Old 06-20-2001, 10:34 PM   #1
Motohead1
Member#: 5121
1987 Monte Carlo SS
Primer grey
Question N/A Newbie Question
Hi Guys I am looking into getting a used Impreza (old body style) 2.5 RS. Forgive me I am a V8 guy and I know very little about Subys but I do know that I dont want turbo cause of lag and this car would be driven daily and used for autocross and i need touque. I was wondering what are the best years and what are things i should look out for? Also Are there reliable Supercharger kits out there? Any superchaged Impreza peps out there I can ask my many questions? Thanks
Jay
87 MC SS 6 speed with a cup holder!
Forever 3
Motohead1 is offline   Reply With Quote
Old 06-20-2001, 10:40 PM   #2
preza
Member#: 1454
2000 2.5 RS-T
I would say the best year to get, if you can afford it is a MY00. The 99's had the intake issue. There are no "reliable" supercharger kits out there right now. There is only a handfull of SC'ed 2.5rs running around a couple are on this board.
preza is offline   Reply With Quote
Old 06-20-2001, 10:46 PM   #3
Overtime
Member#: 1346
If you're staying naturally aspirated, I would definitely go with a MY00/01.
If you're going with a turbo, the MY99 is actually your best bet because of the stage 2 block and no pain in the butt MAP sensor.
There aren't any supercharger kits out yet. As always, we patiently wait for the ones in "development" to emerge.
Overtime is offline   Reply With Quote
Old 06-20-2001, 10:51 PM   #4
Motohead1
Member#: 5121
1987 Monte Carlo SS
Primer grey
Unhappy Dang no good superchager kits?
Its hard to beleive theres no good SC kits out there? Theres plenty of turbo kits. right? Well is there turbo kits that are geared toward quick spool-up and little lag for autocrossing? Thanks
Jay
Forever 3
Old 06-20-2001, 11:10 PM   #5
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
a turbo will still work well, in autocross, you just have to get used to driving in the upper power band.
There are superchargers that will work, but they are either very expensive, or they kits suck. You'll probably find Rimmer, if you do a net search, but stay away from that guy. There's an australian company that does a SC kit that's supposed to work pretty well.
If you can do the work yourself, and don't need a kit, the smaller eaton SC will work.
gavin is offline   Reply With Quote
Old 06-20-2001, 11:28 PM   #6
Motohead1
Member#: 5121
1987 Monte Carlo SS
Primer grey
Cool Work whats that?
I can install a kit on the car myself. But I would rather stay with a kit thats been tuned for the car cause I dont know much about these cars yet. Caint be to hard. So a good SC kit (austrailian I assume) is about as much as a turbo kit? Well looks like more research.
Jay
Forever 3
Old 06-21-2001, 07:55 AM   #7
SilverSuby
Member#: 1599
2000 Impreza RS
Post Superchargers - not yet !
There are several of us that are patiently waiting for an s/c kit to come out. Personally I'm waiting for my warranty to expire, or I'd already have one.
Check the private classifieds, frequently someone tries to sell them there.
I think I'd suggets beefing up the engine internals before slapping on a turbo or a s/c. You can get the car up to around 200 HP's with just intakes, exhaust, headers, etc. After that, you can throw a s/c on and you'll get even MORE power out of one.
I'd go with the 2000...in fact, I did! It doesn't have the MAF which caused quite a bit of problems with intakes, and it's got the Limited Slip Differential.....it was the first year for it.
SilverSuby is offline   Reply With Quote
Old 06-21-2001, 10:20 AM   #8
Motohead1
Member#: 5121
1987 Monte Carlo SS
Primer grey
Thumbs up 00/01 years
Limited slip! Allright theres a plus! Was it standerd or optional? Ok so for what I want to do looks like MY 00/01 2.5 RS is what I am looking for? Now what I need to know is what things break and where quickly. Also what can I expect to pay for one in the 50-70,000 mile range? Thanks. I know its a lot of questions but I am learning
Jay
Forever 3
Old 06-21-2001, 11:41 AM   #9
s-one
Member#: 7482
2012 Acura TL-SHAWD
Default problems
Well i have a MY00 .... havent really run into any problems yet ... only weird thing is my airbox, the clamps dont wanna stay on .....i'm at about 19k miles so far ... oh one thing that does go wrong ... o2 sensor.... u will need to get that replaced if it hasnt already
s-one is offline   Reply With Quote
Old 06-21-2001, 12:02 PM   #10
dirk.gecko
Member#: 3141
2007 Scion tC
Blue or something
Default okay, short newbie list of things for subies
1. 98 & 99 used the MAF sensor, which works well with turbos, but not aftermarket N/A intakes. 00 & 01 use the MAP, which is more durable, but tends to run rich.
2. The engine itself is more or less bulletproof. 300hp out of an otherwise stock engine have been attained (91+ octane, a must) The clutch and gearbox, on the otherhand, have to endure the stress of the AWD system. Clutches regularly go to pot around 70,000mi (even on NA cars), and 2nd gear in a manual can't take much more than 8-10psi before it turns itself into small pieces. There are some stronger aftermarket clutches (ACT) available for good prices, and it doesn't sound like you plan on running huge boost even if you decide to go forced induction.
3. If it still has the original RE-92 skins, put them on the curb. Kumho makes a tire that is sized well to the RS, and its gotten a lot of good press from the locals on the board. As always, tires are a personal thing, tho. And oh yeah. 215's fine, but 225's are a huge squeeze.
4. Don't forget that the 98-01 RS's are just 2800lbs in full trim. That's not all that much, if you're used to driving a Monty. Combined with the 4.11 gearing and the wide torque, she scoots about rather well as it is. The upper end does suffer a bit from breathing issues, but thats easy to fix.
dirk
PS: I'm sure someone else will chime in.
dirk.gecko is offline   Reply With Quote
Old 06-21-2001, 02:55 PM   #11
Kurtaliscious
Member#: 7694
2001 2.5 RS Coupe
Silverthorn Metallic
Check out the SPD Tuning website http://www.spdusa.com/, under the "Techical Information" section. There is a lot of good information about subies and modifications to them.
Kurtaliscious is offline   Reply With Quote
Old 06-25-2001, 06:30 PM   #12
Motohead1
Member#: 5121
1987 Monte Carlo SS
Primer grey
Cool Thanks!
Cool Thanks. All good points. Havent decided exactly what year I want and what future mods I want but Yall have given me stuff to ponder. Thanks again
Jay
Forever 3
Old 06-25-2001, 11:09 PM   #13
AndresRS01
Member#: 2401
2002 Toyota Mr2
Default Well....
...I own a 2001 RS with almost all the goodies that Cobb Tuning has to offer. That is one of the reasons why I don't have a WRX, beside the fact that I love my car's body. But if money wasn't a factor , and I didn't own an RS, I'll be buying a WRX. Even knowing that I already beat some of them on the street and track.
They were almost stock; man you shouldn't worry about turbo lag, Cobb has different affordable ways to get rid of that almost completely. A WRX has a lot of potential.
Now don't take me wrong I love my N/A and still have some more room for improvement.
On the other hand a WRX will never beat a well done turbo installed on an RS.
Now if you find a reliable S/C go for it and later tell me where did you find it, I autocross and will love to have it.
Andres
AndresRS01 is offline   Reply With Quote
hi, newbie, who just have '03 new forester, has some newbie questions! White95NA8C Forester Forum 6 04-25-2003 02:46 PM
Newbie Question. :) thepawn Tri-State Area Forum 4 06-05-2001 07:18 PM
Everyone who loves stupid newbie questions, click here! SubieKidTK Legacy Forum 4 04-11-2001 09:49 AM
Chi-town stereo installation newbie question. Cjchaps Mid West Subaru Owners Club Forum -- MWSOC 4 03-22-2001 02:41 PM
Newbie Question ahson Canada Region Forum 1 01-05-2001 09:57 PM
