Old 09-29-2004, 05:32 PM   #1
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
Default low on coolant at 20k miles... is this normal?
i have to add some coolant to my resivior tank, it's exactly at the "low" line... it says replace the coolant at 30k and i'm only at 20k miles, do i have a leak or is this (somewhat) normal?
Handsdown is offline   Reply With Quote
Old 09-29-2004, 05:33 PM   #2
iamrazor
Member#: 52324
2011 SWP WRX LTD
1990 T30 miata
do you know where the level was to start at?
you could fill it and use that as a baseline and see what happens from there.
iamrazor is online now   Reply With Quote
Old 09-29-2004, 05:37 PM   #3
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
that's what i'll end up doing.
dinner first. then get coolant.
Old 09-29-2004, 07:53 PM   #4
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
My car has the same miles as yours (~20k). Several months ago, I noticed that the coolant reservoir level was a little low, so I added a bottle of Redline Water Wetter and it stayed at the new level for a long time.
It seems a little low on some days, but I'm convinced that there is just a lot of coolant circulating in the engine and that the level fluctuates on a daily basis.
Let me know if you hear anything about potential leaks, etc. I'm not worried, but you never know
DrBoy01 is offline   Reply With Quote
Old 09-29-2004, 08:36 PM   #5
jasona
Member#: 11786
02 TS
Black on White
They found a crack in my radiator at the dealership at about 20k. No idea what it was from, or that it was even there till they told me. Fixed under warranty.
jasona is offline   Reply With Quote
Old 09-29-2004, 08:58 PM   #6
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
I've worried about this as well. Try going for a drive and getting the engine nice and hot. If you check it then, I'll be it will be pretty close to the maximum fill line. Sometimes mine tends to dip just below the low line if the engine is cold.
whtlegacy is offline   Reply With Quote
Old 09-29-2004, 10:26 PM   #7
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Antifreeze naturally is burnt off in normal driving. Just the same way a new car consumes oil. I wouldn't be worried at all if I was a little low after 20k on the same antifreeze.
jamesfacts is offline   Reply With Quote
Just installed boost gauge, peaks at 12psi. Is this normal on a stock '02 WRX? AjntOrnj Factory 2.0L Turbo Powertrain 17 10-17-2009 12:04 PM
19k miles, low on coolant, oil, trouble? Jonny07subie Service & Maintenance 1 08-31-2008 06:27 AM
CPU usage hovering at around 50% - Is this normal? Whitford Off-Topic 44 01-02-2007 12:42 AM
Testdrive refused at Mazda dealer, is this normal? Len Off-Topic 50 07-25-2004 11:47 PM
Message Board Statistics All times are GMT -4. The time now is 09:06 PM.
