Old 06-19-2001, 08:08 PM   #1
jhayzhon
Member#: 2933
Question 85mph + higher vibration?
Once i past 85 mph in my 2.5 5spd my engine starts umm...vibrating differently? Its a distinct feeling and sound and it starts right after 85mph. Just wondering if any of you guys have the same experience.
jhayzhon is offline   Reply With Quote
Old 06-19-2001, 08:45 PM   #2
Fish
RIP Sirkbac
Member#: 869
1987 GPZ-750 TURBO
90' MX-5/11' DGM STi Sdn
is it just the engine?
or could it be tires/rims.
engines do not care what speed you're going.. just RPM
Fish is offline   Reply With Quote
Old 06-20-2001, 12:43 AM   #3
preza
Member#: 1454
2000 2.5 RS-T
My guess would be that your rims are out of balance
preza is offline   Reply With Quote
Old 06-20-2001, 09:14 AM   #4
2001LegactGT
Member#: 5089
2002 Audi A4
Denim Blue
I had something sort of similiar when I had my 92 Legacy. When I would get to around 85ish the car would start to vibrate and sort of hum but if I would go faster it would stop. So well of course I just had to go faster It was real annoyign
2001LegactGT is offline   Reply With Quote
Old 06-20-2001, 11:58 AM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
85 mph is speeding, sorry cant help you! ahah j/k
Easy way to tell if the vibration is engine speed related (ei. a bad engine pulley or anything rotating at engine speed RPM)
Or vehicle speed related (mph) tires, drivline.
Go the speed it takes to make the car vibrate. Throw it in neautral and let it coast at the speed, you will probably have to go alittle faster than the vibration speed, then let it coast down throug the mph range the vibration occurs.
If the vibration STAYS during coasting (rpms @idle speed) The vibration is VEHICLE SPEED RELATED and I would look into getting your wheel/tire assemblies balanced first, and have your tires checked for lumps...excessive runout. If that doesn't fix it, your probably looking maybe an out of balance drive shaft or a differentional concern
If the vibration GOES AWAY during the coast. Your vibration is ENGINE SPEED RELATED. This could be numorous things, anyone of your engine accessory pulley's or anyting rotating at that same speed. (rpm wise)
I dont know if you can hit 85mph in 4th gear i think you can, see if the vibration always occurs at the SAME RPM no matter what gear, the vibration is indeed Engine Speed Related.
I would be leaning more towards a tire issue here.
Any mods? do you auto-x?
hope that helps.
Jay McDade
Auto Tech--Lincoln/Mercury/Jaguar
www.hometown.aol.com/impreza25rs2000
Old 06-20-2001, 04:20 PM   #6
jhayzhon
Member#: 2933
I dont auto-x but I did take my tire off a couple months ago to check for a dinging noise. I tightened the lug nuts on the wheel today so I'll see if that helps at all.
wish me luck!
Old 06-20-2001, 05:05 PM   #7
Section 8
Member#: 821
I have a simular problem, but mine starts at 80. Its not a vibration, that I can feel anyway, but it sounds like a vibration anyway, I think that it is engine/exhaust related because it only makes the noise when I am on the gas, not coasting. Its not loud, you only hear it when the radio isn't on. I think that it is the exhaust "note". Since I don't "cruise" at that RPM (~4000) in any other gear, I don't notice it other than when I am holding a constant speed on the freeway.
What do you all think?
Greg
Section 8 is offline   Reply With Quote
Old 06-21-2001, 03:36 AM   #8
minix42@
Member#: 548
'98 Impreza RS
dinged up faded black
don't know about the 85 vibration, but I get the 70mph shakes. once I pass this it usually dissapears. I think it might have something to do with the road conditions too. I get it on some roads, but not others, but always at 70mph. I'm kinda curious about this too, but I'm more worried about my headgasket at the moment. Once I get that taken care of, I would be more than happy to go out and do some test runs to see if it's possibly a similar problem. I agree though, go out and see if it's speed, or RPM's, and throw the road surface into the mix as well... Let's see who figures theirs out first
mike
minix42@ is offline   Reply With Quote
Old 06-21-2001, 06:55 AM   #9
jhayzhon
Member#: 2933
Question
K on the way to work this morning I threw my car into neutral once I hit 90 mph and now I'm more confused. The vibration SEEMED to have let up a little but its hard to say....like I cant say for sure if its my alignment or engine thats producing the vibrations. If there's enough room on the highway I'll try it again after work.
If it is my alignment thats jacked I'll be pissed because the only time my alignment was affected was when I was ass-raped by NTB to install my dunlops.
Old 06-21-2001, 06:58 AM   #10
goose
Member#: 3578
I had the same problem, right at around 65- It was so bad the shaking of the steering wheel was making my watch rattle. I got my tires rebalanced, and it's 10 times better now, there's still a slight vibartion at 60- but nowhere near as annoying- I'll have to try and figure out what's still causing vibration this weekend- I suspect (though I hope not!) one of my rims may have some undetectable damage to it-
goose is offline   Reply With Quote
Old 06-21-2001, 11:24 AM   #11
dirk.gecko
Member#: 3141
2007 Scion tC
Blue or something
Section 8....ins't that the dismissal in the military for mental instability?
Anywhoo, the 4000k RPM vibration (more of a WUB-WUB-WUB?) is a resonant frequency within the exhaust. Like a tuning fork, except instead of thousands of vibrations a second, its more like 1 or 2.
Every car has them, its just that some exhausts are tuned to remove them. Stainless steel exhausts make the sound MUCH more pronouced. It is not in any way harmful.
dirk
dirk.gecko is offline   Reply With Quote
Old 06-21-2001, 12:44 PM   #12
MadMax
Member#: 1279
2000 MY00 SRP RS2.5
"Stock" kinda
Lightbulb
I get vibrations noises when driving from 75 up. Mine is caused by exhaust and mid pipe. I got use to it. But if you have a loud exhaust that might be it. Also check you heat shield, it might be loss and rattles with engine hits rpm range of 85.
MadMax
MadMax is offline   Reply With Quote
Old 06-22-2001, 10:23 PM   #13
Section 8
Member#: 821
Heh Heh Shhhhhh..... Hey shut up! He will forget about it if you don't call attention to yourself....oh stuff it, he already knows our secret...Oh poo .... Roses are red violets are blue, I'm a schizophrenic and so am I!
This is what I had in mind too. I should have said that it starts at ~4000 and continues on up because the exhaust "gets louder" around that RPM in any gear, I just don't cruize around in 2nd at 4000 to notice it then, maybe I should try it.
It has a higher frequency than that, maybe 3-4 times a second. Simular to my truck (V8) when I am to high in the gears, going to slow and it dogs baddly. WrrRrrRrrRrrRrrR
Greg
Where to chop Injectors for higher flow outlwstr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 04-28-2016 02:35 PM
low RPM vibrations and BOV(?) noise ryguy02rex Newbies & FAQs 17 06-01-2010 04:52 PM
Great Gas Mileage at 85mph! Skylab Normally Aspirated Powertrain 7 01-17-2003 06:03 PM
vibrations while braking from higher speeds evilwrx Brakes, Steering & Suspension 8 10-27-2002 02:15 PM
Engine Sound over 85mph tonic Newbies & FAQs 16 07-26-2001 09:45 PM
