Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 09-29-2004, 06:01 PM   #1
mjalex007
Member#: 66022
2005 Baja Turbo
Default Installed a Unichip Today
I installed my Unichip this morning. It's been raining and there are spots with leaves on the road (I can't believe it's that time already) so I haven't had a chance to wring it out.
My initial impression is that the power is very linear. It comes on smooth and aggressively. Before the chip, I really felt the car kick me in the seat of the pants in second gear, more so than first, in fact. Now, first and second are the same--it pulls enough that you have to pay attention to keeping the wheels on the ground. The car also pulls harder in third gear. But like I said, that's about all I was able to discern on my 10 mile commute to work.
My chip was mapped for cat-back exhaust, short ram air intake, and uppipe (without cat). I also have a lighter crankshaft pulley and a manual boost controller on the car. I think the MBC has to come off--I have a querry into the people who did the mapping.
I bought the GP Moto short ram air intake on the recommendation of dealer (not the one I actually bought the Unichip from). Evidently, the chip is mapped for that intake. Previously, I had a K&N air filter in there.
You have two map options--one for regular and the other for premium gas. I threw a CEL on the regular gas map, which apparently happens in 30% of cars that are sensitive to detonation. Nothing seems amiss with the alternate map. In addition to a switch to choose between maps, there's a power-cut switch that is used to reset the ECU and to clear a CEL.
Installation takes about 30 minutes, give or take. You have to pull back part of the carpet on the passenger side and take of the ECU protective cover (four screws). Unplug four plugs from the ECU, plug those into the harness and plug the harness into the ECU. You also plug the harness into the Unichip along with a driver's module (the wires for the two switches also go into this module). Takes really it.
The kit comes with velcro strips to hold everything in place. I haven't buttoned up everything yet because I wanted to make sure all was copacetic.
So, I've got some more driving to do before I announce my verdict. The place where I bought the Unichip doesn't have a four-wheel Dyno, so getting it tuned there wasn't an option. I'm not sure what's available in my area just yet.
On the way home tonight I had a chance to floor it in a couple of short straights. The thing is a rocket! I have no idea what sort of HP I'm putting down but my set up is almost identical to Vishnu's Stage 3 (I have a cat-back, not a turboback) and they say it puts a WRX at 300-310 HP. Who knows? It's just fun to drive. I can't wait to really try it out this weekend.
mjalex007 is offline   Reply With Quote
Old 09-29-2004, 06:29 PM   #2
Chris N
Member#: 5322
07im +07Leg+00Forest
Scooby wrench turner
Here in Portland there is an AWD dyno. I beleive its called F1 Performance, Forest Ave. I'll try to get you a link if I can find it. The guys there are very familiar with turbo set-ups...if you ever have the urge to tune in Portland.
Questions for you.
Do you feel any abnormalities after the Unichip install? Anything undesireable?
Who did you purchase from? Satisfied with them? Price range?
Why did you use a unichip and MBC? I thought it as an "either-or" situation.
Thanks.
Chris N is offline   Reply With Quote
Old 09-29-2004, 07:34 PM   #3
mjalex007
Member#: 66022
2005 Baja Turbo
--I haven't noticed an abnormalities just yet. I've got my fingers crossed.
--I bought it from a company called Fastline Motorsports in Connecticut, which was recommended to me by Unicip USA because they are closest to me. I am extremely satisfied with them as far as their staying in touch with me and answering my questions. Their price was waaay lower than any I've seen--$775. However, the mapping was done by iPD on the West Coast and the unit was drop shipped from there.
--I've read that it's an either/or proposition with the chip and MBC. I put the question to iPD today whether I should take it off but haven't heard from them. Still, taking it off is what I'm going to do tomorrow. I have a turbo gauge and I have not seen any change in boost but I suspect that is a result of the manual having fixed setting. It was on the car before I installed the chip, by the way. I have it set at about 13psi, compared to the 11.6psi stock. I'm curious about what the effect taking it off will be.
Old 10-02-2004, 10:28 AM   #4
mjalex007
Member#: 66022
2005 Baja Turbo
I never heard back from iPD, which probably doesn't matter anyway. I took the MBC off yesterday. I notice that boost is about the same of may a bit higher--still about 13 psi.
Still no abnormalities. In fact, the car seems to be running great. I'm definitely going to need new tires!
I buttoned up everything. The chip kit comes with spacers to raise the foot rest (the plate the covers the ECU). They're needed because the kit harness sits on top of the ECU and is held in place with Velcro. The result is that you lose about an inch of leg room on the passenger side.
Old 10-09-2004, 08:34 AM   #5
Chris N
Member#: 5322
Heres the link to the guys in Portand with the 4 wheel dyno, incase you wanna know what she does Now
http://www.f1dyno.com/index.html
Old 10-09-2004, 08:54 AM   #6
mjalex007
Member#: 66022
2005 Baja Turbo
I'm going to have to make that drive one of these days because I want to know not only what the car does now, but also because I'm sure that fine tuning would make it even better.
Right now, the car flies.
By the way, re: the question about the MBC, which I took off. I noticed Xcceleration's power package includes the Unichip, MBC and fuel cut defender. When I asked them about the MBC, they replied they found it necessary to maintain relaible boost. Judging from my boost gauge, I don't see any difference with or without it. I'd much rather go without it for the simple reason that it's probably safer to rely on the ECU/chip than the MBC.
Old 10-24-2004, 05:52 PM   #7
kennyusmc1
Member#: 71221
please update us on how that unichip is working for you ...
thanks
ken
kennyusmc1 is offline   Reply With Quote
Old 10-24-2004, 06:45 PM   #8
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
Here is a shorter drive for ya..
XX TUNING LLC
58a Maple Street
Wethersfield CT
06109
they have a awd dyno and i'm thinking of taking my stock n/a there to see what she puts out before hitting the mods..
http://www.xxtuning.com/
holland_patrick is offline   Reply With Quote
Old 10-25-2004, 08:50 AM   #9
mjalex007
Member#: 66022
2005 Baja Turbo
The Unichip has been working out great. It's been maybe 1500 miles, including a 400 mile trip to NYC this past weekend. I've only thrown one CEL so far, and that cleared by switching the Unichip off and then back on (it also resets the ECU). For those who don't know, the Unichip comes with two switches: one to change between two maps, and the other to turn it off.
In addition to the Unichip, I put in a catless uppipe, cat-back exhaust, short air intake, and lighter crank pulley. I also installed a manual boost controller, then took it off when I got the Unichip, and then put it back on. I was told the MBC would allow the car to hold boost better but I'm not sure about that. Because I've only got it set at about 12 +/- psi, I don't think it will do any harm.
I'm anxious to put the car on a dyno for proper tuning and will do that as soon as I can spare time to make the trip to either Connecticut or Maine (don't know of anyone in Massachusetts).
Some other mods I've done are to replace the shifter bushings and tranny mounts and some hoses.
I bought a Spearco intercooler from someone on i-Club and I hope to get that this week and install it. I also will have some 17-inch wheels installed this week as soon as they arrive.
Last thing on the list for the foreseeable future is a rear sway bar. Anything after that and my wife will make me sleep in the garage (with the motorcycle that I also keep throwing money at).
Old 10-25-2004, 08:59 AM   #10
KC
Member#: 442
2013 Crosstrek XV
00 Honda S2000
KTR in Ayer Ma.
--kC
KC is offline   Reply With Quote
Old 11-06-2004, 04:45 PM   #11
mjalex007
Member#: 66022
2005 Baja Turbo
Originally Posted by KC
KTR in Ayer Ma.
--kC
I sent them an e-mail almost two weeks ago with a few questions (like, how far in advance do I need to make an appointment, and I never heard from them).
Old 11-06-2004, 09:20 PM   #12
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
IPD has been around a long time doing Volvo peformance modifications. They may not push the envelope but you will get reliability and longevity. They have excellent customer service.
They recently branched out into Subaru.
http://www.ipdusa.com/
02_Forester is offline   Reply With Quote
Old 11-08-2004, 08:21 PM   #13
SLC
Member#: 499
OK - I just spoke with Scott B at KTR. Please send email again. Their server went down last week and he lost 2 days of emails
d
SLC is offline   Reply With Quote
Old 02-19-2005, 10:44 PM   #14
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
mjalex007, How has the Unichip been holding up?
Old 02-20-2005, 07:37 AM   #15
mjalex007
Member#: 66022
2005 Baja Turbo
It's been great... No problems whatsoever. I've been meaning to run the car without the UniChip turned on to see what it feels like with, and without it, but I haven't had time to do a proper "before" and "after" comparison. I forget what the car feels like without it; and I've done so many other mods that the memory blurs...
The UniChip has two switches, one to turn it on and off, and the other to change the map. Turning it off, letting the car sit for 10 minutes, and then turning it back on, resets the ECU. It will also clear a CEL like I had to do yesterday when I exceeded 13-ish PSI. The MBC is set a bit too high but it's cold, I'm lazy, I'm busy, and it's cold., so I haven't tinkered with it.
The other switch allows you--supposedly--to run with regular octane gas, but I get a CEL if I try it The instructions say that 30% of cars won't be able to use the second map.
My car is scary fast, that much I know. It's ridicuous, actually. Even with performance tires, the thing literally hops when I accelerate too hard. It slingshots through every gear. I have yet to put the car on a dyno, however, so I can't tell you what sort of HP it puts out but with the mods I've done, it's easily in the neighborhood of 300 HP. Over the summer, I'll put in a new header and a bigger intercooler and then call it quites. By then, I hope to be in the 320-340HP range.
My wife calls the car the Darth Vader because you can really hear the short air intake suck air.
Short story is that based on my experience, if you do the sort of mods that most people might consider (catless up/downpipe, cat/turbo back exhaust, air intake, etc) you need chip management to get the most bang for your mods. As you probably already know, there aren't a lot of options. I was able to get my UniChip mapped by iPD specifically for my mods, so I'm happy about that.
I found a dealer in Connecticut (Fast Line Somethingorother) who sold me the UniChip for $750 (Xcceleration, Rallitek and others want something like $1200-$1500) and they sent it to iPD to do the mapping.
Old 02-20-2005, 10:31 AM   #16
02 wrx sleeper
Member#: 65999
2006 WRX Limited
wow, that's great news, congrats on how well things are going. i have a few questions will the chip work on a auto turbo? also what is a safe amount of boost to run on our engines without getting into any kind of trouble? thanks.
02 wrx sleeper is offline   Reply With Quote
Old 02-20-2005, 03:01 PM   #17
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
Glad to hear all is going well. I may end up with the UniChip.
I'll probably stick with a cat. for emissions testing here in VA. What are your current list of mods?
Old 02-21-2005, 07:17 AM   #18
mjalex007
Member#: 66022
2005 Baja Turbo
Yes, it will work on your turbo. I've found that 13 PSI is about max for my car. Each time I've exceeded that, the engine shut down momentarily and I've thrown a CEL.
Old 02-21-2005, 07:27 AM   #19
mjalex007
Member#: 66022
2005 Baja Turbo
Main ones are catless uppipe, catback exhaust, ram air intake, lighter crank pulley, MBC, and ECU management. Also put 17-inch wheels on. I've changed hoses, transmission mount and some other things as well.
Old 02-21-2005, 05:31 PM   #20
02 wrx sleeper
Member#: 65999
2006 WRX Limited
as far as emissions goes if you have a catless up pipe but keep your down pipe and mid catted you'll still have 2 of your 3 cats. o would like to think that you would pas with that set up. a lot of wrx members do have that setup or they go completly catless
Old 02-21-2005, 05:38 PM   #21
02 wrx sleeper
Member#: 65999
2006 WRX Limited
Do you run a manual boost controller or an electronic. i would imagine it would be hard to set a manual at 13lbs with out going over considering the stock baja puts out 11.6lbs.
on a side note...... i'm not sure if i ever asked you yet but have you ran it down the 1/4 mile yet? what does a stock baja turbo auto and or 5 speed run if you know?
Old 02-22-2005, 12:34 PM   #22
mjalex007
Member#: 66022
2005 Baja Turbo
Mine is a manual. Setting it with a boost gauge involves a small amount of trial and error and a wee bit of guesstimation...
No quarter-mile runs. That's what I got a motorcycle for.
Instaled my hitch today too... Aaron'z 2.5RS Interior & Exterior Modification 12 09-07-2004 11:31 PM
Apexi AVCR install w/unichip rjrutzky Engine Management & Tuning 7 03-28-2004 03:02 PM
Help! How did you guys install vishnu unichip with PNP adapter? WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-15-2003 06:29 AM
Installed Karboy Bushings Today Shinji N Southern California Impreza Club Forum -- SCIC 0 05-16-2001 08:30 PM
Blower installation day is today! rao Mid West Subaru Owners Club Forum -- MWSOC 9 05-13-2000 12:06 AM
