Old 06-20-2001, 08:36 AM   #1
Joncas
Member#: 5349
Have a Nice Day? Exhaust smells like rotten eggs
Everytime I put my foot in it, either marginally or through the fan blade, the exhaust smells like rotten eggs
Now I think it has something to do with the catalytic converter right? I brought the car in once before for service for this same problem and they said they couldn't recreate it. Bunky.
So here's my questions -
1. Is it covered under warranty (MY 99 with 18,000 miles)
2. The problem started before I put on my stromung muffler (no midpipe yet). However, now I have the muffler on. Will they try to blame it on that? Should I remove my stromung muffler and reinstall factory?
3. What types of things can cause that smell problem?
It's an embarrassment I tell ya.
Thanks all.
Joncas is offline   Reply With Quote
Old 06-20-2001, 08:57 AM   #2
tmaler13
Member#: 1992
Did you check your pants??????
Seriously the 99's run rich, which means ever so often your gonna smell rotten eggs, its the unburned fuel in your exhaust.
putting on an intake might lean things up a little bit, so would getting a S-AFC. BTW do you have carbon around the rim/tip of your muffler? Thats a sure sign.
-Terry
tmaler13 is offline   Reply With Quote
Old 06-20-2001, 08:58 AM   #3
Opie
Floresbian
Member#: 470
2013 BRZ, 2011
Forester, '04 Chev 2500HD
Yes, rotten egg smell is usually a problem with the converter, it should be warrantied for 60,000 miles.
Opie is offline   Reply With Quote
Old 06-20-2001, 10:21 AM   #4
subarurabbit
Member#: 4083
2006 OBS SE
regal blue
I'd say your cats are gone too.
Roger
subarurabbit is offline   Reply With Quote
Old 06-20-2001, 12:06 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
From my experience as a technician the smell is directly related to fooked up cats.
My RS has stunk like rotten eggs ever since it was new, the service adviser tells me its normal everytime I go in and complain about it, he makes me want to jump over the counter and smack him upside his head for lieing to my face. Makes me more mad because he knows im a technician. errrrrr
Yup it got even worse when I put my stromung cat back on, high flow exhuast, makes it more evident.
Stilling searching for answers...
Jay McDade
Auto Tech--Lincoln/Mercury/Jaguar
www.hometown.aol.com/impreza25rs2000
Old 06-20-2001, 02:42 PM   #6
nikkicalves
Member#: 3608
Location: the T-dot - The green igloo billowing black smoke
2000 Impreza
Tanned - BRP
I don't think that it a bad catalitic, but more like it's going fast. I don't think this many people have "bad" catalitics. didn't someone say something about this before, that if you beat the car, the cat wears out faster causing the internals to burn up faster than usual causing a smell? I drive the car hard on a daily basis and I still get that awful smell every time. It sucks.
Nick.
nikkicalves is offline   Reply With Quote
Old 06-20-2001, 03:25 PM   #7
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
Subaru issued a bulletin about this some time back. It will often have to do with the sulfer content of the fuel. The emissions system is designed for low sulfer fuel (up 100ppm) such as found in CA. Fuel in the northeast states averages around 200ppm. Federal limits are 1000ppm. So even if your car is working perfectly, it may still stink. Try switching brands of fuel.
SubyTechMaster is offline   Reply With Quote
Old 06-20-2001, 03:54 PM   #8
nikkicalves
Member#: 3608
2000 Impreza
Tanned - BRP
That was also my initial thought but it didn't make that much of a difference. I have tried three different brands and grades for a few weeks at a time. It make very little difference here in Canada.
Nick.
Old 06-20-2001, 04:01 PM   #9
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Im not sure but seeing how NJ has the same emmisions standards as california, sulfer ratings are probably the same...but dont quote me, ill have to check into it.
With mine im talking about highway cruise, it makes me want to puke! or even slow parking lot manuevers. Plus I have poor gas mileage to boot. Since im in the business ive exhausted every option I can think of b4 taking in to the dealer.
If SOA knows about the problem, how about some redesigned cats to work with the higher sulfer content fuel.
Mercury Cougars had the same problem and we now change the thired catatylic converter for this concern...
Ive tried all different brands of fuel, way before I even complained about it. Now I just deal with it till they blow up not that they would.
Old 06-20-2001, 04:03 PM   #10
subenutt
Member#: 930
99 Impreza 2.5RS
Default MY99 does not run Rick
tmaler13- MY99's do NOT run rich. In fact, they are one of the only model years that run lean. Dangerously lean above 5k. Therefore, the S-AFC is needed to richen the fuel mixture.
Sports Compact Car did a story on installing an intake, exhaust, and finally SAFC. They didn't realize it would run too lean, until they saw a drastic slip in hp on the dyno. I think the article was in March '00 or something like that? There's a pic of a Yellow Type R on the cover.
By the way, after installing the S-AFC shiv saw a gain/ re-gain of about 10hp to the wheels above 5k.
subenutt is offline   Reply With Quote
Old 06-20-2001, 04:44 PM   #11
tmaler13
Member#: 1992
hmmmm....
Sorry didn't mean to misguide you,
its just that my 99 has run rich since day one...without any mods, now with an intake and full header exhaust i'm still running rich. O2 sensor on the S-AFC shows a rich condition as does the amounts of carbon deposits on my exhaust.
guess its just me...
-Terry
Old 06-20-2001, 09:11 PM   #12
Santo Domingo 2.5 RS
Member#: 5354
Silverthorn Metallic
Lightbulb
I had that same problem like a month ago, each time i used to step on the gas, this smell came in. Some friend of mine told me he used to have the same problem on an AMG E-55 he owns, son he told me to remove the cats and install a dynomax resonator where the cat goes.
So i did, and the problem is gone besides adding some power to the car. I would recommend you to do the same.
Santo Domingo 2.5 RS is offline   Reply With Quote
Old 06-20-2001, 11:42 PM   #13
Joncas
Member#: 5349
I'm getting the feeling that I should try bringing it in and if they don't fix anything (like put in a new cat or two) - I'm bumming. Of course - only more reason to put on my stromung track pipe that removes the 2nd cat. 1 less cat equals less stink.
Thanks for the thoughts.
Old 06-21-2001, 07:52 AM   #14
TurboDude390
Member#: 3120
Lightbulb
I had the same smell and bad gas mileage with my '00 RS. When the dealer did the O2 sensor recall fix two months ago BOTH problems went away.
Before the O2 sensor recall I tired the low sulfer gas and every diferent brand of gas available to me in the midwest and still had the bad smell. I figured the low gas mileage was due to running the hell out of my RS.
As a side note my tailpipe went from black and sooty to totally clean after the new O2 sensor was installed. This leads me to believe in my case that extra fuel was being feed into the engine due to the bad O2 sensor. This fuel was being passed out the exhaust while un-burnt and being burned in the converter.
The floor in my RS would be so hot before the O2 sensor recall that passengers in front would complain that their shoes were smoking hot!
TurboDude390 is offline   Reply With Quote
Old 06-21-2001, 10:38 AM   #15
OutAtSea
Member#: 7578
Talking
Mr. Joncas, I suggest that you give your RS to your dear friend with the beat up Ranger. I don't think he will mind the smell since his truck barely runs.
Anyway, like I have said before, take out that damn second cat and throw the freakin track pipe on. Then, put a new O2 sensor in the track pipe and all should be good. After that, let that same friend with the Ranger drive the car for a day or so, so he can gather up some ladies for a "movie" night.
Later man
OutAtSea
OutAtSea is offline   Reply With Quote
Old 06-21-2001, 04:24 PM   #16
Joncas
Member#: 5349
I love the reponses this car gets...
Thanks all for the opinions and thoughts. I'll let you know tomorrow what I find at the dealer.
Old 06-22-2001, 06:51 AM   #17
99 RS 2.5
Guest
Member#:
My car does the same thing , even more so with after market exhaust. I believe it's just running rich like everyone says and i also agree with that not this many people have bad exhaust. Car runs good still and no loss of power which is not right if you have a bad cat. If car is bad car isn't going to run that great and you'd smell it all the time not just after getting on it a bit. Just my 2cents
05 WRX exhaust smells like burning corn all the time...Help! jornander Factory 2.0L Turbo Powertrain 19 01-15-2009 10:00 AM
exhaust smells like sulfur 03sti Factory 2.0L Turbo Powertrain 5 05-08-2008 08:24 AM
My farts smell like rotten eggs.... The Tree Off-Topic 16 07-04-2005 05:59 PM
my farts smell like rotten pumpkin.. alacrity024 Off-Topic 24 03-24-2005 12:56 PM
Exhaust smells like ass! PntBllRS Normally Aspirated Powertrain 44 04-08-2002 01:12 AM
Message Board Statistics All times are GMT -4. The time now is 05:33 PM.
