Old 06-20-2001, 01:10 PM   #1
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
Default WRX Vibration noise at 2000 rpm and WOT?
I noticed an odd noise/vibration that appears if i am just putting along in a gear at a speed where my RPMs are at 1800-2000 (say 4th gear at ~35 to 40 MPH). at this point, if i put the pedal to the floor (WOT), it sounds like there is some shuddering happening in the engine bay. is the turbo doing something weird here? the noise goes away as the needle passes ~2200 RPMs. Any thoughts here?
Cosworth is offline   Reply With Quote
Old 06-20-2001, 03:32 PM   #2
Xio
Member#: 3805
2011 STi Sedan SWP
2011 Outback ABP
At 2000 rpms you are probably bogging the engine going to WOT. I tend to stay light on the go pedal until 3000, then punch it and let it run free....
Remember at 2000 rpms you have very little power. Wait till 3000, the EJ20 motor has NO problem producing power then (Boost! ). You may have to readjust your driving style a bit to keep it up in the powerband.
Xio is offline   Reply With Quote
Old 06-20-2001, 08:31 PM   #3
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
I suppose she was bogging, but it was making some really bad noises... i suppose it was to be expected. has anyone else tried this and heard the same loud bogging noises?
Old 06-20-2001, 11:14 PM   #4
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
Yes =) Try putting it in fifth at about 20 and see if that feels the same =).
Conduit is offline   Reply With Quote
Old 06-21-2001, 02:39 AM   #5
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
WEll, it was not the typical grumpling noise that i heard, but what sounded like some weird turbo noise in addition to it...
Odd noise at 4k rpm and above corms333 Newbies & FAQs 8 07-08-2009 10:53 AM
High pitch whistling noise at higher RPM but not WOT bnr34rb26dett Service & Maintenance 6 06-23-2009 10:39 PM
2005 RS making a vibration noise over 3000 RPM and Dent in tank... pinball4530 Newbies & FAQs 0 08-16-2008 10:45 PM
vibration noise at ~2k rpm Dekka98 Newbies & FAQs 5 08-26-2007 02:02 AM
Clutch Vibration and Noise at 3000 RPM jdsimpreza Transmission (AT/MT) & Driveline 0 09-29-2003 01:19 PM
