Old 09-29-2004, 11:53 PM   #1
suby53
Member#: 59648
97' Legacy Outback
Post knock limit on ej18
Hello there. I have a 95' impreza with a ej18 with 89k miles and I recently installed a custom turbo kit on it. It is run with a super afc-2 that has a knock reading on it and I installed a knock sensor to the engine to detect detonation from the turbo. One problem, I don't know the knock limit on my motor so i don't know when i am detonating. I am running 8 psi and have the fuel turned up until I can adjust it to the knock. If anybody knows or knows where I can find the knock limit for my engine please let me know. Thanks!
suby53 is offline   Reply With Quote
Old 10-02-2004, 08:36 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
I would imagine you set it as sensitive as possible until it starts pulling timing due to normal vibration. If you know it's not detonating, set the sensor until it pulls timing and then back off....
As far as I knew....all knock was bad. Smoother engines can have a more sensitive knock setting.
Jay Storm
Old 10-03-2004, 05:01 PM   #3
darioc
Member#: 35695
02 RST
98 Outback 92 Wrangler
just because im curious, what fuel mods do you have?
darioc is offline   Reply With Quote
Old 10-04-2004, 12:15 PM   #4
bangor
Member#: 68747
1996 Brighton AWD
Light Blue
just because i'm curious, what are the details and how much did the turbo cost installed?
bangor is offline   Reply With Quote
Old 10-04-2004, 01:29 PM   #5
chip4761
Member#: 55867
2005 Saabaru
AS
Just because I'M curious, do you suppose dolphins could build underwater cities?
chip4761 is offline   Reply With Quote
Old 10-04-2004, 01:47 PM   #6
darioc
Member#: 35695
02 RST
Old 10-04-2004, 02:07 PM   #7
dmatthew
Member#: 69247
2005 2.5 RS Wagon
Crystal Gray Metallic
wow dolphins can build!
dmatthew is offline   Reply With Quote
Investigation of Knock Limited Compression Ratio of Ethanol Gasoline Blends jblaine Engine Management & Tuning 7 04-22-2010 05:53 PM
Advance Utec user Help with Timing. Knocks! Confused on Fuel/Timing Knock. bluesube2000 Engine Management & Tuning 8 11-21-2005 02:08 AM
Knock link on JDM block and knock feedback wreckedWRX Factory 2.0L Turbo Powertrain 2 11-04-2004 04:38 PM
More discussion on WRX EJ20 heads on EJ18 block required... Kostamojen Subaru Conversions 18 11-23-2003 04:03 AM
In which direction is the throttle body on EJ18? tonytiger Normally Aspirated Powertrain 1 03-23-2002 02:57 PM
Message Board Statistics All times are GMT -4. The time now is 12:03 AM.
