Old 10-07-2004, 11:47 PM   #1
nytoy
Member#: 48962
2000 Impreza 2.5RS
Exclamation Uneven compression results '00 EJ25
How bad is this, obviously the compression is within spec, this is cold.
160
145
150
160
According to the service manual 130-160 is good, it shouldn't be more than 7 psi difference in the cyl's. Is this a sign of impending headgasket failure? This is for a car I'm looking to buy. Thanks.
nytoy is offline   Reply With Quote
Old 10-08-2004, 12:03 AM   #2
Akarui
Member#: 60195
World Rally Blue
check your valve train I had similar numbers on MY02RS and it was a sticky intake valve. I suggest a good cleaning with something such as SeaFoam cleaner then check it agian and see if it cleans the carbon buildup off the valves. It woudl help if you knew which valuse goes with which cylinder ie. 1-4.
Akarui is offline   Reply With Quote
Old 10-08-2004, 09:35 AM   #3
nytoy
Member#: 48962
2000 Impreza 2.5RS
Hmm so I guess I shouldn't totally panic.
Old 10-08-2004, 12:12 PM   #4
ratt_finkel
Member#: 46218
06 EVO 9
Yeah, thats not a huge difference. I wouldn't worry about it.
Now, if one were at 120, or lower, then you should start to take notice.
ratt_finkel is offline   Reply With Quote
Old 10-08-2004, 12:20 PM   #5
jeffg
Member#: 2958
2001 WRX (GC8)
motors are never even on compression, even when new. The general idea is +/- 10%. You are pushing the limites from 160->145, but I think you are okay. You should generally do compression tests with the motor full warmed up, but on an Impreza you would just end up with burned hands.
J
jeffg is offline   Reply With Quote
Old 10-08-2004, 03:51 PM   #6
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Doesn't look that bad. Subaru compression is inherently lower due to the flat engine design.
jamesfacts is offline   Reply With Quote
Old 10-08-2004, 04:03 PM   #7
Hayes
Member#: 11808
Was the compression measured with the throttle WIDE open. If not the the reading are bogus. If after measuring the compression do a vacume check with a good gage as this will help diagnoise a problem. ed
Hayes is offline   Reply With Quote
Old 10-08-2004, 05:45 PM   #8
Akarui
Member#: 60195
World Rally Blue
There's no reason to panic yet are you experiencing a missfire? If then engine runs good I would say give it both some injector cleaner and some seafoam thru the pcv to clean off your intake valves and you should be good.
Old 10-13-2004, 02:40 PM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
cold compression test=uselss
warm it up and try again and make sure the thottle body is Wide open when cranking
Old 10-13-2004, 03:12 PM   #10
nytoy
Member#: 48962
2000 Impreza 2.5RS
thanks for the responses, I'm gonna try some super fuel injection cleaner, then warm it up and try it again.
MA: '00 EJ25 lots of aftermarket theNinja 1993 - 2001 Impreza Specific Parts 16 09-10-2009 02:30 PM
FS: '00 EJ25 longblock sscguy MWSOC Private Classifieds 4 06-20-2009 10:22 PM
Lots for sale Including '00 EJ25, Tires Supapooh NWIC Private Classifieds 45 07-11-2007 12:16 PM
torque specs for intake manifold '00 EJ25? Dr Ken Normally Aspirated Powertrain 0 09-13-2003 10:40 PM
MY00 compression results? Fitz Normally Aspirated with bolt-on Forced Induction Powertrain 9 08-29-2001 09:38 AM
