Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 10-07-2004, 12:32 PM   #1
Rallitek.com
Vendor Sales Rating: (15)
Member#: 34814
08 WRX
Lightning Red
Subaru Banner iPd 22mm Front Sway bars $99.99
$99.99
BUY NOW!
New! iPd Non-turbo Front Sway Bar fits all Impreza, Legacy, Forester, and Baja non-turbo models. Kit includes: iPd 22mm Front Sway Bar, and poly bushings.
Whiteline Sub-Frame Lock Bolts $34.99 Shipped
www.rallitek.com/specials.asp
MSRP $49.99
This kit is designed to lock the rear sub-frame (also called cross member or diff carrier) on Subaru Impreza, WRX, STI and certain Legacy models. It allows for more precise alignment of the rear wheels and limits the amount of rear sub-frame movement under cornering loads, which can result in poor dynamic alignment settings. The hardware is designed to be installed and removed between race meetings. The kit does increase rear NVH levels as it effectively locks out the sub-frame bushings. It is designed for race use and should not be used for extended periods as it may lead to bremature chassis wear.
Whiteline Power Steering Rack Bushings $34.99 Shipped
MSRP $49.99
Stop road wander, and feel more connected to the road with Whiteline polyurethane power steering rack bushings. The factory bushings that hold the power steering rack are soft and allow the steering to wander back and forth. This causes the car to pull in ruts and makes the steering feel 'loose'. This one is a must have!
Braided Stainless Steel Brake Lines $119.99 Shipped
www.rallitek.specials.asp
MSRP: $139.99
Improves pedal feel for better brake modulation. Quality checked and pressure tested. Direct bolt on. A must for improved safety and performance. Agency Power now has a wide variety of steel braided brake line and clutch line kits for most high-end performance cars. The brake line and clutch line kits are made in the USA to meet strict D.O.T. certifications. The steel braided lines are a smoke color with the AP logo printed on it. The CNC machined fittings are in classic Agency Power Gold to separate you from the competition. All kits are assembled for a quit and easy install. Include fittings, hoses, and necessary hardware.
$34.99 SHIPPED
BUY NOW!
Whiteline T Mount Bushing Kit locks rear diff supports where they mount to the body, reducing rear-end float,and removing that "thump!!" on hard gear changes. $34.99 SHIPPED (USA/CANADA)
www.RalliTEK.com
503.546.9209
$99.99
BUY NOW!
Agency Power has heavy-duty rear sway bar links available for the 2004 and up Subaru STI. These rear replacement end links also fit in replacement of the factory front end links on the 2002 and up STI or WRX wagon and sedan. What are sway bar links? Sway bar links replace your factory urethane or thin metal links, which connect the sway bar to the cars chassis. Weak factory end links mean flex in suspension components and loss in handling. Why use Agency Power end links? Reducing suspension flex means improved handling. The factory end links are sufficient for the factory car. However, vehicles with more power, more handling needs, and more aggressive drivers are recommended to switch the end links. They fit the stock or aftermarket sway bars to reinforce and strengthen the suspension setup. Providing a rigid and improved feel. These CNC machined end links are anodized in Agency Power gold. They utilize a spherical bearing for best handling and reduced wear compared to urethane applications. Also included are full stainless steel metric hardware for easy installation and longevity. The sway bar links are engraved with the AP logo and the end links include a 90-day warranty against manufacturer defects.
www.RalliTEK.com
503.546.9209
Rallitek.com is offline   Reply With Quote
Old 10-08-2004, 12:14 PM   #2
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Check out all our specials!
Old 10-12-2004, 03:20 PM   #3
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
We are selling these like crazy and to show our appreciation we just lowered the price more for you For all of you who ordered we will be reimbursing you the difference too! These are selling quick though, so order right away. (Don't worry though, I think we have enough for all of you ) If you have any questions, please email us at sales@rallitek.com
Old 10-19-2004, 04:39 PM   #4
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Subaru Banner
Call in for package deals!
503.546.9209
www.RalliTEK.com
Old 10-27-2004, 04:09 PM   #5
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Any questions?
www.RalliTEK.com
Old 10-31-2004, 01:50 AM   #6
rawrFERNY
Member Sales Rating: (5)
Member#: 51517
2006 Mini Cooper S
Dark Grey
just ordered the steering rack bushings from you guys
rawrFERNY is offline   Reply With Quote
Old 11-01-2004, 02:58 PM   #7
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
They are on the way!!! You should already have reciepts and tracking numbers.
Garner Thomas
www.RalliTEK.com
Old 11-01-2004, 03:02 PM   #8
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
These are regularly stocked items, we have LOTS of them!
Bernie Russnogle
www.RalliTEK.com
Old 11-01-2004, 07:24 PM   #9
Nok's WRX
Member Sales Rating: (1)
Member#: 25797
2002 PSM - Stock
Just ordered steering rack bushings and t-mount bushings....
Nok's WRX is offline   Reply With Quote
Old 11-01-2004, 07:28 PM   #10
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Just got the order! Missed the truck for today. We will all be at the SEMA show for the next 2 days. We will get your order out to you ASAP!
Thanks,
Garner Thomas
www.RalliTEK.com
Old 11-03-2004, 12:01 PM   #11
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Writing to you from SEMA in Las Vegas! The techs and shipping have the next 2 days off. The rest of us are shopping for new products at SEMA, what would you like to see?
Sean Sexton
www.RalliTEK.com
Old 11-03-2004, 03:26 PM   #12
rawrFERNY
Member#: 51517
2006 Mini Cooper S
Dark Grey
just recieved the steering rack bushings this morning and finished installing and driving it a little, that delivery was fast! thanks!!
Old 11-05-2004, 02:57 PM   #13
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Thanks for the kind words. We don't drop ship, parts are in stock. I am glad we could be so responsive. How well do you like the bushings?
Sean Sexton
www.RalliTEK.com
Old 11-12-2004, 03:46 AM   #14
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
bump
Old 11-12-2004, 04:47 PM   #15
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Just recieved 22mm Front Sway Bars for Non-turbo Subaru! This time only NASIOC special of $99.99!!
I will have the bars listed at www.RalliTEK.com very soon. Call in if you need one now. 503.546.9209 or email sales@rallitek.com
Sean
www.RalliTEK.com
http://forums.rallitek.net/vbulletin/
Old 11-15-2004, 12:52 AM   #16
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Old 11-18-2004, 10:53 AM   #17
AFBeefcake
Member Sales Rating: (63)
Member#: 27874
2002 WRX 6MT 312whp
05 LGT
I PMed you, but Have not heard back yet.
AFBeefcake is offline   Reply With Quote
Old 11-18-2004, 12:27 PM   #18
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
You have a message!
Sean
Old 11-22-2004, 06:21 PM   #19
hungiema
Member Sales Rating: (2)
Member#: 45682
1998 legacy 2.5 gt
dark green
great service...already shipped my sway bar that i ordred last night!
hungiema is offline   Reply With Quote
Old 11-22-2004, 09:22 PM   #20
Bankie
Member Sales Rating: (4)
Member#: 37785
OT hates your car
I just have a question about the iPd Non-turbo Front Sway Bar. You say that it'll fit all non-turbo Imprezas. If it will fit an Impreza RS or TS wouldn't it fit a WRX wagon?
Bankie is offline   Reply With Quote
Old 11-22-2004, 10:05 PM   #21
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Front frame cross members are different between turbo and non-turbo Subarus. There are clearance issues with the exhaust, thus the two different front bars. The rear bars are interchangeable on those models.
Sean Sexton
www.RalliTEK.com
Old 11-23-2004, 06:51 PM   #22
AFBeefcake
Member#: 27874
2002 WRX 6MT 312whp
05 LGT
Got my parts today. Thanks
Old 11-24-2004, 06:17 PM   #23
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Just a note you guys...
Only 2 iPd N/A front sway bars left.(I promise to have better pics up on the site when we get the next order in.) We have sold out the manufacturer for a few weeks! Lots of WRX sets, and rear bars kits in stock though.
Steering Rack Bushings are out of stock until Monday. (Just after Thanksgiving) We will be shipping them out on Monday, so any orders over Thanksgiving weekend will not be delayed.
Stainless Brake Lines are running low. Pre '02 lines are sold out. We have 2 sets of '02+WRX and STi lines left. Get 'em while you can.
Specials will change after the holidays. All orders before the website Specials are updated will be filled at the sale prices.
Thank you,
Sean Sexton
www.RalliTEK.com
RalliTEK Subaru Performance Inc. at SEMA Rallitek.com North West Impreza Club Forum -- NWIC 6 11-05-2004 01:33 AM
RalliTEK Subaru Performance Inc. at SEMA Rallitek.com News & Rumors 0 11-03-2004 11:52 AM
RalliTEK Subaru Performance Inc. - New Location Celebration - Thank You. Rallitek.com North West Impreza Club Forum -- NWIC 7 10-20-2004 09:26 PM
RalliTEK Grand Re-Opening! Berns North West Impreza Club Forum -- NWIC 2 10-01-2004 12:25 AM
Message Board Statistics All times are GMT -4. The time now is 02:54 PM.
