Old 10-06-2004, 03:34 AM   #1
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Default Will a Phase I DOHC run using a Phase II SOHC ECU?
Seeing Matt Monson's thread about I-speed's RS ECU reflashing has me wondering about my tuning options. As it is now there are tuning options available for the '99-01 RS's (SOHC) using the I-speed RS Reflash, and for '01+ cars of all flavors (all SOHC for the N/A cars) using EcuTek Reflash, but nothing for the DOHC Phase I ECUs. So I'm thinkin' I could just get myself a SOHC ECU, and then use the reflashing capability to improve performance. I just don't know how different the ECUs actually are, or if a newer ECU would even install in my car. Would I need to completely re-do the wiring harness, or are the pin-outs the same? Etc etc etc...
Pat Olsen
'97 Legacy 2.5GT sedan
Old 10-06-2004, 10:20 AM   #2
ruskiyab
Member#: 55128
2007 Impreza WRX
I'm no tech or anything, but I imagine it would not work because the fuel maps would seem to be completely different, also the phase 1 uses a MAF sensor, an 00+ ECU will be looking for a different signal from a MAP, idk, though, I just wouldnt think itll work
ruskiyab is offline   Reply With Quote
Old 10-06-2004, 12:54 PM   #3
jeffg
Member#: 2958
2001 WRX (GC8)
The ECU will work, but you will need to swap out several sensors. Some that come to mind:
MAF-> MAP
cam position sensor
I know there was a whole list, I looked at doing the same thing, but the other way. sohc with dohc ecu.
jeffg is offline   Reply With Quote
Old 10-06-2004, 06:05 PM   #4
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Isn't phase II early99+? If so, why would he have to swtich sensors?
jamesfacts is offline   Reply With Quote
Old 10-06-2004, 06:08 PM   #5
Porter
Member#: 486
2004 Forester XT
bug spattered
It's not that simple... some Phase II motors used MAP ('00+) and some used MAF (99). Those cars have different ECUs.
I would think that a '99 RS ECU would work in your car, Pat, but not a later ECU unless you swapped over all the sensors it needed.
The Hydra EMS Nemesis should work, they support the '98+ RS which includes the DOHC Phase 1 just like yours. You'll probably have to custom wire it to fit your harness, but that's no big deal.
Porter is offline   Reply With Quote
Old 10-06-2004, 06:26 PM   #6
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
If you're looking to buy a 2000 RS ECU, I have one.
garface is offline   Reply With Quote
Old 10-07-2004, 02:41 AM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I hadn't heard of the Hydra before, did a quick search and I see lots of posts over in the Engine Management forum. Looks like I have some reading to do. You're sure they offer it for N/A cars - their website only lists WRX and STi.
Pat
Old 10-07-2004, 03:17 AM   #8
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Pat
lots of the AFI guys are running them. they seem to like they hydra. I looked at the site, the software seems easy to use.
subiekid is offline   Reply With Quote
Old 10-07-2004, 10:12 AM   #9
Porter
Member#: 486
2004 Forester XT
bug spattered
http://www.hydraems.com/ems-index.html
Hydra is the company who makes the hardware and supports it.
Phil Grabow at Element Tuning has been customizing these for the WRX and STi and providing custom maps. He is a dealer/distributor for Hydra.
Contact Hydra directly and see who they would recommend to integrate the unit for you and what you could expect in terms of tuning and power delivery on a Legacy.
Old 10-07-2004, 11:32 AM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Ahhh, I see. Thanks for the clarification, Porter, I had just seen the Element Tuning links in the threads I browsed through.
Pat
Old 10-07-2004, 06:16 PM   #11
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
I believe a hydra would eliminate the need for a reflash, because you'd basically be replacing your ECU with the hydra. The goal, I assume, would be to keep a stock ECU and just flash it.
ilmaestro is offline   Reply With Quote
Old 10-08-2004, 12:26 AM   #12
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Well, I don't necessarily have to keep my stock ECU. The car just doesn't run right, and has gotten progressively worse over time. The car has a band where it hesitates and pulls timing - used to be it was just a small portion of the mid-range, now it happens all the way up to 5000rpm. Very annoying, and seriously restricts the mid-range power of the car.
Pat
Old 10-11-2004, 01:27 PM   #13
Section 8
Member#: 821
Cam sensor is a generic Hall effect sensor. The cam pulley has a different number of teeth/nubs (whatever you want to call them) on the back to locate the cam.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Phase I DOHC to Phase II SOHC swap jnorth85 Subaru Conversions 4 04-23-2008 07:16 PM
PA: EJ25 SOHC Phase II Block, ECU, etc. MMastro 1993 - 2001 Impreza Specific Parts 13 11-08-2007 08:15 AM
DOHC heads running on SOHC ecu-CAN IT BE DONE!? turboL Built Motor Discussion 7 12-20-2006 02:47 AM
Phase I DOHC/MAF and Phase II SOHC/MAP pin-out diagrams? Patrick Olsen Normally Aspirated Powertrain 7 02-09-2006 05:23 PM
phase 1 DOHC heads or phase 2 DOHC heads.. whats better to use? YaZahX Normally Aspirated with bolt-on Forced Induction Powertrain 11 03-05-2003 06:16 PM
