Old 10-08-2004, 10:31 AM   #1
myles
Member#: 43086
2000 Impreza 2.5rs
aspen white
Default Removing the Heads from my EJ25?
I trying to Port, Polish and Match my heads as well as get new cams and headers but I want save on labor cost. How difficult is it to remove the heads and is there a step by step guide or something like that to help? Or does anyone live in the chiago land area that would want to give a helping hand for some extra cash? something like that. I just need some help cause labor chages will rape me.
myles is offline   Reply With Quote
Old 10-08-2004, 12:54 PM   #2
jeffg
Member#: 2958
2001 6.0?RS
only thing I know.... mark the timing belt and pulleys before you take it off. A white paint marker will be your friend here.
jeffg is offline   Reply With Quote
Old 10-08-2004, 02:12 PM   #3
chip4761
Member#: 55867
2005 Saabaru
AS
Yeah, I have a similiar question about this. I know how to get the heads off, but when I tried to do it on my ej22, I was afraid that the head bolts were going to snap. I really don't want to have to take my whole block to a machine shop to get those suckers out. Is there a good way to get them out? Heat the block with a torch? I really don't know. Throw me a bone.
chip4761 is offline   Reply With Quote
Old 10-09-2004, 04:00 AM   #4
RyansJDMgc8
Member#: 65462
01' 2.5RS
Silver/Carbon Fiber
I suggest start the engine and let it run until normal operating temperature. Then turn it off and start tearing apart the heads, so by the time you get to the head bolts, they will still be warm. I know its no Subaru, but thats how I took the heads off on my 73' Big Block Nova.
I try to keep torches as far away from my engine as possible.
RyansJDMgc8 is offline   Reply With Quote
Old 10-09-2004, 12:08 PM   #5
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
doesn't heat make things expand?? Wouldn't that make the bolt/hole a tighter fit?? Maybe this isn't true, but I would think that a cold block would be better, but I have NO experience on this and shouldn't be trusted
Jared
gtwagon941 is offline   Reply With Quote
Old 10-10-2004, 02:40 AM   #6
chip4761
Member#: 55867
2005 Saabaru
AS
Thank you for the honesty, Jared!
Well, getting the head bolts off with the engine in the car would be a problem, as the heads on one engine are no longer in a car. My buddy and I were just talking about getting the heads off the 1.8 and seeing if the head studs snap. If no, good. If they do, oh well, b/c I'm not using that block anyway. However, I would have to figure something out with the 2.2.
Old 10-10-2004, 12:41 PM   #7
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
The block and heads are aluminum. The bolt is hardened steel. I highly doubt you are going to snap the bolts.
Tim Sanderson is offline   Reply With Quote
Old 10-10-2004, 01:02 PM   #8
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
the bolts are alluminum i believe, or not hardened steel they stretch quite a bit
Old 10-10-2004, 01:27 PM   #9
chip4761
Member#: 55867
2005 Saabaru
AS
Aluminum bolts? That sounds like dumb idea, on Subaru's part. I figured they were steel, and they had reacted with the aluminum, hence the sticking. They've been in there for awhile, that's why I'm concerned about them breaking.
Old 10-10-2004, 11:37 PM   #10
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
They will come out. They are definately not aluminum bolts.
Old 10-11-2004, 02:16 AM   #11
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
eh youre probably right, they sure seem flimsy tho
Old 10-11-2004, 02:34 AM   #12
Storm
Member#: 5218
96L Most Over-
Developed Beater
What are you trying to take them off with? Quality tools with the correct 12pt socket? If you're using worn out tools, it could very well be those instead of the bolts that feel flimsy.
If you think the headbolts are hard to get out, don't even try to split the block!
Jay Storm
Old 10-11-2004, 12:59 PM   #13
Section 8
Member#: 821
The bolts feel "flimsy" because they are very long. There is gong to be alot of strech compared to a 2 or 3 inch bolt that most people are use to. (this is part of the reason for the odd tightening sequence).
Heat will make metal expand. However different metals expand at different rates. Aluminum has significently higher coeffcient than steel. While the bolt head will press into the head harder and generate more tension in the bolt, the threads of the bolt will be pinched less. Being warm may or may not help remove the bolts.
Which leads us to adding heat to the bolt head:
Using a torch on a 8+inch bolt on an aluminum head isn't such a good idea. Aluminum is a better conductor of heat than steel, a large part of the heat you put into the steel bolt will likely be removed by the aluminum at the bolt head, and the left over heat that makes it to the threads will be rapidly removed from them by the block. Which is sort of waht you want, but by that time you have substantionally heated up the head in one spot possibly causing it to warp.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 10-11-2004, 04:58 PM   #14
SubyGC8
Member#: 70069
2005 Legacy GT
Satin Pearl White
Dont mark the timing belt and pulley where it is.. you have to turn the engine over to TDC (top dead center). Then the pulleys should already be marked from the factory. Thats what timing marks are. There are also timing marks on the crank pulley.. They do this because the cams are rotating at half the speed of the crankshaft.. If you plan on doing this yourself you may want to buy a manual that tells you everything you need to know because your also going to need torque specs, which is very important in building or putting the engine back together. also your going to need new headbolts because they do stretch and will not torque properly the second time around.
SubyGC8 is offline   Reply With Quote
Is torqueing down the head, then removing the head, considered reusing the gasket? mokujin22 Built Motor Discussion 8 10-20-2006 08:29 AM
Simply removing the headlight from my 05 STI rack Alaskan Impreza Club Forum -- AKIC 3 04-10-2006 01:53 AM
To Remove The Heads caged1 Normally Aspirated Powertrain 6 07-31-2005 09:45 AM
How do I remove the clock from the center pod housing the clock? impRSa Electrical & Lighting 3 03-30-2005 11:25 AM
