Old 09-30-2004, 02:59 PM   #1
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
Default Car has the hiccups
I keep putting off taking the car in, cause I know its going to cost so much money, and don't have much time with school, etc etc.
The car has had a CEL on and off for, oh maybe 6 months now. Its a p0304 (I think), misfire in cylinder 4. I had a compression test done a while back, which showed number 4 a little lower, and the leakdown test was like 4% on 1, 2, and 3, and 14% on 4!
It drives great, and still gets 27mpg consistently (thats city driving mostly). So you'll be driving along, and get to a stop light. Sitting there, it starts hiccuping. It isn't a regular periodic thing, its more erradic, like:
buuuuuuuurrr-POP-burrrr-POP-POP-burrrrrr-POP
Its not very loud, but with my noisy axle-back you can hear just a little cough when it does it. The whole car kinda shimmies when it does it too. Soon as it starts doing that a lot, I just have to look down and wait for the CEL, and sure enough it comes on every time. I would say about half of every tank of gas is spent with the CEL on.
Bad valve? Dirty valve? Anybody have any valve work done, and any ideas of the cost?
twizzstyle is offline   Reply With Quote
Old 10-02-2004, 03:33 AM   #2
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
bump
Old 10-02-2004, 03:52 AM   #3
rabbitnutz
Member#: 51940
run seaforam through the engine, and change plugs.....if it doesn't work, it certainly should have helped.
rabbitnutz is offline   Reply With Quote
Old 10-04-2004, 07:04 PM   #4
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
Seaforam?
Old 10-04-2004, 07:28 PM   #5
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Fuel filter? Coil pack, wires or plugs? Just some thoughts... go to Autozone and have them check out the code... that will narrow it down.
jamesfacts is offline   Reply With Quote
Old 10-05-2004, 12:17 AM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Sounds somewhat like the indications I had when I was burning up one of the exhaust valves on #2, so your thoughts on a bad/dirty valve may be correct. After months of driving it that way finally the valve burned through big time and at that point there was no doubt the car was AFU. I unplugged the fuel injector and just ran on 3 cylinders for a few weeks. I can't help on repair cost because I ended up taking the opportunity to go to Cobb ported heads.
Pat Olsen
'97 Legacy 2.5GT sedan
My 02 WRX has the Hiccups, help! Aprice40 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-31-2007 12:08 AM
Car has the hiccups? lbone420 Normally Aspirated Powertrain 2 05-17-2004 09:22 AM
Help: My car has the hicups in the cold SuberStar Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 02-19-2004 11:56 PM
What production car has the highest HP for a 2 cyl engine? NeoteriX Newbies & FAQs 10 10-18-2002 04:05 PM
My car has the worst luck... JGard New England Impreza Club Forum -- NESIC 35 02-07-2002 05:53 PM
