Old 09-30-2004, 05:45 PM   #1
Nicklbrso
Member#: 44887
00 GC6
Default exhaust install?
How hard is it to install a catback on an RS? The biggest problem I see is getting off the 4 bolts that connect the cat to the mid pipe due to rust. Is there anything I can do to make this easier? What else should I be prepared for? All suggestions welcome.
Nicklbrso is offline   Reply With Quote
Old 09-30-2004, 05:48 PM   #2
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
try:
1. PB blaster
2. sawzall
3. torches
4. BFH
5. all of the above?
iamrazor is offline   Reply With Quote
Old 09-30-2004, 06:13 PM   #3
Nicklbrso
Member#: 44887
00 GC6
Originally Posted by iamrazor
try:
1. PB blaster
2. sawzall
3. torches
4. BFH
I have no clue what any of these mean except for the torch. speak english man.
Old 09-30-2004, 06:41 PM   #4
Scooby Blue
Member#: 12112
MY00 RS
PB blaster = brand name of a lubricant...like wd-40...
sawall = cutting tool
BFH = Big F***in Hammer <- my favorite, saved my butt many times, tho I actually use a BF Mallet.
Really should be fairly simple even with hand tools on a older car. To be safe you can pick up extra nuts and bolts incase you break some, and gaskets if the catback did not come with any. Ramps and maybe extra hands...
Scooby Blue is online now   Reply With Quote
Old 09-30-2004, 08:15 PM   #5
RxyGrl
Member#: 63796
04 2.5 RS
JBP
i used WD-40 to loosen the bolts. worked like a charm.
RxyGrl is offline   Reply With Quote
Old 09-30-2004, 09:48 PM   #6
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
dont use the oem jake. I have seen people try to change stuff with that thing and well its not good. I was changing a tire on pavement and it slid under and the car landed on the rotor. (not good). Have a good 3 ton jack with 4 decent jack stands that are of the same brand and make.
Try bolt loosening spray before a torche.
subiekid is offline   Reply With Quote
Old 09-30-2004, 10:39 PM   #7
maddbmxjumper
Member#: 43044
01 sedona red ej20
stage 3 vf23 rs
torch and just breaking the old bolts worked for me!
maddbmxjumper is offline   Reply With Quote
Old 09-30-2004, 11:01 PM   #8
dkl
Member#: 63096
1998 2.5RS
Green
WD-40 (or the like) is pretty essential. I also like to use a breaker bar when things get messy. I think replacing the bolts/gasket is probably a good idea, but overall things really aren't that difficult.
dkl is offline   Reply With Quote
Old 09-30-2004, 11:25 PM   #9
squeech
Member#: 38280
2000 2.5RS w/ EJ205
tuned @ teh Ghetto Garage
I was able to use WD-40 on my header on bolts (front of the cat), but I had to torch the bolts off of the rear for the catback install.
squeech is offline   Reply With Quote
Old 09-30-2004, 11:29 PM   #10
Nicklbrso
Member#: 44887
00 GC6
The car is a 2000 RS that has seen many winters so I am a little worried about getting the bolts off. Are the bolts easy to obtain from any hardware store? How do I know what gasket to get?
Old 09-30-2004, 11:36 PM   #11
blueimpreza25rs
Member#: 21821
2004 Fxt
Psm
YEs the bolts are easy to obtain from any harware store....as for gaskets go to any auto part store and tell them you're year and make and the location of gasket, and u're good to go. Alot cheaper then if you would go to the subaru dealership
blueimpreza25rs is offline   Reply With Quote
Old 09-30-2004, 11:56 PM   #12
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
the three gaskets I purchased for the header install were only $20 or so from Subaru. Napa didn't carry any. For $20, I was ok with the OEM stuff.
Jared
gtwagon941 is offline   Reply With Quote
Old 10-01-2004, 12:18 AM   #13
squeech
Member#: 38280
2000 2.5RS w/ EJ205
Yup, get gaskets OEM from Exeter Subaru for $14 plus ship (added on to an order of some nice Kartboy hangers for that catback ). Catback install only has two gaskets...save ya one there
There's donut from the cat rear to the intermediate, and a gasket from the intermediate to the muffler. Check with wherever you get the catback from, mine came with all the gaskets I needed for install
Old 10-01-2004, 10:33 AM   #14
Scooby Blue
Member#: 12112
MY00 RS
Yea, what are you putting on? Some systems come with gaskets already because they may be larger than stock.
Another tool that I love (along with my mallet) is a set of ratcheting wrenches. They have a thin enough profile to fit where a normal socket will not and saves time and aggravation of constantly taking the wrench off the bolt/nut.
Old 10-01-2004, 11:30 AM   #15
Nicklbrso
Member#: 44887
00 GC6
Its a custom 2.5" mid pipe with an N1 can. Will stock gaskets fit? Can I reuse the old ones?
Old 10-01-2004, 12:42 PM   #16
jamesfacts
Member#: 51282
98 RS
black & blue from parking
I did mine w/ none of the above. The bolts that connect the cat to the midpipe are very easy to break - I didn't even need a breaker bar - just a socket wrench and a box wrench. Undo those bolts, disconnect the hangers, and slide the whole deal out.
jamesfacts is offline   Reply With Quote
Old 10-01-2004, 02:21 PM   #17
squeech
Member#: 38280
2000 2.5RS w/ EJ205
Mine's a 2.5" from FAT...don't know if the stock gaskets will fit b/c I'm getting replacements
My guess is they won't though...OEM pipe diameter is like 1.75" IIRC
Old 10-01-2004, 03:02 PM   #18
Impreza2003
Member#: 67247
2003 2.5RS BRP
SQC 189
WD40 is the most useful tool
Impreza2003 is offline   Reply With Quote
Old 10-02-2004, 10:54 PM   #19
troll_old
Member#: 46355
2002 REX
Agent Orange
PB Blaster is much better than WD 40. I highly recommend it.
troll_old is offline   Reply With Quote
Old 10-02-2004, 11:29 PM   #20
ttboy19
Member#: 38043
2004 impreza rs4sale
'10 Legacy 2.5GT
BFH always made installs a whole lot easier.
ttboy19 is offline   Reply With Quote
Old 10-03-2004, 10:08 AM   #21
Nicklbrso
Member#: 44887
00 GC6
how the hell does a hammer/mallet help any?
Old 10-03-2004, 12:18 PM   #22
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
you put your socket/wrench/whatever on the bolt then hit said tool with the BFH.
Jared
Old 10-03-2004, 02:22 PM   #23
Handsdown
Member#: 29355
pb blaster will penetrate like there is no tomorrow. i'd say it's better than wd40.
Handsdown is offline   Reply With Quote
Old 10-03-2004, 05:33 PM   #24
Will98RS
Member#: 15816
1998 Impreza RS
i just did this today with pb blaster and two wrenches and this is a 98 so they were rusted on there pretty good. i did have my brother hold one wrench while i turned the other and we did end up breaking a bolt and now the auto parts store is closed oh well i guess its an excuse to get some ss bolts.
sorry to run on but the point was pb blaster is good
will
Will98RS is offline   Reply With Quote
Old 10-03-2004, 11:30 PM   #25
Nicklbrso
Member#: 44887
00 GC6
Thanx for the explanation guys. I guess I will be buying some bolts beofre I go and install my catback. Any idea what size/length bolts I should get? Total of 4?
tanabe exhaust install??? Ds baruuuuu Normally Aspirated Powertrain 2 05-30-2001 11:38 AM
BPM exhaust Installed 50mi and CEL Rexy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-20-2001 10:08 AM
Exhaust install Q's and cats jeffg Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-24-2001 09:20 AM
Does anyone have a BPM exhaust installed yet? Turbo4me Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-11-2001 08:15 AM
