Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 10-07-2004, 04:48 AM   #1
Jesperss
Member#: 4996
02 Impreza
Default Installing air filter
Just went out and bought an air filter for my 02 2.5RS.
Any tricks I should know about installing it? Is it pretty straightforward?
Jesperss is offline   Reply With Quote
Old 10-07-2004, 05:15 AM   #2
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Its easy. Just make sure that you get the tabs back in place, on the bettom of the air box.
RS_to_WRX_swap is offline   Reply With Quote
Old 10-07-2004, 11:21 AM   #3
mikebike357
Member#: 35008
2003 Forester XS
2008 Outback 2.5i
It's actually easier to take the air box out, install the filter, and put the box in. That way you guarantee you have a good seal. I tried to do it w/o taking the box out... arghhhhh... eventually got it back together but it took longer than if I would have just taken the airbox out.
Just my 2 cents....
mikebike357 is offline   Reply With Quote
Old 10-07-2004, 12:21 PM   #4
orndog
Member#: 34670
2013 No gears!
Saltine American
Just my 2 cents....
Yep.
orndog is offline   Reply With Quote
Micro air filter install help! WalkmanX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-27-2002 09:28 AM
Anyones "check engine" light came on after K& N air filter was installed? Rozos Newbies & FAQs 11 11-05-2001 02:44 PM
Amsoil Air Filter install Skirvdawg Normally Aspirated Powertrain 4 02-17-2001 01:45 AM
Installed K&N Air Filter Fido General Forum Archive 6 09-20-2000 08:51 AM
Just installed this wierd factory option, air filteration system. Jason Legacy Forum 3 12-23-1999 10:36 PM
