Welcome to the North American Subaru Impreza Owners Club Saturday September 5, 2015
Old 10-08-2004, 02:24 PM   #1
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
Default Took out my rear seat and drove around, but noticed it is loud as hell
It is loud as hell without the sound deadening of the rear seat pad! Especially on highways, I could hear a sound that sounds EXACTLY like a circular saw cutting a 2x4. The similiarity is uncanny. It's as if I had a woodshop back there.
I noticed that if I let off the gas at around 70-75mph, I would get this very high-pitched grinding sound (circular saw cutting a 2x4). It seems to be the loudest when I let the gas off. If I'm accelerating, it's not as bad.
Is this the deceleration noise that I hear about on Nasioc, but amplified because I don't have the rear seats installed?
volkl23 is offline   Reply With Quote
Old 10-08-2004, 02:49 PM   #2
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Sounds like the rear diff possibly. I was thinking wheel bearing at first, but doesn't seem like it.
garface is offline   Reply With Quote
Old 10-08-2004, 06:38 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
is it a whining type sound? you do know what the fuel pump sounds like? It's sort of a high pitch whine sound
Legacy777 is offline   Reply With Quote
Old 10-09-2004, 07:22 AM   #4
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
Noise = rear diff, all rear diffs make that noise, it's the gears. Most people just don't notice because of the sound damping material or stereo.
wrx plus is offline   Reply With Quote
Old 10-11-2004, 02:25 AM   #5
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
Thanks for the reply guys...
LEgacy: I am not familiar with the sound a fuel pump makes. The sound I am experiencing is of a whining nature (sound of a circular saw cutting a 2x4) so it might be it...although, I do hear the "saw" sound the most when I let off the gas and when the speedos around 75mph or so. Would the fuel pump make sounds when I'm not on the gas?
I think I might know what the fuel pump sounds like. Everytime I start the car, I hear a really high-pitched sound (sort of eletronic sounding, but different from the "saw" sound I'm hearing on the highway) coming from the back. It would only last for 5 seconds or so and then it would disappear. Is that the sound of the fuel pump?
I'm guessing it might be the differentials. I just don't know if it's normal or not I'm going to change my rear diff oil soon (i'm at 24k miles) so maybe that will help out a little.
Old 10-11-2004, 08:55 AM   #6
Legacy777
Member#: 4800
Does the noise change much with speed? If so, it's probably not the fuel pump.
Old 10-11-2004, 10:15 AM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
my fuel pump makes a lot of different noises depending upon the fuel flow
Old 10-11-2004, 11:49 AM   #8
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
It does change a lot, but I don't think it's the fuel pump sound now. Unless the fuel pump sounds like a circular saw cutting a 2x4 (or even a sharpening tool sharpening a blade), I don't think it's that.
Also, it makes a lot of sound when I'm coasting and not on the gas. Maybe it's all nothing, because I really couldn't hear it with the rear seat installed.
Old 10-11-2004, 11:50 AM   #9
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
hmm
my rs also makes that noise at certain vibrational frequencies
the pass center pillar <whatever its called> rattles really fast and sounds kinda like that, its not deafening but similiar
Old 10-11-2004, 01:06 PM   #10
Legacy777
Member#: 4800
Well....I wouldn't think it to be the fuel pump then....and wheel bearings probably wouldn't change sound or increase when going from accelerating to coasting. I'd probably say it's a drivetrain issue, rear possibly.
Subaru does have a 60k drivetrain warranty right? I'd just take it to the dealer....even if it's only 36k, I'd still take it to the dealer. Sounds like warranty work to me.
Old 10-11-2004, 01:19 PM   #11
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
yea i noticed the same sound when i had my rear seat out and always wondered what it was. The sound i got didnt happen until higher rpms though. Everytime i reached like 4500-7k i would get an extremely loud buzz sound. I couldn't imagine this be the fuel pump or sound deadening preventing me from hearing the sound since it is so loud. I think its just the seat belts hitting the hard plastic and making that buzz sound. With the seats there its soft and it has nothing to smack against that would make that noise under.
dan avoN7 is offline   Reply With Quote
Old 10-11-2004, 10:01 PM   #12
UrbonWRX
Member#: 71382
0407 WRX/C6 Vette
WR Blue and Vel. Yellow
i have recently taken out my back seats, and the only sound i hear thats different before is the exhaust comes through the car a little bit more....(shoptime!)
UrbonWRX is offline   Reply With Quote
Old 10-11-2004, 10:39 PM   #13
96Imprezadent
Member#: 62556
1995 Fastest EJ18T
13.4@105 Record Run.
whoa people. dont shut out wheel bearings or a bad CV so quickly. One or both is bad on my car and it shakes differntly according on throttle position. the sound would occur with hard driving. this week my rear seat has been out and the noise is there even w/ regular driving, which means it was always there, i just couldnt hear it.
96Imprezadent is offline   Reply With Quote
Old 10-12-2004, 12:06 AM   #14
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
WRX's have no sound deadning material. I have had my seat out numerous times. For days sometimes. My 03 makes no such noise. I do have knocking from solid camber plates but the noise you describe is foreign. Always thought that wads the reason for the 3.54 and 3.9 in the front. The rear is quieter. With the seat completly out, I was amazed how I could not hear anything but the exhaust and metal resonating.
I now have tons of dynamat extreme in my trunk and passanger area. Now all I hear is exhaust. no metal resonating and definitly no buzzing.
May seem basic, but did you check the oil level in the rear diff? I imagine if it were low you would hear gear wine more easily.
ebeck is offline   Reply With Quote
Old 10-13-2004, 09:10 AM   #15
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
^^ I think you might be onto something. I have never checked my rear diff level before. Do I just unbolt the top screw and see where oil level is? If it's low, do I just stick a finger in and see how low I have to go before I touch the gear oil?
Old 10-13-2004, 09:45 AM   #16
Legacy777
Member#: 4800
The gear oil level should be at the bottom of the top filler hole. If it's not, add some more until is starts dripping out.
Old 10-13-2004, 05:22 PM   #17
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
Use a turkey baster or something. There are tools for refilling it but turkey baster works fine too.
this is geeky as hell but cool OvrClkdPmp Off-Topic 16 09-23-2005 01:59 AM
SUNY Albany, who has that black rex that is loud as hell Keith Tri-State Area Forum 10 02-28-2005 12:01 PM
Hit and Run: Lastnight someone took out my rear left quarter panel. CaptPuppet Texas Impreza Club Forum -- TXIC 2 09-03-2004 09:55 AM
Check out my new seat and rims! ommmjido Member's Car Gallery 38 05-25-2004 12:12 AM
