Old 10-07-2004, 04:35 PM   #1
sfr4dr
Member#: 50316
1995 Legacy L
Default Screwed up timing belt alignment. Need help
So, I'm posting for my friend that has a 2.2 fwd legacy. I think it's mid 90's. He had the timing belt off to be replaced and for some reason cranked the engine over. How should he get the crank and both cams re-aligned so he can put the new belt on? I think he marked the cams before he took them off but now the crank is way off so who knows.
sfr4dr is offline   Reply With Quote
Old 10-07-2004, 06:48 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Just realign the marks and put the belt back on. If the belts has no marks on it then you will be counting belt teeth and using a marker to set the correct alignment marks. Unfortunately, my manuals are for my00.
Tim Sanderson is offline   Reply With Quote
Old 10-07-2004, 07:06 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Do as Tim said. Just align the marks on the cam sprocket and crank gear. The crank gear mark can be a little tricky to figure out exactly where it is.
Here's pics from my legacy t-belt change. This should give him all the info he needs
http://www.main.experiencetherave.co...ges/timingbelt
josh
Legacy777 is offline   Reply With Quote
Old 10-08-2004, 02:12 PM   #4
sfr4dr
Member#: 50316
1995 Legacy L
Yeah, the crank gear is the problem. He didn't mark it, so we don't know where it is in relation to the cams.
Old 10-08-2004, 02:20 PM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
It does'nt matter. Pull the plugs and turn the crank to align the marks. Then align the cams. Put the belt back on and re-do the tensioner.
Old 10-08-2004, 04:47 PM   #6
jamesfacts
Member#: 51282
98 RS
black & blue from parking
josh
Word. It is next to impossible to find - I did this on a '91 Legacy once and it was so frustration to actually find the mark!
jamesfacts is offline   Reply With Quote
Timing belt alignment, need opinions/expertise Boxerocks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-10-2010 02:46 PM
Eeek - screwed up my rear suspension, need help. JediRex Brakes, Steering & Suspension 14 05-14-2007 04:55 PM
Timing Belt Problem - Need Help ASAP Egan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 07-21-2003 07:21 PM
IS there a way to double-check my timing belt alignment? scootr Service & Maintenance 4 10-29-2001 02:16 PM
