 03:45 AM
lets talk head swapping. jasona Normally Aspirated Powertrain 2 08-31-2002 12:42 AM
STi cylinder head swap. KillerRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-14-2002 12:06 PM
head swapping Tensecgn Normally Aspirated Powertrain 4 12-01-2000 07:02 PM
Legacy Turbo head swap to a N/A 2.2L (idea's)? MPREZYA Technical Forum Archive 6 05-19-2000 06:22 AM
