Old 10-07-2004, 11:44 AM   #1
staticfritz
Member#: 66934
2004 JBP FXT
2002 cammed OBS - RIP
Default cracking borlas?
so this might be a bit newbie-ish, but obviously a lot of borlas crack
I assume this is because the rapid changes in temperature a header goes through (especially if splashed going through a pulle or something) and the fact that borla may not use as high a quality of welding as the headers costing 2x as much.
One way to try and alleviate this as far as i can tell is wrapping the headers..
but this inevitably attracts rust and salt come winter...
do you think having a skidplate installed would help protect the header?
staticfritz is offline   Reply With Quote
Old 10-07-2004, 12:16 PM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
my headers are wrapped and i've not had an CEL nor an issue.
that i know of there is no skidplate available that will clear the headers.
Jamie
www.subiegal.com
Old 10-07-2004, 12:18 PM   #3
Jyik40
Member#: 48540
2005 Spec-V
Sapphire Blue
A skid plate would help prevent thermal shock to the hot pipes (driving through standing water). But the only problem is that currently there are no skid plates that will fit with the Borla headers installed. I think they hang down too low for the skidplate to fit properly.
Jay
Jyik40 is offline   Reply With Quote
Old 10-07-2004, 12:28 PM   #4
staticfritz
Member#: 66934
2004 JBP FXT
crappy....
good thing i didn't buy the borlas quite yet....that rallyarmor plate is already installed...
how much clearance are we talking about? like way off, or is there some way to make it fit?
other headers fit though?
Old 10-07-2004, 02:10 PM   #5
piker28
Member#: 22664
you can try to use certain washers i was told to get em to fit but i havent heard of anyone being successful
piker28 is offline   Reply With Quote
Old 10-07-2004, 03:06 PM   #6
rawrFERNY
Member#: 51517
2007 Outlander LS
they hang too low?! grr then why is my sway bar hitting my headers
rawrFERNY is offline   Reply With Quote
Old 10-07-2004, 03:08 PM   #7
piker28
Member#: 22664
well what was the swaybar made for? most 02+ rs's dont change our swaybars since there really are non made for our cars, wrx ones dont fit, and older rs ones i dont thingk work either
you dont really need a front it does nothing
Old 10-07-2004, 03:10 PM   #8
rawrFERNY
Member#: 51517
2007 Outlander LS
the 04 wrx sway bars fit the 04 rs... well thats what racecompengineering told me. i have the cusco 21mm in the front and when i floor it on first i hear the sway bar hitting the headers... i was thinking about swapping out my front sway bar for maybe whiteline or something and see if it helps...
the front sway bar actually made a noticable difference in turn in, the car has a very slight lean in during cornering.
Old 10-07-2004, 04:33 PM   #9
piker28
Member#: 22664
the frotns dont fit, which is why they are hitting
Old 10-08-2004, 01:48 PM   #10
outbackwbeer!
Member#: 64060
98 lifted FOZ M/Ts
glacier white
I have a Primitive Enterprises skid plate on my '03 OBW I was planning on getting a set of Borlas! I will contact Paul Eklund about this issue of clearance he would know. Also from what I understand the new generation of Borlas don't crack!!! Most of the problems were with older headers(couple years ago).
outbackwbeer! is offline   Reply With Quote
Old 10-08-2004, 01:50 PM   #11
piker28
Member#: 22664
^^alot of peoples V4's have cracked
Old 10-08-2004, 02:43 PM   #12
staticfritz
Member#: 66934
2004 JBP FXT
argh...this is mighty frustrating....
so do NA rally club cars use the stock header or what?
Old 10-08-2004, 03:06 PM   #13
piker28
Member#: 22664
custom skidplate probably
Old 10-08-2004, 04:50 PM   #14
D-Speed 2.5
Member#: 29516
2005 WRX Wagon
Former GC O.G.
I've got 40k miles on my Borla and it hasn't cracked or even shown signs of aging. This is on a MY00 with an A/T. The only negative thing that i've experienced is that it used to heat up my transmission because of how close it was to the tranny coolant line. I now have a tranny cooler and have since moved the line. So no problems.
D-Speed 2.5 is offline   Reply With Quote
Old 10-09-2004, 01:30 PM   #15
Jyik40
Member#: 48540
2005 Spec-V
Sapphire Blue
I would pay extra money for Borla to make slight modifications to their current 4-2-1 header. I wish it had better fit and finish along with better pipe routing. I wish I could buy them (I love the sound they make), but I rather not worry about having them crack while I'm on a business trip somewhere.
Jay
Old 10-09-2004, 05:55 PM   #16
Sargeant_002
Member#: 65447
2005 Legacy 2.5 GT
Garnet Red Pearl
I got mine not to long ago...Borla Header's that is from a blowout deal on one of these threads...can't remember the thread title...but it was Brad from Titan Motorsports I think...and I've only got about 3-6k miles on them....and they seem fine...also, I thought Borla has a millon mile warranty? Anywho...I was told this latest model of Borla header's are good against cracking, I guess we'll see after winter...how they hold up...I'm sure they'll be fine...if not, I have that warranty to fall back on....and for the price I got mine for....can't complain yet.....
Sargeant_002 is offline   Reply With Quote
Old 10-09-2004, 10:36 PM   #17
Costas
Member#: 13760
1999 Impreza WRX
Rally Blue
There are skid plates available that clear the Cobb plates from Rally Armor
Costas is offline   Reply With Quote
Old 10-09-2004, 10:37 PM   #18
piker28
Member#: 22664
but they would never say if they fit the borlas
Old 10-09-2004, 10:41 PM   #19
Costas
Member#: 13760
1999 Impreza WRX
Rally Blue
Borlas wrap around the oil pan and droop low... the skid pan would be extremely low
Heres how they look like on a GC (I think they are similar on the GD)
In comparison to a stock set of headers....
Old 10-09-2004, 10:43 PM   #20
Costas
Member#: 13760
1999 Impreza WRX
Rally Blue
The Rally Armor plate is angled just enough for the Cobb headers to clear, without being too low
(Here it is bolted)
Old 10-10-2004, 02:25 AM   #21
staticfritz
Member#: 66934
2004 JBP FXT
that's the skidplate I have....
too bad i don't like the way cobbs sound or their price bracket
nice pics though. thanks for the detail
Old 10-10-2004, 06:09 PM   #22
lalaporter
Member#: 32946
2013 WRX Hatchback
white
I've had my Borla header for 10K. Sounds good and gives good low to mid range power, not much on top end. I've heard that turbos put exta weight on the end of any header due to the up and down pipes. That may be the source of cracked header complants. For NA I feel the gen VI Borla is a very good choice for street use.
lalaporter is offline   Reply With Quote
FS: Cracked Borla Headers for n/a. $40 badfish1134 NWIC Private Classifieds 14 10-08-2009 01:34 PM
FS: cracked Borla 2.5rs headers arkady151 MAIC Private Classifieds 33 03-31-2007 03:02 AM
FS: cracked Borla 2.5rs headers arkady151 Engine/Power/Exhaust 28 03-30-2007 05:31 PM
Cracking Borla headers G.Subramaniam Normally Aspirated Powertrain 19 09-24-2004 04:54 PM
Got welding skills? Cracked Borla 2.5 header fellfrosch7 Private 'For Sale' Classifieds 7 08-29-2004 06:26 PM
