Old 10-02-2004, 02:40 PM   #1
popnGEAR
Member#: 4616
1999 2.5RS
RBP
Default Major Engine Problem, help!
So I used to have blown headgaskets but I had those replaced with the gaskets with the updated design and things have been fine for the past 5 months. Yesterday however, while i was driving home fumes began emitting from beneath the passenger side of my hood. When I stopped to check, i could see all over the passenger side underneath the hood was coolant everywhere. With my prior blown headgasket issue, the coolant would only spew out from the overflow and end up on the driver side. Now I can't drive for more than a couple minutes and it will beging fuming. Also there is a kind of ticking noise coming from the engine bay. Any ideas what this may be?? It sounds like it's expensive and I think I am just going to trade in my car.
Thanks guys
popnGEAR is offline   Reply With Quote
Old 10-03-2004, 02:45 AM   #2
Honkey3k
Member#: 53992
SOLD CGM 2005 2.5RS
35 PSI -- in my tires
leaky hose?
Honkey3k is offline   Reply With Quote
Old 10-03-2004, 04:08 AM   #3
RyansJDMgc8
Member#: 65462
01' 2.5RS
Silver/Carbon Fiber
Freeze plug?
RyansJDMgc8 is offline   Reply With Quote
Old 10-03-2004, 11:41 AM   #4
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Water pump?
jamesfacts is offline   Reply With Quote
Old 10-03-2004, 06:27 PM   #5
ruskiyab
Member#: 55128
2007 Impreza WRX
blinker fluid?
in all seriousness, first see where the coolant is coming from, then panic
ruskiyab is offline   Reply With Quote
Old 10-03-2004, 09:54 PM   #6
popnGEAR
Member#: 4616
1999 2.5RS
RBP
well it turns out to be a pinhole in my rad hose, so i'm gonna get that replaced and see if it does the job. thanks for the advice.
Old 10-03-2004, 10:05 PM   #7
dmatthew
Member#: 69247
2005 2.5 RS Wagon
Crystal Gray Metallic
lol blinker fluid
dmatthew is offline   Reply With Quote
Major Engine Problem TheShadowWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-26-2006 09:14 AM
Major Idle problem ? Help ? galacticWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 08-18-2005 01:12 PM
Major Engine Problem, help! popnGEAR Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 10-02-2004 02:38 PM
Major Engine Problem!!! mattjk Southern California Impreza Club Forum -- SCIC 38 10-04-2003 07:32 PM
Major Engine Problems! SubaruImpreza_power Newbies & FAQs 4 09-05-2003 03:09 PM
