Old 10-04-2004, 11:01 PM   #1
Costas
Member#: 13760
1999 Impreza WRX
Rally Blue
Default Question on Installing V8 Brembos on MY 99 RS WRX Swap
With my swap done-
the car definitely needs to stop better, and the stockers arent up to the task.
Im going to pick up a set of USDM STI take offs this week...I have done some research (r180 hubs/axles/differential/driveshaft/)but I would like to confirm a couple of things, and pose a question.
Interesting fact on my rear calipers -
I know the rears arent a direct bolt on, but in my case (at least Im hoping) there seems to be something different going on.
Two years ago when I did the pads, I noticed that the regular Impreza pads did not fit. I turns out I may be using Forester calipers in the back (Only Forester Pads worked ) The Impreza pads I originally bought were completely different (smaller/different tabs) and wouldnt work with the calipers. So I guess that may or may not work in my favor.
This may have come like that from the factory or swapped out from the previous owner ---
Does anyone know the forester mounting brackets any different? (Im secretly hoping that they would bolt up to the STI two pot rears)
Also, I've been told that the Fronts are direct bolt on- just looking for a confirmation to make sure I have everything I need for the switchover.
Thanks!
Costas is offline   Reply With Quote
Old 10-04-2004, 11:50 PM   #2
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
eer, sorry to disappoint you but I used impreza rear pads on my Forester rear brakes
Hyper is offline   Reply With Quote
Old 10-04-2004, 11:59 PM   #3
Costas
Member#: 13760
1999 Impreza WRX
Rally Blue
could it be??? Our cars brakes were switched??? EEK!!
hehe
Old 10-05-2004, 01:26 AM   #4
punkrocksailor
Member#: 43376
The fronts are a direct bolt-on as long as they are from a USDM STi, if you buy the STi gold kit from Brembo for some reason they come with bolts that are too long. If you buy the Gran Turismo kit with the black or red calipers and two-piece rotors you're fine; but for some reason the gold kits with the drilled one piece rotors make us go to the hardware store when we have to install them.
Cheers,
Joel
punkrocksailor is offline   Reply With Quote
Old 10-05-2004, 07:36 AM   #5
Costas
Member#: 13760
1999 Impreza WRX
Rally Blue
Cool...
Thea rears are another story all together
Old 10-05-2004, 11:12 AM   #6
wrxtreme2
Member#: 71896
I was going to do this, but someone told me if I just do the fronts the brake bias will be all messed up.
wrxtreme2 is offline   Reply With Quote
Old 10-05-2004, 02:48 PM   #7
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
very true
I had bias with my STI 4pots
Old 10-05-2004, 02:58 PM   #8
Costas
Member#: 13760
1999 Impreza WRX
Rally Blue
you mean that the brake bias was thrown off?
What did you decide on doing in the end?
Old 10-05-2004, 03:31 PM   #9
wrxtreme2
Member#: 71896
yeah because you will still have the small stock rear calipers. It's best to go with a aftermarket setup, those are engineered to work properly with the stock rears and keep the brake bias. With the sti brembo's, your fronts will lock up way too fast.
Old 10-05-2004, 04:15 PM   #10
Costas
Member#: 13760
1999 Impreza WRX
Rally Blue
Well, Ive got an email from someone who says that these will indeed mount using h6 legacy bscking plates...anyone do this?
getting ready for ej20 swap in my 99 rs jonnyquest Subaru Conversions 0 05-19-2010 12:01 PM
HYDRA installed in my 99 RS-T... Mariano Normally Aspirated with bolt-on Forced Induction Powertrain 0 02-20-2009 12:10 PM
Installing STi Brembos on a WRX questions..... Alan l. Brakes, Steering & Suspension 4 03-30-2006 01:52 PM
my new rims on my 99 RS golfs2good Member's Car Gallery 12 03-20-2004 09:14 AM
looking to upgrade my suspension on my 99 RS ILUVMY2.5RS Brakes, Steering & Suspension 2 06-18-2002 07:53 AM
