Old 06-20-2001, 11:07 PM   #1
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
Unhappy Help me decide! Silver GT 5-speed
I can get a Silver GT 5-speed with 59000 miles for $10200. It is in perfect shape and runs great. The problem I have is how much I hear about crankshaft seals going out and some kind of piston slap. What would you do? If the camshaft needs replacement down the road how much $? What is the piston slap and how much to fix it?
HIHO is offline   Reply With Quote
Old 06-21-2001, 09:06 AM   #2
lucien2
Member#: 1519
1998 Volvo V70R
You emailed me, but I'm going to post the response because others here know a lot more about it than me.
In phase I ej25 engines (DOHC), Subaru made the piston skirts too short, and the suckers have a tendency to slap around a chew up the inside of the cylinders. For the Legacy, sometime in 1999 Subaru equipped cars with DOHC Phase I heads on Phase II blocks. For anything earlier, SoA will, after some prodding, replace the engine block. I have not had the problem show up in either of my '99s, so I have only tangentially followed the problem. Mr. Rubel can certainly sound off about the problem, how to spot it, and what the fix is, yes?
lucien2 is offline   Reply With Quote
Old 06-21-2001, 02:00 PM   #3
dvancleve
Member#: 5211
2007 Outback XT Ltd.
Diamond Gray Metallic
Question Phase I block replacement
Does Subaru replace shortblocks that develop piston slap when the warranty has expired? They should, but it seems to me that they probably don't. I ask because I have a '97 that is out of warranty. Unless the piston slap is very subtle my car is fine, but it only has 45K miles on it. I have used 10w30 synthetic since <10K miles. Maybe that helps?
Thanks, Doug
dvancleve is offline   Reply With Quote
Old 06-21-2001, 02:05 PM   #4
silverSurfer
Member#: 1361
1999 Legacy GT Ltd.
2006 Rav4 Sport Silvarrr
Unhappy
just wondering, how can u tell that this problem is occuring??
silverSurfer is offline   Reply With Quote
Old 06-21-2001, 02:11 PM   #5
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
dvancleve-Subarus come with a 30,000 bumper to bumper and a 60,000 mile powertrane warranty. Piston slap and blown short blocks fall in the Powertrane(anthing covered in oil) warranty.
I have a 99 GT that RalliSpec confirmed that it has the high flow phase-I DOHC heads and the strong phase-II block.
Thanks
Brad
MY99 2.5GT is offline   Reply With Quote
Old 06-21-2001, 02:13 PM   #6
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Somebody PM Subi-Gal. She had a 99 GT blew the engine and had to have it warranty replaced. Ask her about symptoms also.
Old 06-21-2001, 02:26 PM   #7
gumball
Member#: 1209
On the other issue, I had my oil seals go (covered under powertrain) at about 59,000K. There are several seals that can and may fail on the Subaru engines- Camshafts, crankshaft and oil pump. All of these would show up as oil beads on the underside of the block betw. the timing belt cover and engine(in front).
I suspect my switch to synthetic at 50K+ miles may have helped cause this.
rats, does anyone else have trouble TYPING on the new board? its like my keyboard is on "delay".
gumball is offline   Reply With Quote
Old 06-21-2001, 02:41 PM   #8
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
I would immagine this new board uses more resources which will probably slow your computer down a little. That is unless you have resources to burn.
Aquamist HFS-1 or HFS-5. Help me decide for my 07 STi! rhinotech Water/Methanol Injection, Nitrous & Intercooler Cooling 14 02-27-2008 11:46 PM
Aquamist HFS-1 or HFS-5. Help me decide for my 07 STi! rhinotech Water/Methanol Injection, Nitrous & Intercooler Cooling 0 02-16-2008 07:20 PM
1988 mustang 5.0 gt 5 speed new motor new paint - $6500 wrxben Private Vehicle 'For Sale' Classifieds 0 02-03-2004 03:07 PM
Help me decide which Rotas: Silver SDRs or Steel Grey with machined lip Subzeros Moses Interior & Exterior Modification 15 03-19-2003 05:57 PM
WHICH exhaust for me??help me decide Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-12-2002 11:42 AM
