Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 06-20-2001, 04:04 PM   #1
matts2.5rs
Member#: 7067
2004 GTO
Torrid Red
Default What Gauges should I get????????
what gauges should I put in the center gauge pod. I will never get a turbo. Should I get a S-AFC or just go with oil temp, oil presure, ???????? What do you like I should get? I want to do this, this weekend so please help.
matts2.5rs is offline   Reply With Quote
Old 06-20-2001, 04:13 PM   #2
Fish
RIP Sirkbac
Member#: 869
1987 GPZ-750 TURBO
90' MX-5/11' DGM STi Sdn
I'd say...
if you HAVE to get some.. get an EGT gauge, oil pressure, oil temp.
but really all you need is an EGT if you're going to be doing some tuning. but one gauge looks lonely.
Fish is offline   Reply With Quote
Old 06-20-2001, 04:17 PM   #3
matts2.5rs
Member#: 7067
2004 GTO
Torrid Red
How easy or hard is it to install three gauges in the center pod. Never put gauges on before.
Old 06-20-2001, 05:12 PM   #4
zzyzx
Member#: 815
2013 Boss 302 White
2008 S2000 CR ABP
I've decided on EGT, oil pres. and A/F ratio. A good setup for tuning.
- Steve
zzyzx is offline   Reply With Quote
Old 06-20-2001, 11:39 PM   #5
Fish
RIP Sirkbac
Member#: 869
1987 GPZ-750 TURBO
not too hard of an install.
just have to make a plate for it..
I've only got one gauge up there right now.. so I'm using the custom ziptie mount till I get more gauges and have a reason to make the backing plate.
Old 06-21-2001, 01:34 AM   #6
SubaDan
Member#: 6631
2000 ImprezaRS Sedan
Cool
Ok since your noot getting a turbo put in nitrous. Lots cheaper. then you can put in a Nitrous pressure gauge. by the way. anyone know where to get a good NOS pressure gauge.
SubaDan is offline   Reply With Quote
Old 06-21-2001, 11:22 AM   #7
joostin420
Member#: 1046
2007 WRX Wagon
UGM
Lightbulb
follow this link, it should solve a lot of questions about installing a center gauge pod:
http://www.i-club.com/forums/showthr...threadid=63598
these intructions took a while to come up with, but it was a good experience. if anyone has any good info. for the WRX pod let us know.
thanx,
justin
joostin420 is offline   Reply With Quote
Old 06-21-2001, 06:35 PM   #8
Longshot
Member#: 2359
2001 Impreza 2.0 WRS
EGT, Oil Pressure, Water Temp..
EGT's are vital for tuning.. the oil pressure is always a good idea period.. and the last is your choice, I just chose water temp personally..
Korey
Longshot is offline   Reply With Quote
Old 06-21-2001, 06:57 PM   #9
cakagan
Member#: 251
1998 Impreza 2.5 RS
Question Dual gauges
What company makes the dual gauges (two readouts on one gauge), and what 6 readouts would you need for N/A?
EGT
Oil Temp
Oil Pressure
A/F Ratio
Water Temp
(from this thread's recommendations)
Is A/F Ratio and Water Temp good to have for tuning, if staying N/A?
Thanks,
-Chris
cakagan is offline   Reply With Quote
Old 06-21-2001, 07:50 PM   #10
Longshot
Member#: 2359
Water Temp is useful for staying N/A yes... A/F is fine and dandy, but speaking from experience its a built difficult to use in a closed loop system like we have.. the little light ends up flashing all over the place except at WOT, it just doesn't provide enough info for the price.
Korey's .02 cents.
Old 06-21-2001, 08:06 PM   #11
WRSport
Member#: 2060
00 2.5RS Coupe
01 black boxster hardtop
electronic Dual Guages can be found below.
These guages run about $240 a piece, at least for a dual Oil Temp and H20 Temp.
Link to SPA Dual Guages
WRSport is offline   Reply With Quote
Old 06-21-2001, 10:45 PM   #12
rbehny
Member#: 1908
ok lets say that you have a s-afc and aren't sure if your going turbo or not. So from the majority of responses an egt gauge is a definite. The next would be a ??oil pressure?? then the final would be my choice...could i just put in a boost gauge and leave the wires disconnected since i don't have a turbo? I really want to do everything at one time so i don't have to go opening up the dash every other month. Thanks...
rbehny is offline   Reply With Quote
Old 06-22-2001, 11:55 AM   #13
subenutt
Member#: 930
99 Impreza 2.5RS
Exclamation
*Warning*
Matt, you've got a MY99. If you plan on doing an intake, or already have one on, you NEED the S-AFC.
MY99's are known for running extremely lean above 5k RPM. Not only is this a loss in hp, but can be fatal to your motor. More detail can be found in old Sport Compact Car (Impreza Build Up) Articles, and/or by doing a search here.
I would recommend the S-AFC to control the fuel delivery before any other guages.
After the S-AFC......
EGT
Oil Temp
Water Temp.....
I've got the S-AFC, but if your not 'sold' on this... contact Rallispec or Cobb Tuning and ask them.
subenutt is offline   Reply With Quote
Gonna Get Tuned Think I Should Get Bigger Injectors- What Size Should I Get? ScoobyNubieToo! Engine Management & Tuning 13 01-08-2009 10:58 AM
What Gauges Should I Get? Acejam2k Electrical & Lighting 3 01-11-2007 10:13 AM
What Gauges Should I Get jzsurfer5 Newbies & FAQs 15 11-08-2005 05:59 PM
What gauges should I get? subrandon General Community 5 06-01-2004 12:46 PM
Local peeps--what gauges should I get? (egt, oil temp, etc.) well_armed North West Impreza Club Forum -- NWIC 18 05-20-2003 03:35 PM
