Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 05-08-2001, 12:25 PM   #1
Farfrumgerman
Member#: 5235
'98 Legacy GT
w/ full-Nelson intake
Question Trey? update on phaseI/II rib marks???
I was exploring a archived thread concerning PhaseI / PhaseII "hybrid" engines... from June 2000 - started by Trey.
Has anyone come up with a solid answer? My '98 GT has the 1 rib on the block - is it a phaseII or no? can I look at the tranny or something to confirm?
I hope it is!! it is in great shape - I run the hell outta it, 59K mi, and only eats 1/3 qt of oil between every oil change....
anyone...anyone... bueller....
thanks,
Chad
Farfrumgerman is offline   Reply With Quote
Old 05-08-2001, 04:30 PM   #2
Farfrumgerman
Member#: 5235
'98 Legacy GT
Post
TTT - - and soooooo soon
common - someone has to know!?
pleeeaaassse
Old 05-08-2001, 04:35 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I'm pretty sure that was the definitive answer. Phase II's had 1 ridge while Phase I's had 2.
Old 05-08-2001, 06:58 PM   #4
Cobb Tuning
Member#: 4803
Post
Originally, we thought that all Phase 1 blocks had 2-ridges, and the Phase 2 blocks only had one.
Unfortunately, during our regular engine building duties we've found that Subaru has mixed and matched a few blocks, particularly in '98 when the changeover occured. They'd use Phase 2 cases machined to accept Phase 1 cranks and thus, rods.
That is extremely rare though. If you have 1 ridge, I would suspect it's a Phase 2 block. MY98 is a weird year though, Subaru was making quite a few changes so we never know exactly what we're going to deal with when we get our hands on one of those engines.
Thanks,
Trey
Cobb Tuning www.cobbtuning.com
Old 05-08-2001, 07:22 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Trey - Got something I can measure in there to tell the difference? Crank dia. or something?
Old 05-08-2001, 07:28 PM   #6
Safir
Member#: 3873
. Paradise is
like Disney with hookers
Post
where are said ribs located? we have a 98 RS around here and we are trying to figure it out. I understand what you said about things changing a lot in 98 but it'd be nice to have an idea.
Safir is offline   Reply With Quote
Old 05-09-2001, 12:11 PM   #7
Farfrumgerman
Member#: 5235
'98 Legacy GT
Talking
Thanks for the info!!
I am stoked that my GT has what most likely is a phaseII!!
Safir - - The ribs are located (looking at the engine from the front) on the left (pass.) side, top & front of the block -(not the head). Look for the EJ25 stamping, then look a little left and more forward from there - the rib(s) will be parralel to the front of the car - and are .75-1" long. they are raised off of a round smoothed area of the block 1" in Dia.
thanks again!
Chad
Old 05-09-2001, 12:17 PM   #8
Joel Gat, 1.8L
Member#: 32
Post
Hello,
See my post in the thread on "calling all '98 owners" or something like that. I still think at least as accurate as the marks on the block are the number of bolts to the tranny. The block itself is a phase-II block if it is designed for a 7-bolt tranny.
Sure, there may be some internal differences and I guess you can't be sure without looking at the crankshaft, but still, just crawl around and count the attachment points - is the starter mounted on a stud that comes from the engine, through the tranny or is it attached to the tranny itself off a tranny-stud?
there are several ways to test this visually...
Joel
Joel Gat, 1.8L is offline   Reply With Quote
Old 05-09-2001, 02:32 PM   #9
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
Post
I have both EJ25 Phase I and Phase II engines here and upon inspection they both have a single rib as desrcribed. Your best bet is to count Bellhousing bolts. Regardless of which heads it has (single or double cam), a Phase II case will have an 8-bolt bellhousing.
SubyTechMaster is offline   Reply With Quote
Trey Cobb on Speed TV right now! waktasz Motorsports 18 01-08-2008 12:34 AM
Anyone have an update on KYB AGX on WRX wagon? Orson Brakes, Steering & Suspension 14 08-25-2003 12:09 PM
Best informative site on the web. Book mark it! HIHO General Community 1 07-08-2002 11:58 AM
Update on on software from Link JenisonWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 05-29-2002 04:32 AM
any updates on fog lights on with high beams? joostin420 Technical Forum Archive 8 06-13-2000 03:03 PM
