#1 |
Member#: 1685
Vehicle:2001 2.5RS-T FMIC WHITE |
Hey all, I got CEL on 2003 WRX.
Running on 2 cylinders, barely idling, dying under load. Replaced plugs - no help. Have not had time to check spark or fuel or anything like that. Before I rip into it, you guys have any suggestions? Tips? Tricks? Methods? Anyways, advice is apreciated. Thank you PS. Could a vacuum leak completely shut off 2 cylinders? Can the timing be completely off?
#2 |
Member#: 28408
TXIC
Vehicle:2002 BugEye WRX PSM |
#3 |
Member#: 9898
Vehicle:2002 WRX Water Injected Blue |
Well, I would try swapping the ignitors and plugs around to see if the missfires track to the other bank.
If it does, get new ignitors and plugs. If it doesn't, get a firing indicator to see if the ignition wires are deliveringthe pulsed current. If it doesn't then you will have to track down the wiring problem.- |
#4 |
Member#: 1685
Got around to checking the spark on each cylinder - strong spark on every cylinder.
#5 |
Member#: 4001
Vehicle:2006 Legacy GT Obsidian black |
Check the injectors. I am getting a misfire on cylinder 1. I think my injector o-ring has blown out, or in.
| Thread Tools | |
| Display Modes | |
| Major Issues 2.2 Only Running On 2 Cylinders After I Cleared Cel Codes (iacv) | bcustom561 | Service & Maintenance | 2 | 05-20-2010 08:17 PM |
| Running on 2 cylinders v9 swap | SpinIce | Subaru Conversions | 2 | 07-01-2008 11:25 PM |
| 96 Legacy Misfire on 2 Cylinders - next steps? | NovasTaylor | Legacy Forum | 13 | 08-23-2004 11:55 AM |
| help.........car running on 2 rear cylinders,can both go bad @ once? | legzy | Engine Management & Tuning | 4 | 05-19-2004 06:17 AM |
| help.........car running on 2 rear cylinders | legzy | Legacy Forum | 0 | 05-13-2004 08:36 PM |
