Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Old 10-01-2004, 06:59 PM   #1
Prylex3
Member#: 57308
1999 2.5 RS
Rally Blue Pearl
Question Car is jerky, what is wrong
Alright so my stock 99rs with 80k, started jerking a bit whenever I gave it gas. A blinking CEL came on and when I had the car in the Subaru dealership earlier they said that the drive belt would need to be replaced sometime in the future but not immediately.
So does the drive belt have anything to do with this? The dealership was a bit foggy when they explained things and I want to get to the bottom of this. For some reason the dealership said replacing the drive belt would cost like 400 bucks. Also, the alternator and power steering belt is cracked
Prylex3 is offline   Reply With Quote
Old 10-01-2004, 07:13 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Not the Drive Belt..
the Timing belt, and yes with your mileage it should be changed soon, as well as the crank oil seal and water pump at the same time, (water pump is driven off the timing belt, and the crank oil seals always leak, might as well change them while they are in there)
your drive belts/accessory belts, are you alternator and power steering belt. They sholdnt charge you any extra labor to put them on, just the parts price because they have to take them off when they do the timing belt.
anyhooo
your problem sounds like bad spark plug wires, wich would be a safe bet if you have never changed them. Pretty common with scoobys and high mileage.
Should change the plugs to when you change the wires.
Jay
Old 10-01-2004, 07:15 PM   #3
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Ignition wires, certainly, but it could also be water in the gas if it was a sudden change.
OneOBS is offline   Reply With Quote
Old 10-01-2004, 10:25 PM   #4
Black_Rain
Member#: 29932
2005 LGT Ltd
Womp
or a dirty tb
Black_Rain is offline   Reply With Quote
Old 10-02-2004, 03:01 AM   #5
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Well, the timing belt is good bet. My car is doing the same thing, oddly I threw a CEL today, EXACTLY 1 year to the day from having this done last year. What gives??
There is no logical reason to have the timing belt go bad and then cause the CEL (misfire in 3) after only 15,000 miles. This is now the THIRD time that this has happened to my 98 GT wagon. My car is cursed. I hope that it can be cured this time. Actually, I am REALLY hoping that my mechanic will back his work since there is no reason for this to happen, at all.
If anyone knows something that can explain this please tell.
Oh, and sorry for the hi-jack, but it might help you too.
Jared
gtwagon941 is offline   Reply With Quote
Old 10-02-2004, 05:01 PM   #6
Prylex3
Member#: 57308
1999 2.5 RS
Rally Blue Pearl
Well the spark plugs were just replaced and the wires looked good
The oil seal and water pump was just replaced but this poor college student really coudln't afford a new timing belt at the time Dang.
Old 10-02-2004, 11:36 PM   #7
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
I dont see how a timing belt would cause the car to be jerky at times. I had one break on me with my motor swap. The car acted fine up until the time when it broke.
I thought that the 99 RS is SOHC? If this is the case a timing belt change should not be 400 bucks. I had mine done on my SOHC ej22T and it was only 250 bucks.
Anyone think it is a MAF issue?
subiekid is offline   Reply With Quote
Old 10-02-2004, 11:38 PM   #8
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
Well if you're going to get it done at least don't give your money to a subaru dealer and save yourself a ton by finding a good independant mechanic who works on or specializes in subarus.
j
ilmaestro is offline   Reply With Quote
Old 10-03-2004, 12:20 AM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Well the spark plugs were just replaced and the wires looked good.
The wires "looking" good isn't enough. Wires can look good with 200,000 miles on them - just clean them. With 80,000 miles and 5 years on the car I can assure you that the wires are due for replacement.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 10-03-2004, 05:13 AM   #10
chip4761
Member#: 55867
2005 Saabaru
AS
I was thinking MAF. My car is doing the same thing, more or less, but only before it has had a chance to warm up. Other thought: Have you replaced the fuel filter or air filter lately? My GF bought a 95 Integra which was having bogging issues. I decided to check the air filter. Good thing I did. It was solid bugs and dirt. I don't know how any air actually made it to the TB. Crazy.
chip4761 is offline   Reply With Quote
Old 10-03-2004, 01:01 PM   #11
Honkey3k
Member#: 53992
SOLD CGM 2005 2.5RS
35 PSI -- in my tires
torque
Honkey3k is offline   Reply With Quote
Old 10-03-2004, 09:11 PM   #12
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Ignition coil. I have had 2 go out on my. Same symptoms, except I never got a CEL on my '00. If you have an ohmeter, you can follow the test procedure in the manual.
-Rob
rob is offline   Reply With Quote
Old 10-04-2004, 03:07 AM   #13
auricom
Member#: 3088
'01 2.5 RS
i have this issue with my MY01, but i only get the shacking/hesitation when i'm at higher RPM's, mostly in 2nd and 3rd. sometimes in 4th but very rare. i was thinking something to do with air flow, never thought about timing belt, but considering it's almost at 75K.....who knows. i guess it's just time for a good tune up.
any other suggestions for the higher RPM shacks?
auricom is offline   Reply With Quote
Old 10-04-2004, 05:10 AM   #14
Prylex3
Member#: 57308
1999 2.5 RS
Rally Blue Pearl
Actually I just got a tune up and that is when the mentioned the drive belt thing. But the car doesn't jerk anymore... it just stopped. Of course I have only driven it back and forth to work a total of like 2 miles a day so I plan on taking it in when time permits.
Old 10-04-2004, 04:10 PM   #15
PoopRSkupe
Member#: 48886
'00 WRS
'08 Forester XT
edit: oops didnt read the whole post
PoopRSkupe is offline   Reply With Quote
buying a car from pa. what is autotech???? atenzany62 Tri-State Area Forum 9 03-02-2009 06:39 PM
Sandblasted Audi's intake while the car was on. WHAT IS WRONG? darksc00by Off-Topic 13 11-23-2007 06:54 AM
What is wrong???????? Draven235 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 04-16-2006 02:15 PM
What is wrong with my 96 Impreza? BenjiG Transmission (AT/MT) & Driveline 4 02-15-2005 10:40 PM
Engine is whining. What is it. ImprezedRS Normally Aspirated Powertrain 3 12-16-2001 03:20 PM
