Old 10-04-2004, 09:58 PM   #1
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
Default Flashed AP stage 2 v 1.20 tonight..questions....
i love it, drove it around for like 30 mins, reached an indicated 16.5-17 in 3rd after vishnu reset, but should i try the 3/16 mod and wastegate adjust mod?
bren wrx is offline   Reply With Quote
Old 10-04-2004, 10:37 PM   #2
peterex
Member#: 27021
2015 WRX
No and no. You're already boosting on the high side. Shortening the wastegate arm will only make you boost even more, which would be a bad idea IMO. As for the 3/16th mod, all that is going to do is make your boost control unpredictable and lead to spikes. Hey, your car is doing everything that it is supposed to be doing - why screw around with it and cause problems? Just my .02.
Glad that you're enjoying v1.20 - I'm loving mine as well. Pretty amazing for an off-the-shelf map.
peterex is offline   Reply With Quote
Old 10-04-2004, 10:59 PM   #3
Flyn'Rex
Member#: 64957
i'm only hitting 15.4 pounds faintly in 4th and 5th. I haven't done the vinshu reset but i have done the AP reset. Don't know why i'm still not hitting target boost. Any help guys?
Flyn'Rex is offline   Reply With Quote
Old 10-04-2004, 11:05 PM   #4
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
well heres my question to you pete, i ran 14 ish bone stock, maybe my gauge could be off?
Old 10-05-2004, 12:16 AM   #5
supermarkus
Member#: 6971
2008 WRX STi
SSM
stock is 13.5 +/- 0.5 psi so 14 wouldn't be outside tolerance. Also, your boost gauge will almost certainly be different than what is read on the AP, it's usually about a pound different either way as far as I've seen. On my car the AP was a pound lower than my boost gauge so when my Greddy gauge read 1.22, the AP was showing about 16.2psi. I'd trust the AP a little more since it reads the MAP sensor and that's what the ECU is reading. Others have correctly pointed out that MAP sensor readings can change over the life of the sensor so if you want truly accurate measurments you need to periodically verify that whatever you're using to read boost is calibrated against an accurate reference.
supermarkus is offline   Reply With Quote
Old 10-05-2004, 01:23 AM   #6
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
Im running that map and getting a max boost of 16.8psi according to the AP, a lil on the high side, but my car is runnin great and feels fast.
imprzya is offline   Reply With Quote
Old 10-05-2004, 11:53 AM   #7
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
so i should plug the AP in and read live boost?
Old 10-05-2004, 09:46 PM   #8
WRXVII
Member#: 15854
VF34'd...
wait a few days until ECU learns. OEM boost gauge and AP live boost differ by 1psi...
WRXVII is offline   Reply With Quote
Old 10-05-2004, 10:39 PM   #9
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
highest i could get was 16.5, 15 others, and it would tapers hardcore at 5000 rpms, anyway i can make it hold on longer, cobb restrictor or wastegate adjustment?
Old 10-06-2004, 12:09 AM   #10
peterex
Member#: 27021
2015 WRX
Naw, your injectors and your turbo are incapable of operating at high boost levels in the upper RPMs. The boost tapering on the stock turbo is a safety measure employed by just about every reputable Subaru tuner on the WRX. Don't worry about it.
Old 10-06-2004, 12:39 AM   #11
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
I have my Accessport sitting on my desk right next to me but can't install because Cobb forgot to put the little blue connector in the box so I can initialize the thing to my ECU. Also, I can't get the thing to sync with my computer. It's a Dell 8250 adn I went through Dells support and they say the serial port is working fine (they can remotely access my desk top to run diagnostics). Anyone else have problems with connecting to your Commputer?
silver arrow is offline   Reply With Quote
Old 10-06-2004, 12:44 AM   #12
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Can't wait to install. Have uppipe,TBE, light pulleys, and IC hoses. Will the IC hoses and underdrive pulleys give me noticeably more power than the stage 2 without them. Anyone upgrade uppipe, IC hoses and pulleys after already having stage 2 for awhile? Notice a difference. Each of those upgrades is said to give about 5hp by themself, but I wonder if that is cumulative? I was also thinking about a Deadbolt P&P TD04. Should be within the ECU's ability to adjust. peak HP is same but comes on alittle faster from the dyno charts on Deadbolts sight.
Old 10-06-2004, 12:46 AM   #13
peterex
Member#: 27021
2015 WRX
When you run the AccessPort program on your PC, try selecting COM2 as your port - you might have your serial port configured differently.
Old 10-06-2004, 12:51 AM   #14
Turbo4Life
Member#: 22036
2002 WRX Wagon
WR Blue Pearl
peterex, in order for your accessport to sync up to your cpu you have to reflash your car first, then it will work.
Turbo4Life is offline   Reply With Quote
Old 10-06-2004, 12:54 AM   #15
peterex
Member#: 27021
2015 WRX
Oops, you're right. I remember now that I was unable to fool around with the AP on my computer until I flashed the car.
Old 10-06-2004, 12:56 AM   #16
dippi
Member#: 44424
2007 Impreza WRX
dirtiest crystal grey
i had the deadbolt turbo with the cobb stage 2, and it did not run any better, in my opionion it was acutally slower. it would boost quicker but not hold boost for as long as i wish it did, the stock one holds boost longer. only my experience.
dippi is offline   Reply With Quote
Old 10-06-2004, 01:27 AM   #17
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
I tried
Old 10-06-2004, 07:40 AM   #18
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Thanks, I will flash as soon as I get the little blue plug.
Just another Cobb AP Stage 2 flash appreciation thread ultraspdWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-16-2006 09:08 PM
05 STI AP stage 2 18psi 1,700 deg jnorth85 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 38 05-20-2005 01:47 PM
Unplug the EBC solenoid & install AP stage 2 tonight....but smootth Engine Management & Tuning 4 03-20-2005 04:10 PM
Just flashed Cobb Stage 2-93 octane. Quick question! the2rz Engine Management & Tuning 7 03-11-2005 08:30 PM
I flashed in AP stage 2 1.20.... bren wrx Engine Management & Tuning 1 10-11-2004 03:57 PM
