Old 09-29-2004, 06:07 PM   #1
jsalicru
Member#: 58031
Default Some shavings in the oil filter...
So yesterday I did my oil change on the car... was eager to do it as it has been 6-7k since the oil change.
Now, I dont really run the car hard or anything... most of those miles are highway cruising to work and back.
My current motor mod is only a TXS Stealthback.
When I drained the oil from the filter I noticed something alarming. Now I have to say that I only noticed this because I put the flash light up to it.. but otherwise, Im not so sure i would have noticed it.
There were small, powder like metal shavings running out with the oil(some a little bigger than powder, but not by much). These were all silver in color.
Im a little concerned since the car is taken care of properly (always checking my oil... etc). I only run it hard mostly merging on the freeway, the occasional run here and there and 1 autocross event since I purchased the car at 10k miles. It currently has 21k.
Anyways, should I be worried? Should I just ignore this? Any input is appreciated.
jsalicru is offline   Reply With Quote
Old 09-29-2004, 06:12 PM   #2
kedrin
Member#: 48380
i would have no idea what it is without seeing it, but i believe there are places you can take it to have it tested.
kedrin is offline   Reply With Quote
Old 09-29-2004, 08:08 PM   #3
Dale_K
Member#: 42342
Did you ever use additives, like Slick50 or stuff with teflon?
Dale_K is offline   Reply With Quote
Old 09-29-2004, 08:14 PM   #4
jsalicru
Member#: 58031
hell no.. haha, the only additive I believe in is a fresh change with Mobil 1
Old 09-29-2004, 08:33 PM   #5
f4phantomii
Member#: 58504
2004 STi w/o wing
Aspen White / Silver
So has anyone got links to some data, evidence, or studies that Slick50 *doesn't* work?
I'm more familiar with it when it was strictly more of an aviation product for small aircraft. Actually know a guy that lost all oil pressure in flight, and was still able to fly an hour further to a safe landing. They tore down the engine and it had no damage. He was a Slick50 user.
Maybe the automotive product is different.
I see people badmouthing it all the time. I'd just be curious to see some information to support that.
-Michael
f4phantomii is offline   Reply With Quote
Old 09-29-2004, 09:14 PM   #6
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Old 09-29-2004, 09:27 PM   #7
_Ai_
Member#: 70714
2005 STi
Crystal Grey
While I wouldn't be terribly alarmed, I also wouldn't hesitate to spend a few dollars on an actual oil analysis. Myself & a few customers have had good luck with blackstone labs. Additionally, many large cities have Caterpillar, Cummins, etc. service centers with in-house labs and are sometimes willing to help out.
_Ai_ is offline   Reply With Quote
Old 09-29-2004, 11:34 PM   #8
singletrack
Member#: 42440
04 Impreza WRX STi
Platinum Silver
I would have it analyzed, but you are supposed to catch the oil on its way out of the drain hole. So you would really have to do it at the next change. I would go 3k miles and have it looked at if you are scared. They will tell you if you can go longer on the oil, if there are any alarming levels of metal or contaminants, etc.
-st
singletrack is offline   Reply With Quote
Old 09-30-2004, 12:50 AM   #9
Invisiguard
Member#: 43201
04 STi
07 Corvette
Ive had some powder/flakes in my oil since 20K(50K now) Im pretty sure its a bit of bearing material getting beaten out during detonation, Im sure if I tore my motor down I would be down to the bronze on a couple of spots on the rod bearings
this is an exagerated example, but after heavy use the babbit material will seperate from the bronze substrate.
Invisiguard is offline   Reply With Quote
Old 09-30-2004, 01:57 AM   #10
jsalicru
Member#: 58031
yeah... frankly.. I think it isn't too much to worry after thinking some more...
Its been a bit (13-14k was when it was changed) and the car runs perfectly fine. Another thing is that I only see that it came from the filter and not the oil itself.
Oh yea... about those bearings pictured above... i once took a Civic motor apart because of bearing problems... a bearing was FUSED to a rod.
Old 09-30-2004, 08:01 AM   #11
f4phantomii
Member#: 58504
2004 STi w/o wing
Originally Posted by Unabomber
Aha! Excellent info Unabomber. Thanks for the links and the education.
-Michael
Old 09-30-2004, 09:17 AM   #12
bikerboy
Member#: 5477
2007 R171.473
2009 SWP Spec B
I would cut open the oil filter and examine the element for any metal material.
bikerboy is offline   Reply With Quote
Old 09-30-2004, 09:25 AM   #13
Timdog1650
Member#: 45516
MY04 STi
When my engine blew there was no 3rd rod bearing....it had disappeared into oblivion
Timdog1650 is offline   Reply With Quote
Old 09-30-2004, 11:34 PM   #14
burnin4
Member#: 59764
10 sec STi
10 sec Z06
[quote=jsalicru]So yesterday I did my oil change on the car... was eager to do it as it has been 6-7k since the oil change.
Um, most STi's would be out of oil at that point .
burnin4 is offline   Reply With Quote
Metal Shavings in gear oil. ninethreeeleven Transmission (AT/MT) & Driveline 2 10-08-2006 07:47 PM
Why the f'k does the factory crank the oil filter on? Beer:30 Mid Atlantic Impreza Club -- MAIC 20 10-10-2005 03:20 PM
Where in the world is the oil filter located?? leej323 'Old School' Subaru Forum 4 10-01-2005 03:11 AM
Is the ATF filter and the oil filter the same size? Kwyjibo Service & Maintenance 6 12-06-2002 10:40 AM
('93-'01) Is the oil filter for the 2002 impreza accessed from above or below the engine? driver Impreza Forum 4 04-30-2001 10:53 AM
