#1 |
Member#: 111
Vehicle:1999 Impreza 2.5 RS EJtwentyfied -> '04 STi |
I want to swap in a V7 motor into my GC. Can I run it with a USDM WRX ecu/harness? My car will need to pass obd-2 emissions either in Cali or Ohio. Will a usdm ecu work with any JDM Sti motor (V5-V8)?
thanks, Duncan
#2 |
Member#: 11932
Vehicle:1998 CW ITR 2006 NBP SI |
the vvt wont work, it will run, i accidentally put a 04 wrx ecu in my v7 and it ran fine just had a CEL for the TGVs, fuel temp sensor and random stuff, the car will pribably need to be tuned to run good though..
#3 |
Member#: 111
I would have it tuned with a ecutec, to get it running right. Is there any way to get rid of the cel lights.
Also, I read a couple people have passed obd2 emissions with the V7 ecu. Something about it just reading the o2 sensors or something. Have you passes emissions with your V7? |
#4 |
Member#: 11932
i passed emissions, but we dont use the obd port here, just a probe in the tail pipe..
and u can delete trouble codes with ecutek now fromw hat ive been told |
#5 |
Member#: 36901
South East
Vehicle:2007 RX-8 Brilliant Black |
My car passed the obd2 emissions test. All you need to do is get an AVCS wiring harness from East Coast Scooby and you will be all set using the WRX wiring harness.
George |
#6 | |
Member#: 70346
Vehicle:2011 WRX Lightning Red |
#7 |
Homicidal Maniac
Moderator Member#: 1612
Vehicle:2008 STI |
I will be doing OBD2 emissions this coming Saturday on my V7. I'm currently running clean, with no CELs.
-Jon |
#8 | |
Member#: 25516
NWIC
Vehicle:1995 Legacy TURBO!!! EJ22T/TEC3 & 06 MCS |
#9 | |
Member#: 10852
Vehicle:Then : JDM Ver 7 STi Now : E46 M3 / MKVI GTI |
#10 |
Homicidal Maniac
Vehicle:2008 STI |
Version 6-8 are... Well, they are and they aren't. Yes, I can connect to my V7 ecu via OBD II and get the readiness state. However, I cannot poll a single sensor parameter using my Auterra OBD-II scanning software like I could with my WRX ecu.
Please take a look in the FAQ as there are two threads answering the emissions questions. -Jon |
#11 |
Homicidal Maniac
Vehicle:2008 STI |
My car passed the Utah state emissions test with no problems. All the readiness states can be queried on the V7 ecu via OBD II just as they expected. I am legally registered with my 2002 drivetrain and all emissions equipment.
-Jon |
#12 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
registerd with the 2002 drivetrain that is in your garage?? not your car?
#13 | |
Member#: 11932
#14 |
Homicidal Maniac
Vehicle:2008 STI |
The 2002 STi V7 drivetrain that is in the car, not the *sigh* OTHER EJ20 I have sitting in my shed... It passed with a JDM, but newer, drivetrain complying with the standards set for a MY96 emissions test.
He looked for a cat in the factory, MY96 location, checked for the EGR system, evap system, PCV, and gas cap. He then polled the ecu, primarily noting that the MIL was off, that it could turn on if needed, and that no sensors reported errors (though some reported as "N/A". -Jon |
#15 |
Member#: 33782
Vehicle:96 bastard child search FIRST, then PM!!! |
I'm glad I don't have OBD-II or emissions crap for my inspections
sorry for you guys though who actually have to think/worry about them ![]() |
#16 |
Member#: 10197
I should have started my swap sooner... I found out last week that OBD II scanning is now part of Upstate NY's inspection
I thought it wasn't supposed to be implemented for atleast 2 years!Keith |
#17 |
Member#: 51282
Vehicle:98 RS black & blue from parking |
Wonder how YaZ passed then?
Jon, Whats a PCV check? ![]() |
#18 |
Homicidal Maniac
Vehicle:2008 STI |
Uh, check to see if a PCV valve exists where it is supposed to be...
-Jon |
#19 |
Member#: 25693
Vehicle:2008 18x9" goodness E85-380ftlbs @ 3100 |
Very interesting! I was thinking that I would have to swap back in my AF423 ECU and find a way to undo my AVCS conversion of the TGV wires, but now I have hope.
Anyone have any idea how Oregon compares to Utah? |
#20 |
Homicidal Maniac
Vehicle:2008 STI |
There should have been nothing undone with the TGV wires. The AVCS wires sit in tandem to all other existing wires. I have no idea how Oregon compares to Utah. OBD-II is a standard so your ECU should work fine as long as they use that.
-Jon |
#21 |
Member#: 25693
I used some of the wires that originally went to the TGV sensors and actuators when I wired in the AVCS. If I were to plug in the AF423 I am sure I would get a TGV sensor error. I could always reflash it away, but that seems silly just for an anual inspection.
Thanks for the information, I am now MUCH less concerned about inspection time, which is basically now since I am moving into Oregon this week. |
#22 | |
Member#: 24537
SCIC
Vehicle:2006 LanEVO9 RS SFVoltron White |
#23 |
Homicidal Maniac
Vehicle:2008 STI |
You do need to have an AVCS ECU in order to control the AVCS unit.
-Jon |
#24 | |
Member#: 36901
South East
pegdrgr- You shouldn't have any problem with TGV CEL's because your motor has no TGV's and the ECU doesn't read for them either. I've run my car with and without my UTEC and there are no TGV related CEL's, you should have no problem at all. George Last edited by SonicYelloWRX; 11-08-2004 at 01:07 AM. |
#25 |
Member#: 25693
I am only concerned with inspection time. If I switch back to my stock ECU it will look for the TGV stuff. Prior to reading this message I thought that I needed the US ECU in place to get it to pass. Now that seems to not be the case so I am not worried about it. I will just replace my rear O2 sensor, reset the car, and call it good.
| Thread Tools | |
| Display Modes | |
| JDM ej20 (2004 from legacy twinscroll) with USDM wrx ECU. | elsanto | Subaru Conversions | 0 | 06-15-2007 02:20 PM |
| Running STi EJ207 with USDM WRX ECU | garface | Factory 2.0L Turbo Powertrain | 7 | 03-18-2006 06:10 PM |
| running a usdm sti longblock with a wrx ecu/manifold | legacy2003 | Factory 2.0L Turbo Powertrain | 3 | 12-02-2005 12:58 AM |
| v7 motor, v8 complete harness;v8 ecu okay? | petawabit | Subaru Conversions | 1 | 07-29-2005 12:06 AM |
| Is It Possible To Run Jdm Sti V7 Heads On Usdm Wrx Ej20 | julien | Factory 2.0L Turbo Powertrain | 10 | 06-29-2005 02:00 PM |
