Old 09-28-2004, 07:27 PM   #1
RUN
Member#: 68048
1998 Impreza Outback
white with dents
Default 2 bad crank seals in 2 weeks?
1998 2.2 16v impreza
100k miles
just bought the car.
car smoked like mad
Local mechanic changed the crank seal and both valve cover gaskets
Crank seal started leaking again after 25 miles of hway driving
Changed it again
This time it lasted 2 days. It leaks much less but it shouldn't leak at all!
What is this mechanic doing wrong?
Thanks
RUN is offline   Reply With Quote
Old 09-28-2004, 07:46 PM   #2
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Is the seal bore damaged? Did the mechanic drive the seal in correctly the first time, or did he pry it out, thus, damaging the spring, and then tried reinstalling it again? Are these Subaru crank seals or aftermarket?
-Charles-
ImprezaVA is offline   Reply With Quote
Old 09-28-2004, 09:24 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
There could be excessive pressure in the crankcase, from blowby caused by worn rings and/or a stuck PCV valve.
Old 09-29-2004, 08:47 AM   #4
OBS Fan
Member#: 9751
Run-
Can you actually see drops of oil at the front of the engine or are you going by smell (burning oil)? After repairing my front crank seal (97 EJ22, 115K) I could smell burning oil for a few days after the leak was repaired. There was a fair amount of oily buildup on and around the exhaust Y pipe, which took a few days to stop stinkin'.
-OBS Fan
OBS Fan is offline   Reply With Quote
Old 09-29-2004, 09:58 AM   #5
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
maybe he didn't put them in right?
JonofScio is offline   Reply With Quote
Old 09-29-2004, 03:22 PM   #6
RUN
Member#: 68048
white with dents
-Definitely have oil drops on the bottom of the timing belt cover
-I wasn't there to inspect the bore, but i will be next time
-Supposed to be Subaru seals, but will make sure
-I hope the rings arent worn with only 100k, but i will do a leak down test if all else fails
-PCV valve:is there an easy way to check if its working right?
THanks for all the quick feedback !
Old 09-29-2004, 05:21 PM   #7
chip4761
Member#: 55867
2005 Saabaru
AS
For the PCV, just pull the vacuum hose off of it, then stick your finger over it and give the throttle blip. It will suck on your finger. On mine, I didn't even need to blip the throttle, it just sucked all by itself.
chip4761 is offline   Reply With Quote
Old 09-29-2004, 06:49 PM   #8
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
^What he said, or take it out and shake it, if it rattles, it's good. Did you buy the car off an individual or a dealer? What I'm getting at, is there anyway you can find out what has been done to the car maintenance wise? When I bought my car, used, I replaced these things because I didn't know what had been done:
1. Air filter (easy to check, if needed) $10-15
2. Fuel filter $20
3. Spark plugs $8
4. Rear diff. oil $3 (Valvoline Durablend 80w90)
5. Front diff. oil $13(Valvoline Durablend 80w90)
6. Tranny oil or fluid depending on manual or Auto.
7. PCV $9
I don't mean to be spending money for you, but with 100k on the odometer why not change the timing belt and water pump too since your already in there. For under $80 you do all the things mentioned above and not have to worry about it. Of course, I don't know how deep your wallet is or what your mechanical abilities are, but these would be safe measures.
-Charles-
Old 10-02-2004, 02:51 PM   #9
RUN
Member#: 68048
white with dents
Thanks I'll definitely do all those things, the timing belt has just been replaced. I didn't think to do the water pump at the same time.
Since the last time the seal was replaced it only leaks noticeably when i drive like a maniac. I'll post an update If i ever figure out why.
Old 10-02-2004, 03:37 PM   #10
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Run, this same thing happen to my RS. 133K miles
Oil pump, you need to replace the oil pump. The tolerences between the impeller and the house of the pump get too big so you start to get too much internal pressure in the pump. The oil pump is driven by the crank. The seal you replaced in on the pump. The blow back hole behind the seal is only so big and when flow account is exceeded that the blow can handle. It will popthe seal. I'll get pic on my old pump.
Patrick L is offline   Reply With Quote
Old 10-02-2004, 04:01 PM   #11
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
here is the pic of my old oil pump.
FYI, the vertical tubes on the left is the pressure side and the right side is the vaccum side. If you wanted to. You can take the plug on the left and replace it with a plug for a pressure sender gallery plug.
http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg
If you wanted too, too prevent this in the future. You can bore out the blow back hole with a drill bit and make the hole bigger.
Old 10-05-2004, 03:57 PM   #12
RUN
Member#: 68048
white with dents
THanks TD
now whats a good subaru mechanics manual to get
Old 10-05-2004, 04:41 PM   #13
linsavy
Member#: 11620
1997 GF4-STiV3 clone
linsavy is offline   Reply With Quote
3 bad wheel bearings in 2 months... txl146 Brakes, Steering & Suspension 11 01-16-2010 09:36 PM
VF39 BAD SEALS? What are the reccuring effects of bad seals in a turbo? Drewbaru04 North West Impreza Club Forum -- NWIC 2 05-16-2009 11:50 PM
How bad is a leaky front crank seal or oil pump? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-03-2007 11:24 PM
Bad window seal in freezing weather??? e8w117 Mid West Subaru Owners Club Forum -- MWSOC 6 11-25-2005 03:15 PM
JDM 2.0 wrx turbo in 2.5 rs? tabolau Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-17-2001 12:56 AM
