Old 09-29-2004, 04:34 PM   #1
V6
Member#: 2703
Y2K GC8
Silver forever
Default Anyone knows how to adjust the headlight of MY98-01 to aim it more downwards?
Hello,
So that the headlight will light up more on the road not on the car in front of me?
I tried the screw on the corners of the headlight as shown in Scoobymods.com but seems like that screw is to adjust the left / right of the headlight. Not the up / down.
So anyone knows?
Thanks
V6 is offline   Reply With Quote
Old 10-23-2004, 02:32 AM   #2
V6
Member#: 2703
Y2K GC8
Silver forever
bump
Old 10-23-2004, 07:49 AM   #3
doomonu
Member#: 70155
1999 Legacy 2.5 GT
Brilliant Silver Metallic
if it's set up how i believe it is there should be two bolts on the top of the headlight holding it on. loosen those bolts and pull the top of it towards you. retighten the bolts. if it doesn't look right repeat until it does
doomonu is offline   Reply With Quote
Old 10-23-2004, 08:40 AM   #4
brunetmj
Member#: 8023
2004 2.5 RS
Have you changed bulbs lately? It is possible to incorrectly seat a bulb in the lamp. If this where the case the high beam might be right on with the low beam being off (or vise versa). If both are off then the lamp needs adjusting. Just a possibility..
brunetmj is offline   Reply With Quote
Old 10-24-2004, 07:01 AM   #5
Scooby Blue
Member#: 12112
MY00 RS
The left/right adjustment is the on inboard of the headlight, closer to the middle. It is acessed by removing metal cover.
The up/down adjustment is located on the outside of the headlight relative to the car, or behind the corner lense. Standing over the corner of the car, look down at the back where the corner lense and headlight meet, you will see a philips head bolt located in a (white?) plastic part. This controls the up/down. You need a long philips screwsriver to get to this.
Scooby Blue is offline   Reply With Quote
how to adjust the sensitivity of the Stock Subaru alarm? SubyWRXSti Car Audio, Video & Security 2 11-14-2007 05:44 PM
Anyone knows how much is the 00 or 01 SOHC 2.5RS enigine V6 Canada Region Forum 2 08-17-2006 10:07 PM
How to adjust the sensitivity of the shock sensor? cinemaster Car Audio, Video & Security 7 04-19-2005 02:30 PM
How to adjust the headlights on an STi WE R ND Interior & Exterior Modification 5 03-20-2004 04:09 PM
Anyone know how I can get ahold of Nick? E5performance General Community 1 07-23-2002 10:51 AM
Message Board Statistics All times are GMT -4. The time now is 12:10 AM.
