Old 10-06-2004, 04:29 PM   #1
CitySubie
Member#: 60099
2003 Impreza RS
The perty blue one
Default Head gasket might be blown
How hard of a job is this to fix. The dealer said that there might be a leak in the head gasket. If so, I'm looking at a $1100.00 job. Plus $200.00 to "resurface" the heads. Whatever that means. OUCH!!!
If this is the case are there better replacement gaskets that are less prone to breaking, or stronger than stock for people with a heavy right foot?
CitySubie is offline   Reply With Quote
Old 10-06-2004, 04:30 PM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
2001 2.5 RS/70 Van
02 WRX Rally Stud
what year, and model do you have
Old 10-06-2004, 04:48 PM   #3
CitySubie
Member#: 60099
2003 Impreza RS
The perty blue one
2003 Impreza RS in a pretty blue color.
Old 10-06-2004, 05:19 PM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Should'nt that be under warranty?
Tim Sanderson is offline   Reply With Quote
Old 10-06-2004, 05:25 PM   #5
robsgotit
Member#: 59674
06 06/2.5i 03/1.8t
there silver
wwwwwaaaaaaaaarrrrrrrrrrrrrrrrrrrrrrraaaaaaaaaannn nnnnnnnntttttttttttttyyyyyyyyy! for sure, unless youve got over 60k somehow
robsgotit is offline   Reply With Quote
Old 10-06-2004, 05:31 PM   #6
CitySubie
Member#: 60099
2003 Impreza RS
The perty blue one
My 2003 has 69,470 miles
Old 10-06-2004, 06:02 PM   #7
jamesfacts
Member#: 51282
98 RS
black & blue from parking
HGs aren't awful, but there not easy either. You will have to pull the motor and likely bring the heads to a machine shop to have them resurfaced.
Hate to say it, but its possible a search might reveal something....
jamesfacts is offline   Reply With Quote
Old 10-06-2004, 06:38 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Was the '03 not covered under the 100k mi recall extension? If so, that bites. I got my HG replaced under warranty with 99,987 mi on the car. That's when the cams went in. If you have ever considered doing cams on your car, now would be a good time while the engine is out and in pieces...
Old 10-06-2004, 06:53 PM   #9
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
The cam girdles require a special tool. It's a torx plus. On the sohc heads you don't have to mess with the cams to remove the heads. I doubt you'd need to resurface the heads. Just use a good gasket scraper and get all the old material off. 3m makes a nice one that can be used in a drill.
If you have the means to get the engine onto an engine stand then the rest is cake. You would need the correct torque specs and torqueing sequence, and a torque wrench. But it's not tough at all. I did my own and it cost me a day and 50$.
Good luck.
Old 10-07-2004, 09:43 AM   #10
CitySubie
Member#: 60099
2003 Impreza RS
The perty blue one
What is this 100k mile recall extention that you skeak of Matt?
Old 10-07-2004, 09:44 AM   #11
CitySubie
Member#: 60099
2003 Impreza RS
The perty blue one
Speak of.
Sorry. No can spell to much good.
Old 10-07-2004, 10:14 AM   #12
CitySubie
Member#: 60099
2003 Impreza RS
The perty blue one
One other thing. I posted a tread regarding a CEL. The code that came up was P0483, cooling fan problem.
I took it to the dealer to get the CEL turned off and to check if everything is running fine. I would love to do all the work on my car myself If I knew how and if I had the time, but I can't. Anyway, the head gasket problem is what they came up with. Is that possible. They also told me about there was a noise coming from the tranny, but they can't tell me what it could be without taking it apart. Make sense.
What sucks is that while it was under, I was told that everything was fine. Now that warrenty is over, they found all this work that needs to be done.
Those bastards.
Old 10-07-2004, 10:26 AM   #13
Jejunum
Member#: 15773
2011 Impreza WRX
dude thats CRAP. i have an 02 RS (26k miles) and im constantly worried about the possibility of hg failure. write a letter to subaru, thats unacceptable quality imho. did they document your concerns about hg before you ran outta warranty?
if nothing, i say spend the extra and go the 2.0 turbo swap :/
Jejunum is offline   Reply With Quote
Old 10-07-2004, 10:39 AM   #14
CitySubie
Member#: 60099
2003 Impreza RS
The perty blue one
I love my Subaru, but their sevice is crap
Old 10-08-2004, 10:11 AM   #15
CitySubie
Member#: 60099
2003 Impreza RS
The perty blue one
Is it true that you can see "white smoke" (I'm assuming it's a mix of smoke and steam) if my HG is blown?
Old 10-08-2004, 06:28 PM   #16
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Do you smell coolant after a drive at all? Or do you see white smoke out the tailpipe? Does your coolant reservoir constantly need to be refilled? How did they determine that the hg was bad?
Blown head gaskets, warped heads and a piston melted to the cylinder wall Borjaq Warranty Issues & SOA Problems 13 05-22-2010 10:16 PM
Which head gasket will be most reliable for 2.5 / 2.2 hybrid? JoshP Normally Aspirated Powertrain 8 06-02-2006 03:27 PM
Class Action Lawsuit Re: Blown Head Gaskets/ Cracked Heads/ Overheating oldblackbeard Legacy Forum 22 01-13-2005 12:18 AM
Shocks/Struts might be blown for 02 RS? balajc Brakes, Steering & Suspension 5 12-29-2002 11:49 PM
Blown RS Now with matching blown head gasket. 5252 Technical Forum Archive 66 09-18-2000 10:46 AM
Message Board Statistics All times are GMT -4. The time now is 12:52 PM.
