Old 10-01-2004, 04:54 PM   #1
kevin2.5rs
Member#: 67518
2013 Focus ST
TB
Default No Instructions With Cobb Cai
After 2 monthes of waiting for the CAI it finally arived today
but with no instructions.
Can anyone with a 03+rs help
kevin2.5rs is offline   Reply With Quote
Old 10-01-2004, 05:14 PM   #2
dmatthew
Member#: 69247
2005 2.5 RS Wagon
Crystal Gray Metallic
I believe the cobb website has instructions on how to install it
i want a 2005 CAI
dmatthew is offline   Reply With Quote
Old 10-01-2004, 05:31 PM   #3
impr25rs
Member#: 60162
04 Aspen RS
The One Not Turbo'd, NA!!
No cobb doesn't have any. But is should not be that difficult. Disconnect the battery(trust me it, is better to do it now). Remove the stock system by unbolting the pieces, I think 10, 11, 12 mm sockets (an extension would be good too). Disconnect the IAT sensor. Then construct the Cobb CAI (don't oil it, it comes pre-oil). Make sure the silicone sleves are connected firmly. Place the thin strip of silicone on the fender wall. Place the head of the CAI (the part that goes into the fender) first, then connect it to the throttle body with another sleve. Then bolt everthing up, and attach the IAT sensor. Now reconnect the battery (By now I sure that it has take you at least 20 minutes, longer is better, if not more to do the CAI, so ) Start the car up, let it idle for about 10-15 minutes, then take if for a drive. Rev it up to nearly redline in first and/or second. It will take about 1.5-2 weeks for the MAP to fully adjust itself. Vola!!!
impr25rs is offline   Reply With Quote
Old 10-01-2004, 05:40 PM   #4
xfrickx
Member#: 7267
1994 Honda VFR RC-36
2002 Subaru 2.5RS
also note that the rubber filter opening end goes twards the fender, the black plastic housing is meant to work like a velocity stack after the air is drawn through the filter. The silicone coupler is used at the end of the filter twards the motor.
xfrickx is offline   Reply With Quote
Old 10-01-2004, 05:42 PM   #5
millenix
Member#: 43511
2010 Nissan Frontier
Gray
Back December of last year mine came with instructions... It's pretty straightforward... one thing to point out is the filter goes in with the filter facing > not < like most application.
millenix is offline   Reply With Quote
Old 10-01-2004, 07:39 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
You actually got them in the 6-8 weeks they told you? You should be ecstatic, not pissed of. And did you check under the packing slip? They generally put then there and not in the box...
Old 10-01-2004, 07:50 PM   #7
kevin2.5rs
Member#: 67518
2013 Focus ST
TB
I got the instructions e-mailed to me.
but anyways while 1/2 throttle before pushing it there
is a squeling noise, then it makes the grumbling noise.
Is the noise normal?
Old 10-01-2004, 09:13 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
mine screams Seriously though, I am not really sure what sound you are describing and whether or not it is an issue. Expect it to be significantly louder than stock. Many people do not realize that an intake add more noise to your engine than an exhaust. With that CAI, you are opening the throttle plate like 2 feet from your face with only a milli-inch of alluminum and the firewall between you and it. You probably have nothing to worry about. If you aren't getting a CEL, it is a non issue. And I am not familiar with a Cobb CAI throwing a CEL ever on a MAP based car...
Old 10-01-2004, 09:46 PM   #9
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
lol if you need instructions then you should have someone else do it....like a motor head friend.
RS_to_WRX_swap is offline   Reply With Quote
Old 10-01-2004, 09:57 PM   #10
kevin2.5rs
Member#: 67518
2013 Focus ST
TB
I not that concerned about instructions, it's already installed.
Before WOT there is a whistling type of noise, is this normal?
Also the 2 blue tubes that replace the stock ones are not the same size.
interior width not length.
Old 10-02-2004, 05:59 PM   #11
JewPac42
Member#: 23260
Patr ick Willis
for Rookie of the year
In my 00 RS they replace 3 tubes on the stock intake, thats why they arent the same.
JewPac42 is offline   Reply With Quote
04 TS Wagon running RICH with COBB CAI? soloist80 Normally Aspirated Powertrain 15 12-14-2005 04:04 PM
HP gain with Cobb CAI. ? dntouch Normally Aspirated Powertrain 5 09-20-2005 06:00 PM
Cobb CAI instructions HomerJay Normally Aspirated Powertrain 6 04-26-2002 06:47 PM
no CEL with AEM CAI Scoby-blue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-26-2002 03:37 AM
('93-'01) those with cobbs cai DoctorNick Impreza Forum 12 07-31-2001 03:36 PM
