Old 10-07-2004, 02:19 AM   #1
simprezl25
Member#: 71647
2002 Bug iD
Default Fake "NAS" injection
i heard that on our RS's, we can make a MINI NAS injection. 1st you empty your wind shield wsher fluid, then connect the hose to the small hose that sits right ontop of the intake manifold and then put like rubbing alcohol or an alcohol. you just press the window washer buttom and you get 10-20hp. i can see how it working, but i dont belive it. stupid stuff? im not going ot try it.
simprezl25 is offline   Reply With Quote
Old 10-07-2004, 02:30 AM   #2
rawrFERNY
Member#: 51517
2007 Outlander LS
uhhhhhhhhhhhhhhh... i'd try it with a beater car!
rawrFERNY is offline   Reply With Quote
Old 10-07-2004, 03:27 AM   #3
Handsdown
Member#: 29355
yeah, it's called Naturally Aspirated Stupidity and it's good for 10-20hysterical points.
obviously, if you do this it won't be reliable and it won't be a good way to get hp, even if it does make any power.
you'd probably just throw your ECU into limp-home mode and over time do serious damage to your engine.
the alcohol-injected cars of the hot rod era were carbuerated and you could tune them by tightening bolts.
with a modern ECU you can't just jerry-rig your car to breathe alcohol. it's like saying you can gain HP by dumping some absolut in your gas tank.
Handsdown is offline   Reply With Quote
Old 10-07-2004, 03:33 AM   #4
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
cooling off parts of hot metal = bad
subiekid is offline   Reply With Quote
Old 10-07-2004, 11:31 AM   #5
simprezl25
Member#: 71647
2002 Bug iD
hahaha my thoughts exactly.
Old 10-07-2004, 02:25 PM   #6
tmeh
Member#: 30800
2000 .7 RS
my buddy had to rig a similar setup to move an old pickup a couple of blocks because his boss didnt want to waste money on a towtruck when the fuel pump died
he rerouted the washer spray line to the intake
filled the washer bottle with gas (using the ever-clever inhaling siphon method into a coffee cup)
then he put the truck in low gear and tap the spray button and let it chug along...
it worked.
only had to put the fire out 3 times.
by the time he made it down the street the entire top of the motor was melted, every electrical connector and hose was destroyed. good idea!!! at least it was a beater...
tmeh is offline   Reply With Quote
Old 10-07-2004, 06:06 PM   #7
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
You would need to have some type of orifice to induce a nice spray pattern. You would also want to center it on the manifold. Other than that it will prevent detonation and add a small amount of power. I don't see why it would throw a code.
Good luck
Tim Sanderson is offline   Reply With Quote
Old 10-07-2004, 08:08 PM   #8
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
You can get a thing at Wal Mart for like $2 that would work perfectly. It's meant to screw on to a water hose, then has a little hose to a mist nozzle that sprays a fine mist for misting flowers. The hose is the same size as windshield washer hose, so just yank the mister nozzle off and put it in the end instead of the washer nozzle. I made an intercooler sprayer like this once...
jasona is offline   Reply With Quote
Old 10-07-2004, 08:33 PM   #9
PJ2.5RS
Member#: 33697
PWN3D "Say goodby to NEON"...
Read THIS: http://www.ag.auburn.edu/users/gparmer/articles/neon/
informative, yet very funny...
classic quote from the article: "The motor took first gear launches at 2000RPM with cylinder pressures that should have shot the plugs through the hood, and exhaust gas temps that were slightly hotter than the surface of the sun."
PJ2.5RS is offline   Reply With Quote
Old 10-07-2004, 11:01 PM   #10
Storm
Member#: 5218
96L Most Over-
Developed Beater
I met those guys! They are very much nuts! But also very keen on what makes cars perform better.
Jay Storm
Storm is online now   Reply With Quote
Old 10-08-2004, 03:08 AM   #11
jasona
Member#: 11786
2014 OB 2.5i 6MT
Interesting. One time I put my nitrous kit on a rental Ford Focus and took it to the track. It was still slow
Fuel injection at TB vs. methanol injection swerv_on Water/Methanol Injection, Nitrous & Intercooler Cooling 2 02-04-2010 10:37 PM
Alky injection or meth injection? fastlanerex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-14-2007 12:53 AM
alky injection/water injection... i dont understand vipernj Water/Methanol Injection, Nitrous & Intercooler Cooling 3 09-05-2005 12:50 AM
Power difference between water injection and alky injection? scooterforever Water/Methanol Injection, Nitrous & Intercooler Cooling 10 06-21-2005 05:58 PM
stock fuel injecters/450hp VS more better fuel injecters/450hp FuJi K Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 03-25-2001 12:29 AM
