Old 09-30-2004, 08:43 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Help, car won't go into gear with cable clutch!
I drove my car to work today and the last mile or so my clutch pedal felt a bit strange. I parked the car and when I came out and I started it I couldn't put it into gear. I thought the cable might have slipped some how or the nuts came loose so I got some tools and tightened it up. First a half turn at a time and in the end just a ton. Now it kind of goes into gear. For first to work from a stop I have to pull it back hard into second then push it into first. Up shifting and down shifting through all gears 2-5 seem normal. The clutch cable is so tight now that the clutch is slipping a bit and the release point is rediculously high off the floor. Any ideas?
Joshua
yebokmj is offline   Reply With Quote
Old 09-30-2004, 11:07 PM   #2
yebokmj
Member#: 2213
Brilliant Red
Bump, anyone? I want to drive to work tomorrow.
Old 09-30-2004, 11:53 PM   #3
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
I am assuming you car has the cable operated clutch? I cant figure out what kind of car you have based on your description. If you have a hydraulic clutch it the, clutch master or slave cylinder going bad IMO.
ss
subysouth is offline   Reply With Quote
Old 10-01-2004, 08:58 AM   #4
yebokmj
Member#: 2213
Brilliant Red
I have an Impreza L with a cable operated clutch. Help!
Old 10-01-2004, 02:44 PM   #5
yebokmj
Member#: 2213
Brilliant Red
Default bump
Anyone? Please help! I don't think it's linkage related since it seems to shift fine if the car is turned off.
Joshua
Old 10-02-2004, 11:02 PM   #6
yebokmj
Member#: 2213
Brilliant Red
bump
Old 10-04-2004, 11:23 AM   #7
yebokmj
Member#: 2213
Brilliant Red
Default no one?
bump
Help! Car wont go into gear when started! AjIsDope Transmission (AT/MT) & Driveline 15 11-13-2009 10:30 AM
Need help!!! Car won't go into test mode wuuusaa Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-28-2008 04:59 PM
HELP!! Car won't go in gear after tranny install TheSilverFox Transmission (AT/MT) & Driveline 7 10-30-2007 03:58 PM
Did a clutch install last night, now the car won't go in gear, PLEASE HELP! F3nom3ni Transmission (AT/MT) & Driveline 5 10-03-2005 01:05 PM
need help, car wont go into gears DangeRS Transmission (AT/MT) & Driveline 0 02-12-2003 10:08 PM
