Old 10-06-2004, 11:30 PM   #1
bahboy20
Member#: 6726
Default location of vacuum line
Hi, I was wondering if someone could direct me to the vacuum line (air) on a 2.5 RS. I am clueless to where it is. I have found a picture of a 2.5 RS engine bay, perhaps someone can mark on it where the vacuum line is?
Thanks a lot!
Dan
bahboy20 is offline   Reply With Quote
Old 10-07-2004, 12:03 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
AIR pressure line? I'm not sure what you're looking for, but there shouldn't be any pressure line on a N/A motor. Vacuum lines? yeah, a whole bunch.
Could you be describing something else?
Jay Storm
Old 10-07-2004, 02:02 AM   #3
bahboy20
Member#: 6726
Default yes
yes, can you point out the vacuum line locations in the picture?
thanks for your help
dan
Old 10-07-2004, 02:11 AM   #4
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
Are you asking about the Air Conditioning High Pressure line?
That would be the Black Rubber-covered line going forward from the A/C compressor near the battery.
SubyTechMaster is offline   Reply With Quote
Old 10-07-2004, 02:24 AM   #5
bahboy20
Member#: 6726
Default sorry
no, i meant the vacuum lines...
anyone?
dan
Old 10-07-2004, 02:30 AM   #6
Laugh Damon
Member#: 69010
2008 obxt
If I remember... there was a sticker stuck on the hood which showed the vacuum line routes. It might have been my old toyota though, worth a shot I guess.
Laugh Damon is offline   Reply With Quote
Old 10-07-2004, 04:59 AM   #7
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
If you have a stock airbox then follow it to the throttle body and along the way look for hoses coming out of it, if not look at the heads of the motor and theres a tube coming out of that as well with a thing that secures it there that looks like a clothes pin. in the picture just follow the intake tube and there has to be a vaccum line coming out of it.
Derk1127 is offline   Reply With Quote
Old 10-07-2004, 10:18 AM   #8
bahboy20
Member#: 6726
Default size
i was under the impression that the vaccum lines were small lke 1/4" hoses, not the large one with the paperclip thingy on it?
dan
Old 10-07-2004, 11:29 AM   #9
OneOBS
Member#: 63076
2004 Outback Sport
Red!
dan
You are correct. The large ones with paperclip thingy on them are the breather tubes.
OneOBS is offline   Reply With Quote
Old 10-07-2004, 11:31 AM   #10
bahboy20
Member#: 6726
Default ok
so where are the vacuum lines if its not the one with the paperclips?
dan
Location of fuel pressure regulator? FlatBoost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-22-2006 12:50 PM
Location of high pressure fuel line ? boost4life Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-22-2006 09:47 AM
2002+ 2.5 RS location of vacuum lines? bahboy20 Normally Aspirated Powertrain 0 10-09-2004 05:03 PM
Location of Oil Return Line on Turbo? artdoesart Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-20-2004 09:14 AM
Location of fuel pressure sender Sparks Newbies & FAQs 4 04-05-2002 07:55 AM
