Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 10-06-2004, 09:21 PM   #1
Member#: 53526
1997 Impreza
Default hesitation after starting engine
About 5-10 seconds after I start my car it hesitates so bad it won't accelerate unless I'm at WOT. After it's done with it's "fit" it runs fine except there's a very slight hesitation, almost a misfire, noticed moreso at about 30 in 3rd gear. If I start the car and let it idle it'll start hesitating about 5-10 seconds after starting it. Once it's done with it's "fit" the rpm's will jump to 1500-2k and go down to normal idle. There is no hesitation at idle at all. Here's a list of things I've changed, ECU, both O2 sensors, knock sensor, MAF, coil, spark plugs, plug wires, fuel filter, fuel pump, cam sensor, crank sensor, fuel injectors. That's all I can think of right now but I'm sure there's more. I always run 91+ octane. Anyone with any ideas please help.
mybluesubi is offline   Reply With Quote
Old 10-07-2004, 10:19 AM   #2
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
timing off? maybe a bad injector if you're getting a misfire...
CEL on?
marcus12 is offline   Reply With Quote
Short hesitation after start, idles fine hex2bit Service & Maintenance 0 04-20-2009 09:52 PM
Trouble to start engine after gaz tank fill-up Drummer Normally Aspirated Powertrain 7 12-30-2008 04:38 PM
EJ22 Trouble Shooting: Engine won't stay on after 5-9 sec after start FuJi K Normally Aspirated Powertrain 7 03-04-2005 07:13 AM
Hesitations when starting engine popnGEAR Normally Aspirated Powertrain 3 10-04-2002 08:37 PM
Loud engine noise after start up kalex Newbies & FAQs 10 09-13-2002 12:48 PM
