Mid Atlantic Impreza Club
Old 10-03-2004, 04:49 PM   #1
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
Default what size rotors/pads for '95 legacy L ?
My friend's parents need new brakes on their legacy and I was wondering if my old wrx gear would fit. Does it even have discs in the rear? I know some of you would know the rotor sizes/bolt pattern off the tops of your heads.
Thanks all.
Brandon
rex n effect is offline   Reply With Quote
Old 10-03-2004, 05:07 PM   #2
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Brandon, I think these are the sizes.
Front- 260x24mm 1 pot
Back- 266x10mm 1 pot
The only thing that will swap with the WRX is the rear rotors. I'm not sure what the OEM WRX has for rear calipers, but the 95 L has 1.5" 1 pot. Fronts are the same rotor as the RS, smaller than the WRX.
scoobyimprza is offline   Reply With Quote
Old 10-03-2004, 05:27 PM   #3
rex n effect
Member#: 15289
02 wrx pollen silv
So only the rear rotors would swap? That's what I suspected...
Thanks Brent!
Old 10-03-2004, 08:03 PM   #4
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
If you put WRX brackets on the fronts, you could then use WRX pads(calipers are the same I believe) and rotors.
Speedwagon is offline   Reply With Quote
Old 10-06-2004, 12:43 AM   #5
rex n effect
Member#: 15289
02 wrx pollen silv
That's what I was hoping, but brent says they're 1 piston front calipers...
can anyone confirm or deny the allegations?
Old 10-06-2004, 08:41 AM   #6
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
They're definately 1 piston, and the rotors are smaller too.
Old 10-06-2004, 11:19 AM   #7
BAC5.2
Member#: 43996
The Aggressive (tm)
You don't know about it..
I'll sell you my Turbo Legacy front brakes if you want them... Just need a rebuild kit (like $15 bucks). 10.9" rotors 2 piston calipers (not the same caliper as the WRX brakes). They have some junk NAPA pads that have been on for like 3500 miles, and the rotors are on their last legs. Might get 1 more good turn out of them.
BAC5.2 is offline   Reply With Quote
Old 10-06-2004, 05:50 PM   #8
Speedwagon
Member#: 19681
Green
What models got the same calipers as the WRX ones then? I know my '98 GT has the same calipers, just a different bracket/rotor size. Which, BTW, I have an extra set of calipers if you are interested.
WTB: 2-plug brake switch for '95 Legacy mel t vin Private 'Wanted' Classifieds 4 11-06-2008 12:08 AM
Liftgate for '95 Legacy wagon mel t vin Mid Atlantic Impreza Club -- MAIC 2 09-04-2008 02:44 PM
WTB: Plastic Body Trim for '95 Legacy LS Sedan 2cam16 Private 'Wanted' Classifieds 0 04-27-2008 12:52 AM
WTB Passenger Headlight for '95 Legacy Gallican Private 'Wanted' Classifieds 1 12-21-2004 12:25 PM
Headlight Kit for '95 Legacy AWDBat Legacy Forum 3 11-02-2000 11:38 AM
