Old 10-07-2004, 06:11 PM   #1
CatchMyDrift
Member#: 54523
Exclamation EJ25 Need help PLEASE!
Honkey3k and I just finished our first motor swap. Well, we replaced his shortblock. He has a 98 Legacy Outback with an EJ25D motor. We replaced the shortlbock with one from a 2000 Legacy. Supposedly the motors were the same. Come to find out the pistons were different. His stock pistons seamed to be lower compression pistons than the ones in the newer block. The older ones looked almost identical to the WRX pistons. The new ones have little ridges instead of the square cut.
So we have everything wired up correctly ( To the best of our knowledge ), all the hoses connected and vacuum lines connected. Coolent is in, oil is in, spark plugs in and gaped correctly. (Everything) But when we try to start it, there doesn't seam to be any compression. The starter engages nicely, plenty of fuel, plenty of spark. But there's smoke coming out of the intake.
So we unhooked the intake from the throttle body thinking thats where it was coming from. Nope. It was coming from the largest hose that connects from the intake manifold to the intake itself. ( The long black tube ) It's no ordinary smoke though. There's a gas smell to it when it blasts out, but when I wipe it the smell is gone. Could it be water?
Justin and I will have a short video clip up in a bit to give you a better idea. Anybody with comments are welcome.
Thanks for your help,
Benny
CatchMyDrift is offline   Reply With Quote
Old 10-07-2004, 07:48 PM   #2
Honkey3k
Member#: 53992
SOLD CGM 2005 2.5RS
35 PSI -- in my tires
Ok, we had some other guys stop by and take a look. Their best guess is that the timing is off. Justin had a family friend put his motor together, along with a new timing belt. Were still working on it.
Benny
Honkey3k is offline   Reply With Quote
Old 10-07-2004, 09:24 PM   #3
Honkey3k
Member#: 53992
SOLD CGM 2005 2.5RS
*Update*
We found the prob. The timing was off by 180 degrees. Our exhaust was trying to come out the intake. Im a post whore too. What can I say.
Mods...This thread is done.
NNJ: Need to use a lift or need help! PLEASE! CoBB_tHiS! Tri-State Area Forum 6 05-05-2010 05:46 PM
i need help.. PLEASE HELP. WRXdriver04 Engine Management & Tuning 6 12-14-2005 09:17 AM
need help, please help!!! ralyrcr Mid West Subaru Owners Club Forum -- MWSOC 11 08-30-2005 08:39 PM
I need to order a clutch ASAP - Need help please Rizzo314 Transmission (AT/MT) & Driveline 3 11-05-2004 07:10 AM
Hard Drive Recover Help much needed... ATA RAID 0 knowledge needed HELP PLEASE!!! 2k2 Off-Topic 63 12-24-2003 10:35 PM
