Old 09-28-2004, 02:33 PM   #1
rsti02
Member#: 71329
2002 rs
Default Octane ?
Will it hurt my Suby 02' 2.5rs if i run 87 octane on a trip? I currently run 92 octane while in city. Any help will be appreciated
rsti02 is offline   Reply With Quote
Old 09-28-2004, 02:34 PM   #2
rsti02
Member#: 71329
2002 rs
O yea it will be a trip from omaha ne to denver co
Old 09-28-2004, 02:36 PM   #3
soso3
Member#: 36794
89 T I T A N
Why would it hurt? Isn't the minimum recommend octane 87?
soso3 is offline   Reply With Quote
Old 09-28-2004, 02:36 PM   #4
dmatthew
Member#: 69247
2005 2.5 RS Wagon
Crystal Gray Metallic
Isn't the recommended octane 87 for our RS'? I was told that since our cars are non-turbo ones you don't really need to run the highest octane.
The 87 is from the manual I believe. Then again if you did any mods to your car it might be a different case!
dmatthew is offline   Reply With Quote
Old 09-28-2004, 05:35 PM   #5
bartx
Member#: 51852
04 2.5RS
YATCH
unless your subie is heavly modded, you should be fine. i have never had a problem switching to ****ty gas when needed, but my friend(who has a stage 4+ wrx) does. he usally puts 93 in it, and on the way from stl to denver in KS we can only find 91. when that is the case the damn thing will not idel. but my 04 rs. with an CAI and Cat back donesn't even get nock. i think you should be fine, good luck.
bart
bartx is offline   Reply With Quote
Old 09-28-2004, 05:39 PM   #6
JewPac42
Member#: 23260
Patr ick Willis
for Rookie of the year
I wouldnt run 92 ever. The car is supposed to be run on 87, and you will get the most from your car by running it on 87. By putting in 92 you are wasting money as well as hurting your performance. Unless you are turbo'd or tuned for a different octane rating you should always be using 87.
JewPac42 is offline   Reply With Quote
Old 09-28-2004, 05:41 PM   #7
Yotsuya
Member#: 935
Jack Soo Fan Club
I ran 87 octane in my RS all it's life, except on trips to Colorado. Nebraska only goes down to 89. Colorado has 85, and my parents use that in their Forester with no problem, but the last time I put it in my car my front O2 sensor coincidentally failed. I can't prove it had anything to do with it, but wherever I go, I try to stick to the same gas.
You can probably do Omaha to Denver in a day; just watch for cops on I76 in CO. I've never seen so much as a speed trap in Neb.
And there's no reason to be giving a normal RS 92 octane. Run it till it's on E, put in 87 (or nine, or whatever you get out there) and reset the ECU just to keep it from having issues.
Yotsuya is offline   Reply With Quote
Old 09-28-2004, 06:22 PM   #8
JewPac42
Member#: 23260
Patr ick Willis
You can crusie through Nebraska at ~90, I cruised down 76 at that speed too, but I had a radar detector, although I didnt even pick up a single cop.
Old 09-28-2004, 06:55 PM   #9
rsti02
Member#: 71329
2002 rs
and why would 92 octane make it necessary to reset the ecu? i got 2.5" exhaust, cobb cai, cobb headers, street cams, and lightweight crank pulley, when run on 92 octane, my suby sounds very happy
Old 09-29-2004, 05:53 PM   #10
JewPac42
Member#: 23260
Patr ick Willis
Not reset, but reflash with a tune. The car is designed to run on 87, it runs better on 87 and you are just wasting your money on 92. Ive been running 87 in my car ever since it was new and I have no problems at all. If you want to continue wasting your money go for it.
No MTBE 91 octane vs. MTBE 91 octane wayoutwest Southern California Impreza Club Forum -- SCIC 40 08-31-2002 05:40 AM
Turboxs stage 2 power, 14 psi vs. 17 psi, 91 octane 93 octane Fubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-06-2002 11:26 AM
Unichip Octane Requirements/Octane Boosters? 2002wrx1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 08-18-2001 12:42 PM
