Old 06-20-2001, 01:11 PM   #1
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Question Problems with my Whiteline sway bar
I am having a small problem with my Whiteline sway bar/endlink setup and was wondering if anyone else is having similar problems and/or solutions.
The problem is that the nut that holds the bar to the endlink keeps on backing out resulting in a loose bar that causes and annoying clunk sound when the weight transfers at low speeds. I am using the 18-22mm bar set in the 18mm position. I re-tightened the bar last night for the second time and changed the position to the middle setting.
Anyone have any suggestions on how to stop this problem?
Later Z
Zephyr is offline   Reply With Quote
Old 06-20-2001, 01:23 PM   #2
Skylab
Member#: 4263
Arrow Some help is on the way...
I have the Whiteline bar and also had an annoying clunking sound cornering at low speeds. Then I removed the jack from it's compartment and there was no more clunking sound. The bolts on the bar are all still tight from when it was installed early last month.
Put washers on the end link bolts. And remove your jack.
Skylab™
Skylab is offline   Reply With Quote
Old 06-20-2001, 02:09 PM   #3
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Ok great!!
So your are saying that it should be bolt-large washer-bushing-small washer-bar-washer-nut?
What about a lock washer?
Thanks Z
Old 06-20-2001, 04:07 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Did the bar and endlinks come with hardware or are you using stock?
Try putting some loc-tite on the threads...any bolt that is going to be under stress should have some loc-tite, and try torqueing the bolts to the proper level, 15 ft lbs I think for the links but im not sure.
Jay McDade
Auto Tech--Lincoln/Mercury/Jaguar
www.hometown.aol.com/impreza25rs2000
Old 06-20-2001, 05:21 PM   #5
TurboBoxer
Member#: 6028
2002 WRX Sedan
WR Blue
this is also a problem with my cusco rear bar. so its not only whiteline bars
TurboBoxer is offline   Reply With Quote
Old 06-20-2001, 10:28 PM   #6
aarneson
Member#: 3383
IF you happen to have the whiteline sway bar mounts, the exhaust will also cause a clunking sound when cornering beacuse the stock muffler will rattle against the mount, for some this may be the noise... just my 2 cents- Arne
aarneson is offline   Reply With Quote
Old 06-21-2001, 12:58 AM   #7
SilverSubie
Member#: 4375
Wink
i belive on the whiteline site they say you sposta keep the ajustable sway bar on the tightest setting(22) or it can create an unstable handling situation. just thought i'd tell ya.
-grant
SilverSubie is offline   Reply With Quote
Old 06-21-2001, 03:37 AM   #8
r5t2
Member#: 1693
I've had the same problem with my front whiteline swaybar. I tightened it a couple times and it hasn't happened again. If it does I will use loc-tite. Try that. If you really don't want it to come loose then use the red loc-tite
r5t2 is offline   Reply With Quote
Need advice on weather or not to install my Whiteline sway bar or wait. last lemming alive Brakes, Steering & Suspension 5 05-15-2010 09:13 AM
Whiteline Sway Bar & Endlink Causing Problems? chaddeus Brakes, Steering & Suspension 2 02-07-2006 03:19 AM
Strange thing with my rear sway bar gregsatt Texas Impreza Club Forum -- TXIC 8 05-27-2004 10:18 AM
anyone with experence with whiteline sway bar brackets? DoctorNick Mid West Subaru Owners Club Forum -- MWSOC 0 11-20-2002 09:52 PM
Should I buy the sway bar mounts with my new sway bar and links? Derres Catalano Brakes, Steering & Suspension 1 03-22-2001 06:59 AM
