Old 10-01-2004, 08:20 PM   #1
Tuned
Member#: 45843
2007 Cooper Works
Pepper White
Question Tuning with Delta Dash on an Ecutek Reflash
I did a search and found next to nothing on this topic. There are certain parameters that are tunable on the newer Ecutek Reflashes. I was wondering if some of you tuners out there might have some advice on what to change for optimizing power conservatively.
The car has a GMAC boost solenoid per TheMadScientist mod so I am already running 75% wastegate duty and .03 PSI additional boost on a Vishnu Reflash for a vf34, intectors, etc.
I have the PSI3 data monitor for checking out just about all of the ECU's reporting so I can readily check knock correction, EGT (at the uppipe).
Would love to hear some combinations that work for you.
Thanks,
Jeff
Tuned is offline   Reply With Quote
Old 10-01-2004, 09:27 PM   #2
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
first off don't play with fueling if you don't have a wideband.
second, i dunno if messing with boost will throw off AF ratios. someone else can chime in on that.
third, if you haven't found this, this is a nice write up by Shiv from a while back. http://forums.nasioc.com/forums/show...hreadid=351886
MikeWRX-NJ is offline   Reply With Quote
Old 10-01-2004, 09:47 PM   #3
Tuned
Member#: 45843
2007 Cooper Works
Pepper White
A friend just sent me that. I guess I didn't try that search combination. Not planning on changing the fueling options. I have read the thread but looking for more input. I have not seen any signficant drop in knock correction yet. I've seen advance to 11-12 and then back to around 10 at higher revs.
Anyone else with advice?
Old 10-02-2004, 01:53 PM   #4
Tuned
Member#: 45843
2007 Cooper Works
Pepper White
Anybody else?
C'mon. Where are all the Ecutek tuners?
Thanks,
Jeff
Old 10-03-2004, 06:11 AM   #5
Tuned
Member#: 45843
2007 Cooper Works
Pepper White
Bump
Old 10-03-2004, 06:13 PM   #6
Tuned
Member#: 45843
2007 Cooper Works
Pepper White
Bumpity Bump.
Please?
Anybody?
Bueller?
Old 10-04-2004, 03:50 AM   #7
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Check on ecutek's own forums...
they will answer your questions there. ecutek.com I believe.
jigga is offline   Reply With Quote
Old 10-04-2004, 11:52 AM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
well first of all you can't "tune" with delta dash any way it only allows you to modify Vram setings
Old 10-04-2004, 12:15 PM   #9
Tuned
Member#: 45843
2007 Cooper Works
Pepper White
So when I am adjusting ignition advance, boost and wastegate duty cycle, that isn't tuning for performance?
Old 10-04-2004, 04:28 PM   #10
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Try the " Engine Management & Tuning" forum. You'll get what you need there.
ebeck is offline   Reply With Quote
Old 10-04-2004, 05:09 PM   #11
Tuned
Member#: 45843
2007 Cooper Works
Pepper White
Doh!!! Didn't even know we had one. What a noob!!
Thanks for the tip.
I will try there.
Old 10-04-2004, 08:38 PM   #12
Blackpantherwrx
Member#: 70855
Air Spencer... Squash.
why dont you try Ecutek.com they can help u with every thing
Blackpantherwrx is offline   Reply With Quote
Old 10-04-2004, 08:43 PM   #13
Tuned
Member#: 45843
2007 Cooper Works
Pepper White
I looked at their site and there was not that much info on tuning, per se. The forum there is pretty dead. In fact jblaine had one of the few posts I saw on there.
Thanks for the advice. Turns out this is posted in the wrong forum and there is some info on this topic in the engine tuning forum that I noobishly didn't know existed.
Thanks again,
Jeff
Speed Density Tuning with the Accessport on an 08 STI Cobb Tuning Proven Power Bragging 59 06-07-2010 01:22 PM
Wtt: 04 Sti Ecutek Ecu & Delta Dash For Non-ecutek Ecu whitson01 Engine/Power/Exhaust 5 06-01-2007 06:30 PM
MBC on an ECUTek reflash wcbjr Engine Management & Tuning 11 07-27-2005 11:51 PM
ecutek License with delta dash casurfballa Engine Management & Tuning 4 07-20-2005 06:11 PM
EcuTek Delta Dash on eBay Si2WRX Private 'For Sale' Classifieds 8 01-29-2005 01:03 PM
