Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Old 10-01-2004, 09:28 PM   #1
kedrin
Member#: 48380
Default have u tried mobil 1 race oil?
i decided for this next oil change i would try out what they supposedly made for race engines. its 15w-50
anyone else use this and what are its advantages vs disadvantages.
kedrin is offline   Reply With Quote
Old 10-01-2004, 09:44 PM   #2
Rallycarperson
Member#: 53971
#35 SP Rally Car
MAP-RALLY.com
Race oil isnt recommended for street purposes...
-Mark
www.MAPmotors.com
Rallycarperson is offline   Reply With Quote
Old 10-01-2004, 09:47 PM   #3
nug@imracing
Member#: 67422
dont rec. thick oil for subarus, clearences are to tight.
10W30 syn mobil 1 fine
nug@imracing is offline   Reply With Quote
Old 10-01-2004, 09:52 PM   #4
kedrin
Member#: 48380
hmm its a little late for that.. cant hurt anything tho right?
Old 10-01-2004, 09:56 PM   #5
nug@imracing
Member#: 67422
how many miles, and i would go back to 10w30- ive seen to many problems w/ subie motors and oiling problems; i.e. bearings go away
Old 10-01-2004, 10:00 PM   #6
my02turboWRX
Member#: 68448
2008 WRX STi
Cobb tunned by Surgeline
you already have the 15-50 in???
and he is right, TIGHT clearances in the motor
I would drain it
my02turboWRX is offline   Reply With Quote
Old 10-01-2004, 10:01 PM   #7
kedrin
Member#: 48380
wouldnt thicker oil help bearings better...?
i have 15k miles on my motor.
taking it out would cost me another 20 bucks... which i dont have nor do i want to spend again.
Old 10-01-2004, 10:02 PM   #8
illmob
Member#: 47892
2004 WRX
P.S.M.
Race oil? That stuff is for all of the M3 engines blowin' up.
illmob is offline   Reply With Quote
Old 10-01-2004, 10:09 PM   #9
my02turboWRX
Member#: 68448
2008 WRX STi
If you were to have the engine apart you will know why this all is being said. The heads to start with. The cam bearings are tight and when you see how they are oiled then you will have more insight into NOT running a thicker oil.
With that 15-50 you may run a higher risk of hot spots and the destruction of the bearings.
PS
spend the $20
Old 10-01-2004, 10:10 PM   #10
nug@imracing
Member#: 67422
with the tight clearences and thick oil the oil cant get to the bearings good enough or spread on the bearing surface and it will start to eat the bearing.
and it will cause excessive oil pressure.
example: i just put a bone stock ej20 short block in our race car for testing, we did nothing to it, straight 30 to braek it in, but had like 90 psi at idle and could not figure out why.
broke in for 3 hrs and changed to 0w30 Amsoil syn. went down a little so we went on to map the car, got a have a day in and blew the motor up.
took it apart and Subaru gave us a motor w/ clearences so tight the bearings had no oil and burned up ------5 hrs old.
found the reason for the high oil pressure though
Old 10-01-2004, 10:43 PM   #11
shoooter_j
Member#: 39411
2002 WRX Sedan
Crap, I just ran the race oil for ~3500miles Switched back to 10W30 though as I thought the heavier oil would be better for the hotter summer. Great, I hope no permanent damage is done...car seems to be fine..for now *crosses fingers*
shoooter_j is offline   Reply With Quote
Old 10-01-2004, 10:56 PM   #12
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Follow the viscosity recommendations in your owners manual for the ambient temperatures in your area. Subaru knows what they are doing when they make those charts, no need to second-guess them.
Race oil is not intended for street applications and does not have the proper additives to promote engine longevity. Remember that engines used for racing are torn down and rebuilt regularly so the priority is to make it through the race, not to last 100K+ miles.
Old 10-02-2004, 12:08 AM   #13
DChan
Gone... But not forgotten
Member#: 60342
2004 STi
This is how it was explained to me. Race oil is obviously thicker and more prone to sticking to stuff. While on a track, you're exposing the car to g-forces in every direction. Your fluids are going to move w/ those g-forces. Thinner oils are going to move more while thicker ones are not. I tried the M1 Race oil for a track day and did not notice any difference. Now I just use Amsoil's Turbo Formula.
DChan is offline   Reply With Quote
Old 10-02-2004, 12:26 AM   #14
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Race oils do not have most of the anti-wear additives that you find in regular street use oils because they are meant to be chaged out every race. While they are typically capable of operating at higher temps they also break down faster and don't last for the typical duration of an oil change for a street car.
speedyHAM is offline   Reply With Quote
Old 10-02-2004, 07:13 AM   #15
SubieStyle
Member#: 48936
I Do Installs On The
Side;) PM me for details!
If you don't drain it out. At lease let the car warm up for a while to get the oil thinner before you drive it hard or anything. You'd be surprised how long it takes for the oil to reach normal opperating temps. oil temp guage helps
SubieStyle is offline   Reply With Quote
Old 10-02-2004, 08:45 AM   #16
kedrin
Member#: 48380
haha i thought you were starting to refer to the dude with the srt4
"i took the oil filter off and started the car to get all the oil out"
a classic forever.
ya i will be changing oil again. my car is sitting on jacks in my garage while i put all my junk on my car.
Old 10-06-2004, 11:18 PM   #17
fabrik8
Member#: 68797
04 WRX
Aspen Whiiiiiiite
Does that Amsoil turbo formula have a different name? I don't see it right off the bat at Amsoils site..
By the way, are you saying that the Amsoil 0W-30 is too high viscosity? I've never used it but that wa one of my choices to try.. Any other advice on this?
fabrik8 is offline   Reply With Quote
Old 10-07-2004, 12:00 AM   #18
Russ77
Member#: 69369
just run mobil 1 5w30, and 10w30 when it's extremely hot. i've got 45k on my motor, over half of that is with a vf34 swap. i've run only mobil 1 since about 10k miles and it's in excellent shape.
Russ77 is offline   Reply With Quote
Old 10-07-2004, 12:02 AM   #19
MB38
Member#: 51588
2006 WRX TR
1997 Supra Turbo
I love the SRT4 guy. That was such a terrific thread.
"How do you keep oil from spraying everywhere?"
MB38 is offline   Reply With Quote
Old 10-07-2004, 01:13 AM   #20
billllly
Member#: 62116
'02 WRX
blue/gunmetal wheels
10w-30? Is better than 5w-30 if you drive a little harder? I've been using 5w-30 super syn. mobil 1 for a while now.
I don't mean to thread jack or anything.
billllly is offline   Reply With Quote
Old 10-07-2004, 08:01 AM   #21
jvic
Member#: 34953
2011 Legacy
a classic forever.
Oh my...I didn't see that one. Do you have a link to the thread???
jvic is offline   Reply With Quote
Old 10-07-2004, 10:15 AM   #22
kedrin
Member#: 48380
i think its stickied on the srt4 forums
Old 10-07-2004, 11:11 AM   #23
makofoto
Member#: 25243
2006 Legacy Outback
It was my understanding that the low end of multi viscosity oil was how thick the oil is, ie. a 10/30 oil has a viscosity of 10. When it gets warm ... it does NOT get thicker ... it is always a 10 oil ... but it has the protection of up to a 30 weight oil. Oil does not get thicker as it warms up ...
makofoto is offline   Reply With Quote
Old 10-07-2004, 02:18 PM   #24
gr8-wrx
Member#: 38411
2003 WRX Sedan
2001 Honda CR-V SE
Dude, you don't have $20 to spend on oil on your $25K car?
gr8-wrx is offline   Reply With Quote
Old 10-07-2004, 04:01 PM   #25
RexRonald
Member#: 70823
2002 2.0l FP18g
295whp / 265wtq @ 19psi
Default ok
ok, but why then have i read in these forums and others that,
"high revs on cold oil = short engine life"
pretty sure i read that here at NASIOC posted by a respected member... and always thought that myself too, oil just needs to be up to temp before driving hard all over your car... thus the exchanger, warming up your engine oil to operating temp just a few minutes after your coolant is up to temp... ???
RexRonald is offline   Reply With Quote
Mobil 1 Racing Oil 0W-30 CU04BlackWRX Service & Maintenance 24 05-01-2004 07:35 PM
Mobil 1 gear oil wrxlvr Rocky Mountains Impreza Club Forum -- RMIC 2 12-15-2003 08:05 PM
Mobil 1 Syn oil filter? makofoto Service & Maintenance 7 11-07-2002 10:00 PM
mobil 1 synthetic oil 15w 50? boostin1320 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-29-2002 06:15 PM
Is the Mobile 1 Race canceled? Vigorous Texas Impreza Club Forum -- TXIC 1 06-09-2001 09:09 AM
