Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 10-08-2004, 02:13 PM   #1
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Default Should I port my stock turbo while I'm doing uppipe/downpipe
I'm about to install an uppipe and downpipe on my stock turbo this weekend. I already have a Borla Hush catback, Perrin Pulley, IC hoses, and Cobb Accessport in terms of power modifications. The guy who is helping me out offered to port the exhaust side of my turbo and said it shouldn't take more than 45 minutes beyond the labor we're already doing. Is it worth it? He said I might loose some boost if it is done. Can the Accessport compensate for this? I want reliability and compatibility with the Cobb stage 2 tune before anything else. I don't want to mess around with this if it could cost me power/spool.
whtlegacy is offline   Reply With Quote
Old 10-08-2004, 02:21 PM   #2
crazymikie
Member#: 56321
2006 Honda El Camino
Green
I thought porting the exhaust side should help spool-
If you enlarge the inlet to match the uppipe, you should get less disturbance with the exhaust flow == high velocity == quicker spool. I could be wrong though.
I believe someone talked to Cobb (he's running Stage 2) and they told him ported headers and a ported turbo will play nice with the Cobb tune just fine.
Just my $.02.
crazymikie is offline   Reply With Quote
Old 10-08-2004, 03:09 PM   #3
zinc99
Banned
Member#: 56030
02 stage 2 wagon
run a search for deadbolt, they port stock turbos and there is alot of info on them. They do spool faster but thats about it, its nice for you get even less lag.
zinc99 is offline   Reply With Quote
Old 10-08-2004, 04:25 PM   #4
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
I've heard good things about Deadbolt but I'm wondering if porting just the exhaust side would have any noticeable effects. Also, this guy was telling me that if we did it, I might loose a pound or two of boost. He suggested turning it back up with an MBC but I don't want to have to deal with that. Why would I lose boost? Would the AP compensate for this?
Old 10-08-2004, 06:11 PM   #5
hondaeater69
Member#: 60324
They say the AP is capable of learning around a P and P. Not sure why you would lose max boost, but you will get boost sooner. Ideally you should have a map created for P and P to shift your boost curve to the left, but cobb says it's within the learning capabilities of the ecu and map. I would also have it turbo wrapped while you have good access to it, it will help to greatly reduce underhood temps, reduce heat soak, and they say it helps keep the turbo spooled too (never noticed the last one myself). And get a heat shield too!! Those two things combined will do wonders for your TMIC. Good luck!
Old 10-08-2004, 07:36 PM   #6
AdamRX
Member#: 67601
'08 WRX Sdn
Slvr
what would you use to wrap the turbo and where do you get it?
AdamRX is offline   Reply With Quote
Old 10-09-2004, 12:48 AM   #7
distorto
Top Scoob 024
Member#: 56364
RIP stompr :(
bagged vulvva
i think you could lose boost if you ported it too much...
distorto is offline   Reply With Quote
My dog barks while I'm gone. OT halp! Rancid Off-Topic 18 07-01-2009 04:59 PM
what else should while im doing uppipe and ordering stuff? rbmour Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-24-2005 03:31 PM
why do my legs itch while i'm exercising? marina Off-Topic 26 05-23-2005 01:24 PM
Port And Polish My Stock Turbo In Md mpower22 Mid Atlantic Impreza Club -- MAIC 26 08-26-2004 08:24 AM
Where should I be setting the boost on my stock turbo? chrisdeaner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 08-17-2004 03:42 PM
