Welcome to the North American Subaru Impreza Owners Club Tuesday September 16, 2014
Old 09-29-2004, 05:16 PM   #1
JayD707
Member#: 51018
2005 Legacy
Default Rear diff oil change
i have a couple quick questions..i have searched and i cant find anything relevant..so help would be appreciated. my questions are..when changing the rear diff. oil in the STi i noticed theres a sensor..is there any certain way to get it out, or not to get it out..?? after being taken out, once its put back in is there a need to reset anything? and how much quarts does the STi diff. take? how much does the tranny take?? and finally when jacking the rear of the car up, do i need to jack the front up or can the front wheels rest on the ground? thank you for the help! jared
JayD707 is offline   Reply With Quote
Old 09-29-2004, 08:38 PM   #2
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
I making assumptions here so bear with me...
Put the car on a lift or jackstands for best oil flow.
Remove the fill (top) bolt using a 1/2" breaker bar to remove.
It will probably be on there gorilla tight, so prepare for battle.
Once out, remove the drain (lower) bolt.
Once empty, reinstall the drain (lower) bolt.
Fill the top hole with gear oil until it spills out. ~.8qt is for WRX & should be the same for you, but double check me.
Reinstall fill bolt.
Old 09-29-2004, 09:10 PM   #3
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
the key is to remove the top (fill) plug 1st because wouldn't it suck if you got the bottom off and couldn't fill it
Quack is offline   Reply With Quote
Old 09-29-2004, 10:42 PM   #4
Lachlan
Member#: 19470
1981 Brat GL
Step 1: Take it to Jiffy Lube
Step 2: Watch their shotty TV while "Jon" takes care of it
But seriously, probably do what the other guys said. I just got tired of doing anything oil-related a long time ago.
Lachlan is offline   Reply With Quote
Old 09-30-2004, 02:45 PM   #5
JayD707
Member#: 51018
2005 Legacy
thanks for the help guys..i appreciate it, i dont really trust those guys at jiffy lube or the dealership..i have heard som pretty disturbing stories. i was just worried about the sensor, so i guess theres nothing to worry about. alright thasnks
Old 09-30-2004, 02:57 PM   #6
Calamity Jesus
Member#: 44501
1984 "Skeletor from
"He-Man"
If you're ever in doubt about this, just disconnect the battery before beginning work on the car. If the ECU isn't getting any power, it'll never know that the sensor was removed and replaced... of course, the ECU will be reset in the process, too.
rear diff oil change memphisjames Service & Maintenance 29 07-16-2004 02:46 AM
rear diff oil change impressions voam Service & Maintenance 20 04-12-2004 09:20 PM
rear diff oil change shortfuseWRX Service & Maintenance 1 02-15-2004 03:54 PM
rear diff oil change? rexmobbin' Service & Maintenance 20 03-30-2003 01:05 AM
Tranny and Rear Diff oil changes help WRXThis Transmission (AT/MT) & Driveline 5 04-30-2002 06:25 PM
