Old 10-15-2012, 01:56 PM   #51
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Originally Posted by NateLS1 View Post
I don't think so. The turbo won't build any pressure if the exhaust goes freely around it. Disconnect your wastegate so it stays open, go for a ride. You will not see hardly any boost at all. I've had this happen to me.
That's what the WG springs are for. Once you overcome the spring pressure...the gates open (especially wot). He is right
wgr73 is offline   Reply With Quote
Old 10-15-2012, 02:21 PM   #52
04wrexsti
Member#: 225937
15 Mustang GT
All subies gone
Originally Posted by Badler View Post
I would imagine. If you think about when you are WOT the wg is shut for the most part.
go listen to any EWG car and tell me that under WOT the wastegate isnt piss wide open? lmao.
04wrexsti is offline   Reply With Quote
Old 10-15-2012, 06:26 PM   #53
decodeddiesel
Member#: 64102
I'm sorry but it seems you have a misunderstanding of how turbo chargers actually work.
decodeddiesel is offline   Reply With Quote
Old 10-15-2012, 08:48 PM   #54
NateLS1
Member#: 132380
2004 WRX
rojo
Clearly I didn't picture what you said in my head correctly. I just envisioned a wide open waste gate allowing the exhaust to go around the turbo not allowing it to spool. Not the fact that it was maintaining boost. My mistake.
NateLS1 is online now   Reply With Quote
Old 10-15-2012, 09:09 PM   #55
Badler
Member#: 133597
Maybe you misread me? I said the most part which was bad wording. Unless you're trying to run low boost on a large turbo, that thing isn't wide open. Some have trouble keeping them shut at high boost on stock turbos.
Badler is online now   Reply With Quote
Old 10-15-2012, 10:47 PM   #56
decodeddiesel
Member#: 64102
Listen, I am not trying by any means to get into a pissing match with you. If I am understanding correctly what you are writing you are simply not correct.
For example on my car, when I hit 14.7 PSI of boost my wastegate opens (Tial with 1 bar springs) and it stays open at any pressure higher than 14.7 PSI. The boost controler may modulate the wastegate slightly, but for the most part it is wide open. If you were to close the wastegate at high boost you would over boost like crazy and probably overspeed the turbo/blow the engine/etc.
Old 10-15-2012, 11:26 PM   #57
NateLS1
Member#: 132380
2004 WRX
rojo
I think the key fact here is the wastegate is modulated. It is certainly open at target boost, but not necessarily WIDE open and it must close slightly and open slightly to maintain boost.
And what I meant by disconnect your wastegate in my first comment was physically detach the flapper from the arm, not disconnect the pressure feed which would cause an over boost condition due to the wastegate not opening at all.
Latest dyno results: 145hp, 144ft-lb on Mustang dyno Patrick Olsen Normally Aspirated Powertrain 39 08-27-2008 03:19 AM
flat flange dp vs bellmouth vs divorced ... power gains? si12j12 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-01-2007 01:22 AM
Dyno results: Injen CAI vs. "Torque Box" CAI Patrick Olsen Normally Aspirated Powertrain 45 08-13-2007 12:39 AM
Flat plate vs. bellmouth? sovietjet Newbies & FAQs 48 01-18-2006 01:55 PM
Comparing dyno results: 50F vs. 90 F day superg Proven Power Bragging 2 06-22-2005 10:16 PM
